zerotier 1.10.3 for router os 7.9beta4 in 7.8
Is possible use the plugin zerotier 1.10.3 for router os 7.9beta4 in 7.8?
My guess: no. If it is updated within 7.8, it would be with 7.8.1 or such.
Especially, since currently there seem to be breaking changes.
This question is so strange :smiley: :smiley:
If you need the changes in that version, just use that version. Why does the version number matter? It is just a number. You are afraid of “beta”, because unstable? WELLL Zerotier 1.10.3 is also unstable just the same :smiley:
It’s not such a dump question as you think.
I tried just that. Installing zerotier b9.4 but it’s not possible. In the log I see: System 9.4b is required to install zerotier 9.4b
Pure logic.
The way Mikrotik has chosen to handle their packages, they are made for a specific version of ROS.
They go hand in hand.
Want to install the zerotier package with 1.10.3 version in it ? Then install ROS 7.9b4 as well.
Easy, no ?
Zandhaas that is not what I was getting at.
I simply meant “if you are afraid of 7.9, you should also be afraid of packages it consists of”. Pure logic
