Why is it that the first thing that pops up when you login is the "Quick" programming wizard tab?
Anyway to disable this, and have it go to the "Interface" tab instead.
We have employees that are not real technical that have to use the routers to access AP's and do maintenance on them.
Don't need a wizard to get started to wipe out existing programming on the router!
