Confirmed now - the routes
ARE in the routing table correctly, yet, a traceroute follows the
wrong path...
Border 02 router, which peers with the ASN via public peering:
> /ip route print detail where dst-address=a.b.71.0/24
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
0 ADb ;;; AS34307 - NL-IX Route Server
dst-address=a.b.71.0/24 gateway=c.d.116.103 gateway-status=c.d.116.103 reachable via VLAN7 - NL-IX Peering distance=20 scope=40 target-scope=10
bgp-as-path="34305" bgp-local-pref=3080 bgp-med=0 bgp-origin=igp bgp-communities=65000:3080 received-from=AS34307v4 - NL-IX Route Server 01 (NL-IX)
1 Db ;;; AS34307 - NL-IX Route Server
bgp-as-path="34305" bgp-local-pref=3080 bgp-med=0 bgp-origin=igp bgp-communities=65000:3080 received-from=AS34307v4 - NL-IX Route Server 02 (NL-IX)
2 Db ;;; AS34307 - AMS-IX Route Server
dst-address=a.b.71.0/24 gateway=80.249.209.174 gateway-status=80.249.209.174 reachable via VLAN1587 - AMS-IX Peering distance=20 scope=40 target-scope=10
bgp-as-path="34305" bgp-local-pref=3070 bgp-med=0 bgp-origin=igp bgp-communities=65000:3070 received-from=AS6777v4 - AMS-IX Route Server 01 (AMS-IX)
3 Db ;;; AS34307 - AMS-IX Route Server
bgp-as-path="34305" bgp-local-pref=3070 bgp-med=0 bgp-origin=igp bgp-communities=65000:3070 received-from=AS6777v4 - AMS-IX Route Server 02 (AMS-IX)
> /routing bgp advertisements print "AS2bbbb9v4 - iBGP, BR01" detail where prefix=a.b.71.0/24
peer="AS2bbbb9v4 - iBGP, BR01" prefix=a.b.71.0/24 nexthop=c.d.116.103 as-path="34305" origin=igp local-pref=3080 med=0 communities=65000:3080
So, we have received the route through our peering arrangements, we have 4 paths available. Yet, we only advertise 1 path to our Border 1 router (we should advertise at least 2 paths, as the preferences & communities are different)...
On Border 01, which peers directly with Border 02 (iBGP), and has a transit link (full table):
0 ADb dst-address=a.b.71.0/24 gateway=c.d.116.103 gateway-status=c.d.116.103 recursive via e.f.48.35 VLAN100 - Edge Network distance=200 scope=40 target-scope=30
bgp-as-path="34305" bgp-local-pref=3080 bgp-med=0 bgp-origin=igp bgp-communities=65000:3080 received-from=AS2bbbb9v4 - iBGP, BR02
1 Db ;;; AS49544 - Transit
dst-address=a.b.71.0/24 gateway=31.204.159.165 gateway-status=31.204.159.165 reachable via sfp-plus2 - Cable S03.R13.02 & 2622 distance=20 scope=40 target-scope=10
bgp-as-path="49544,34305" bgp-origin=igp bgp-communities=65000:3000 received-from=AS49544v4 - Transit
The ACTIVE route, is supposedly going via Border 02. A traceroute however:
traceroute to a.b.71.34 (a.b.71.34), 30 hops max, 60 byte packets
1 e.f.48.129 0.455 ms 0.646 ms 0.672 ms <- CORE router
2 e.f.48.34 0.223 ms 0.262 ms 0.310 ms <- BORDER 01 router
3 g.h.159.165 <- TRANSIT
Traffic is not being send Border 01, Border 02, Peering. It is instead going Border 01, TRANSIT. Which is NOT what the routing table on Border 01 indicates.
Refresh/Resend the peering sessions, and the problem resolves itself after the BGP tables are loaded a second time. Happens with IPv4 as well as IPv6 traffic.
EDIT: From the ROUTER ITSELF (i.e. Border 01 router) the traceroute is correct (i.e. Border 01 -> Border 02 -> Peering). From devices BEHIND Border 01, the traceroute is incorrect (Border 01 -> Transit).
Route Cache is disabled, and RP Filter = no (on both routers)
