roe1974
R11e-LTE LTE upgrade ... over OVPN Tunnel ?
Mon May 13, 2019 7:03 pm
I have a RB4011 (home) and a LT-Ap (garage) connect through a OVPN Tunnel
can i perform the LTE Module upgrade "interface lte firmware-upgrade lte1 upgrade=yes" during the Tunnel (over LTE) is established ?
Or have i to go down to the garage (WLAN) ?
thx for info
Richard
eworm
Re: R11e-LTE LTE upgrade ... over OVPN Tunnel ?
Mon May 13, 2019 11:55 pm
Generally you need a connection to your device while the upgrade is in progress, but the upgrade breaks connection.
But this may help: unattended-lte-firmware-upgrade
Just copy'n'paste the code into your device's terminal.
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
roe1974
Tue May 14, 2019 5:26 pm
works like a charm !!!!
thx Chris !!!!
greetings, Richard
Users browsing this forum: No registered users and 7 guests
