ZeroTier Trusted Paths On MikroTik [Help]
I’m running zerotier on my RB3011UiAS-RM and RB450Gx4 with RouterOS Ver. 7.7 with no firewall, mangle, and queue configuration, but i’m encountering issue with the throughput.
I tried bandwidth-test over zerotier vpn and only got 30 Mbps average throughput, really so disappointing.
And then I found that zerotier need high CPU to do encryption and authentication as being said in https://discuss.zerotier.com/t/mikrotik-ros7-zerotier-low-bandwidth/7626/2 and https://docs.zerotier.com/zerotier/manual/ and it’s true when i saw that 1 of 4 RB450Gx4 CPU is on 100% with just bandwidth-test only process is running.
So then I’m willing to by pass or skip the encryption and authentication by using Trusted Path feature in zerotier as being advised, and I’m aware to notice that it will take huge risk to ignore the security reason. But unfortunately, I didn’t see any configuration can be configured related to this feature in MikroTik.
So does anyone know how to configure this Zerotier Trusted Path in MikroTik?
Thank you.
