shanecaznet
VLAN Trunk without knowing/cofiguring all VLANS
Mon Jul 30, 2018 3:16 pm
Hi There
I'm really struggling to work out how to implement the attached VLAN setup:
Essentially I'm need to take any VLANS i receive on one port on a CRS317 and send them to a CCR1009 and send them all out a seperate port. I realise this is Q-in-Q which I can use, however, I dont always know which VLANs I may or may not receive.
I need to just be able to accept ANY VLAN on CRS317 SFP-SFPPLUS2, send it across to CCR1009 and out ETHER1 without manually configuring each one.
Any advice would be great.
Please see the pic attached.
Jotne
Re: VLAN Trunk without knowing/cofiguring all VLANS
Mon Jul 30, 2018 3:29 pm
I would like to know if there is a way to do this as well.
On Cisco you configure the port as trunk. It will then send all vlan over the port.
Here is an example:
interface TenGigabitEthernet1/1/3
 switchport mode trunk
 device-tracking attach-policy trunk
 ip dhcp snooping trust
end
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
shanecaznet
Mon Jul 30, 2018 3:37 pm
That is EXACTLY what we're looking to achieve. Is this just a Cisco thing?
end
nkourtzis
Fri Aug 03, 2018 4:01 pm
Bridge --> VLAN supports VLAN ranges (e.g. 30-1024)... ;-)
Passionate about networks
Enthusiastic about Mikrotik
MTCNA | MTCRE | MTCINE
No trees were killed to send this message,
but a large number of electrons were terribly inconvenienced.
expert
Fri Aug 03, 2018 4:15 pm
Can be the same be achieved on CRS1xx/2xx switches (VLANs configured on switch chip)?
Deantwo
Fri Aug 10, 2018 3:42 pm
Is CRS317 SFP-SFPPLUS1 and CRS317 SFP-SFPPLUS2 bridged together? Is CCR1009 SFP-SFPPLUS1 and CCR1009 ETHER1 bridged together?
If not then, talking about VLANs makes no sense. You only create VLAN trunks between two switches or between a router and a switch, but never between two routers.
What you need to do is route the traffic over the linknet.
It will help if you show an export of your interface and IP-address configs.
/interface export
/ip address export
I wish my FTP was FTL.
Users browsing this forum: No registered users and 7 guests
