we trying to set zero config solution on hotspot. situation is some laptop are being set static ip on their interface, is it possible to have zero config? no matter how what ip address are set on their laptop?
I read that three times and I am not sure I understand what you are trying to say.
Static IPs on clients work fine with Hotspots, if that’s the question. If it is not I either hope that someone else understands or that you can give more details.
Edit: on a fourth reading, maybe you mean Universal NAT. That enables clients with arbitrary IPs to work. Simply set an appropriate IP pool in the Hotspot server profile for that.
Yep, you’re talking about Universal NAT. Just configure an IP pool with valid addresses under “/ip pool” and associate it with the Hotspot Server Profile and you’re good to go.
My own problem right now is that i cannot log in with the usernames on my winbox.
it will bring hotspot fine but immediately i put in a username or password, it will not log in and the system will hang.
i will have to restart the system over again to be able to use it. the config is ok but i dont understand why it it so.
if i disable the hotspot. the systems will browse normally but as soon as i create hotspot and put in a username and password, the router will hang and i will have to restart. what can i do.
