Colleen495
How to send login credentials to Mikrotik from android application
Wed Mar 06, 2019 12:33 pm
I want to send Login credentials to Mikrotik to authenticate user from android application myprepaidcenter
I have created a radius client for android application to authenticate user its working fine. but now what i want is that to send request to the mikrotik instead direct hitting the RADIUS server and then mikrotik will send data to radius server and and send response of the RADIUS server to the user.
So please tell where to find the API for this.
Chupaka
Re: How to send login credentials to Mikrotik from android application
Fri Mar 08, 2019 9:26 pm
What credentials? Do you use Hotspot for authentication?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
teddyrock
Wed May 22, 2019 3:35 pm
Then hit the RADIUS button in the main menu to create a new Radius record: specify radius server IP and password (and the kind of service you want to authenticate).
I'd like to post an image but i don't have enough reputation to do that.
You won't need any API since Mikrotik will intercept and forward radius requests, sending back to your client the authentication acknowledgement.
Users browsing this forum: No registered users and 127 guests
