YouTube “Restricted Mode” Issue on Mac - Seeking Advice
Hello!
First off, I just want to say I’ve been really happy with my hAP ax lite. I’ve also received some great help here before, so I’m hoping I might get a bit of that same expertise again. This isn’t a major issue, but it’s recently started to bug me a little.
Whenever I’m connected to this network (my remote island cabin) with my MacBook, YouTube automatically enables “Restricted Mode.” This means I can’t view or write comments. The toggle in YouTube’s settings is greyed out with a note saying:
“Turned on by your network administrator to help hide potentially mature videos.”
I’m currently using AdGuard DNS with an active Adlist, which has worked great overall (even TikTok ads are gone). My first thought was that this setup might be triggering the restriction. However, I tested by switching DNS to Cloudflare and Google, disabled the Adlist, and flushed DNS on my MacBook - yet the issue persists. I’m using a Starlink as my internet connection.
I’m using Safari, but I also tested Brave after flushing DNS with the same result. Interestingly, my iPhone on the same network shows YouTube comments normally (using the YouTube app), and when my MacBook connects to my home network, the restricted mode is off and everything works as expected.
It’s not a serious problem, but there’s one particular video I’d really like to comment on using a proper keyboard. :sweat_smile:
Would you happen to have any idea what could be causing this?
If you need more details, I’m happy to share configuration info. I’ve attached the current setup for reference.
Thanks in advance for your time and help!
# 2025-10-10 13:11:49 by RouterOS 7.20
# software id = 890S-TZSJ
# model = L41G-2axD
# serial number = *
add admin-mac=* auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name="ether1 (Internet)"
set [ find default-name=ether2 ] name="ether2 (NAS)"
set [ find default-name=ether3 ] name="ether3 (Sauna)"
set [ find default-name=ether4 ] name="ether4 (LAN)"
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration.country=Finland .mode=ap .ssid=* disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface="ether2 (NAS)"
add bridge=bridge comment=defconf interface="ether3 (Sauna)"
add bridge=bridge comment=defconf interface="ether4 (LAN)"
add bridge=bridge comment=defconf interface=wifi1
add comment=defconf interface="ether1 (Internet)" list=WAN
    192.168.88.0
/ip dhcp-client
add comment=defconf default-route-tables=main interface="ether1 (Internet)" \
    use-peer-dns=no
/ip dhcp-server lease
add address=192.168.88.244 client-id=1:0:11:32:c9:b4:f7 mac-address=\
    00:11:32:C9:B4:F7 server=defconf
    192.168.88.1
set allow-remote-requests=yes cache-size=50048KiB servers=\
    94.140.14.14,94.140.14.15
/ip dns adlist
add disabled=yes ssl-verify=no url="https://raw.githubusercontent.com/hagezi/d\
    ns-blocklists/main/adblock/pro.plus.txt"
add ssl-verify=no url="https://gitlab.com/hagezi/mirror/-/raw/main/dns-blockli\
    sts/adblock/pro.txt"
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add address=94.140.14.14 name=adguard-dns.com type=A
add address=94.140.15.15 name=adguard-dns.com type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add comment=Starlink disabled=no distance=1 dst-address=192.168.100.1/32 \
    gateway="ether1 (Internet)" routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=10
add comment="Huawei 4G" disabled=no distance=1 dst-address=192.168.2.1/32 \
/ip service
set ftp disabled=yes
set telnet disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Helsinki
/system identity
set name="*"
/tool mac-server
/tool mac-server mac-winbox
mokkisauva.rsc (7.5 KB)
Additional info:
When I connect to a VPN (Mullvad), which uses its own DNS servers, the issue disappears instantly. Simply refreshing the YouTube page is enough to fix it.
But your exported config still has an active adlist (with the URL https://gitlab.com/hagezi/mirror/-/raw/main/dns-blocklists/adblock/pro.txt).
Yeah, I re-enabled it before exporting the config.
You are using 94.140.14.14 and 94.140.14.15 as upstream DNS server for your router. But those two servers block ads by default, see the list here:
AdGuard DNS moves to new addresses
Try switching to their unfiltered servers 94.140.14.140 and 94.140.14.141, or for the test, the usual Google's (8.8.8.8, 8.8.4.4) or Cloudflare's (1.1.1.1, 1.0.0.1) servers.
YouTube of course would love to make the life of people using ads-filtering DNS servers harder. You'll need real browser extensions like uBlock Origin or apps like ReVanced to be able to block ads on YouTube effectively while still retaining the functionalities.
I already tried Google’s and CloudFlare’s DNS’s, but that didn’t help for some reason.
Can you try on your iPhone using a browser (as opposed to the YouTube app)?
This would confirm that the issue is "per network" and not "per client device".
For some reason I can’t reproduce the issue anymore even with my Mac. :sweat_smile: As soon as I connected to VPN and disconnected, restricted mode is off… On my iPhone, using Safari, it’s also off… Well, I guess this is kind of resolved without doing anything really.
