Beone
Trainer
Trainer
FEATURE REQUEST: LED Dark-mode settings available on all devices
Thu Oct 27, 2016 10:09 am
This feature already exist for some devices; but it would be nice to be available on all devices.
One of the main reasons we seem to have our wifi devices being disconnected from the network is because late at night "they make too much light to be able to sleep" so end-users disconnect them.
jarda
Re: FEATURE REQUEST: LED Dark-mode settings available on all devices
Thu Oct 27, 2016 11:51 am
Black fix pen or tape is simple solution. To sleep with eyes closed is another...
But anyway, to be able to set led intensity value according to other values would be also beneficial.
Beone
Trainer
Trainer
Thu Sep 13, 2018 10:36 am
/system leds> settings set all-leds-off=after-1h
failure: This feature is not supported on this board!
But adding the 'dark-mode=after-1h' logic to below should be possible as you can always disable the leds manually, which is not what we want because we only want them to be disabled after 1h uptime (for installation verification purposes)
/system leds> print
Flags: X - disabled, * - default
 #    TYPE                     INTERFACE        LEDS
 0  * interface-activity       ether1-wan        eth1-led
 1  * interface-activity       ether2-master-local                                                         eth2-led
 2  * interface-activity       ether3-slave-local                                                          eth3-led
 3  * wireless-status          wlan1        wlan1-led
 4  * wireless-status          wlan2        wlan2-led
/system leds> set [find] disabled=y
normis
Thu Sep 13, 2018 1:32 pm
some devices have the led hard wired to the power, you can't control them in software.
we try to include software control in newer products though
llag
Thu Sep 13, 2018 10:14 pm
Is it possible to control the power-leds on the CRS317? They are way too bright.....
Users browsing this forum: anav, Aska and 224 guests
