Zerotier setup help
Hi
I would like some guidance with Zerotier config. I want to use zerotier to connect my laptop to my home network while i’m not home. I looked in to the Zerotier package, but since it is only arm i can’t install it on my hEX PoE. The thing is that I have a CRS326-24G-2S+RM thats running on my network. Since it is a arm unit I had the idea to use it. The guides I found are focused on setup on the router. But I do not know how to set up my use case.
To take a very specific use case. In this video there is a demo with a NAS routed thru the Mikrotik router.
https://www.youtube.com/watch?v=60uIlyF8Z5s
I want to do the exact same thing with my setup. Any ideas?
