What might be the cause of the below attached image?
Somethings to note:
on iPhone, Nokia, Galaxy the suggestion will be displayed but not the actual film.
on windows, linux, the suggestion will take a very very long time to load but actual film will play right away.
thanks,
please can you tell me the trade mark of the router ?
this is a MTU issue …
x86 running routerboard os.
it all happen within the last few days without anything being modified in system configurations.
all other video hosting sites run normal but not youtube.com
peace
i meant in my question the end user router...
if you use a PPPoE server then try to change the MTU in end user router to 1462
if you use a DHCP server then try to change the MTU in end user router to 1492
manipulating mtu sizes had zero effect!
although setting browser’s network proxy will bring back youtube to normal operation!
i am starting to think it may be regional issue.
