ZTE VM6200 USB (Mobley)
Has anyone been able to connect over USB to a ZTE VM6200 (aka: AT&T Mobley) LTE device?
I can connect my hap AC lite via a USB cable to the the Mobley. The hap sees the ZTE device. Reports it in the devices/usb section correctly. The problem is it never adds it as a LTE device.
I have tried the mikrotik being on first. I have tried the mobley being up before I turn on the mikrotik.
Any help appreciated.
Thanks min advance
Did you ever get this figured out? I’m considering doing the same thing.
Remember: you can only use LTE devices from the compatible devices list.
Plug in a device not on that list and it could work or it could not work, you are on your own.
