uumar
block p2p on router os version 6.4
Wed Dec 05, 2018 4:01 pm
hello
how do i block p2p traffic on router os 6.4?
sebastia
Re: block p2p on router os version 6.4
Thu Dec 06, 2018 1:55 am
Hi
You could try with Layer7 matching patterns to mark connections as "p2p" based on the first (usually) 2k of data in connection, and then in second step block connections with that mark.
There are some patterns to be found on line.
Steveocee
Forum Veteran
Forum Veteran
Thu Dec 06, 2018 12:27 pm
Very difficult in general now as most P2P uses encryption.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
vineethp7
Thu Dec 06, 2018 9:11 pm
Hope they integrate IDS/IPS feature in RouterOS in v7.
Steveocee
Forum Veteran
Forum Veteran
Fri Dec 07, 2018 2:09 pm
I like your optimism.
vineethp7
Sat Dec 08, 2018 7:02 pm
I am planning to buy RB4011 which has powerful hardware and is kind of expensive. So, I would expect these type of features.
Juniper/Ubiquiti have DPI integrated into their routers.
kakaxa
Sat Dec 08, 2018 8:38 pm
hello
https://www.mansooryousaf.com/blogs/blo ... rsion-6-41
strods
Sat Dec 08, 2018 8:45 pm
You should upgrade your router first. v6.4 is five years old and is vulnerable for known exploits that can be used in order to hack your routers.
Users browsing this forum: EvgeniyV and 8 guests
