I have a Zywall 2 on ISP 2 with a dynamic IP and I have my Mikrotik at a different ISP on a fix IP. I would like to create a vpn connection between both but I am unable to set it up, lack of competences…
Can anyone help? I am willing to pay for the support as long as I get it working quite fast.
IPsec tunnels must be between two ends with static IPs.
With PPTP your client can have dynamic IP and add a static route for the LAN network on the other end to go through the PPTP tunnel.
I.E :
1 S dst-address=192.168.20.0/24 preferred-source=192.168.98.5 gateway=192.168.20.1 gateway-state=reachable distance=12 interface=VPN
Where 192.168.20.0/24 is the LAN you want to reach, 192.168.98.5 being the IP of your tunnel and 192.168.20.1 the IP of your Pear.
