Zerotier behavior change in 7.3.1
I am now noticing in RouterOS 7.3.1 Zerotier is not “getting an IP” on the interface any longer.
For instance…
The site I am connecting to is 192.168.1.1/24
I have the hAP AC2 set in myzerotier to get 192.168.1.30/23
Since the update to 7.3.1… it does not show that IP address on the Zerotier interface.
Zerotier shows the hAP AC2 as online and I can REACH THE HAPAC2 at 192.168.1.1
I have another site with a RB3011 that doesn’t seem to want to connect to zerotier.
its status shows as Requesting… but I don’t see any traffic on that interface. or on port 9993 on the router.
allow-managed
Will get the IP address to show up… after you disable and reenable the instance.
