Zerotier performance on 4011
Getting about ~100Mbps throughput on between two 4011 devices.
Looks like a single CPU core is being used, and the load sits at near 100% on cpu0 when a bandwidth test is run from A to B.
Any plans to support multicore?
See answers here: https://discuss.zerotier.com/t/mikrotik-rb4011-zt-perf-benchmark-maxed-at-100mbits-sec/11610.
I’ve tried asking some related questions in this forum and never got any answer back… Folks at ZT forum are quite nice and understanding :slight_smile:
Agreed, most users on the zt forum are very nice and you can ask anything you want without being called a jerk if you happen to say the wrong thing.
Anyway, another very important factor is AES encryption using hardware offload. Without this, the CPUs will be loaded to 100% due to software encryption regardless of how many cores and threads there are.
I haven’t tested yet if hardware offloading for AES encryption is enabled with the new zt version v10.0.3 that comes with RoS 7.9rc.
The 4011 is a great router, but its performance is disappointing on v7 (CPU pegged on mine just downloading/routing, which never happened for me on v6). That, and it’s a weak ARM chip in the grand scheme of things. The 5009 is a major ARM revision is this regard overall. Without offloading, a cheap Celeron appliance will perform much better and do much more.
https://discuss.zerotier.com/t/mikrotik-ros7-zerotier-low-bandwidth/7626/3
@Larsa, I don’t think it is. I am using ZT in Mikrotik and haven’t noticed a difference in performance, but that might be also the fact that it is single threaded…
@Moba, agreed… It is unfortunate that we cannot squeeze a bit more of performance from RB4011 in this scenario. How I wished there was a version of the RB5009 with WiFi (and proper WiFi Wave2 for both nics).
