thadrumr
Can't SSH from CHR Version 7.0 Beta 3
Thu Oct 24, 2019 5:10 pm
I am unable to SSH from my CHR running v7.0 Beta 3. I upgraded from version 6.46beta55 using the file https://download.mikrotik.com/routeros/ ... 0beta3.npk. Below is my SSH config the rest of my config is quite long but I can attach if necessary.
/ip ssh
set forwarding-enabled=both strong-crypto=yes
Here is the error when I try and ssh to my rasberry pi
[admin@MikroTik] > /sys ssh user=pi 10.22.87.20
Server returned smaller prime for DH exchange than requested: 3
mrz
Re: Can't SSH from CHR Version 7.0 Beta 3
Mon Nov 04, 2019 4:03 pm
What is the remote device? If it is RouterOS does it have strong-crypto enabled too? If it is not ROS devices, does it have enabled all needed algorithms that is used by the ssh client when strong crypto is enabled?
thadrumr
Fri Nov 08, 2019 11:28 pm
I have tried to SSH to another mikrotik deivce that has strong crypto enabled. I have also tried to SSH to my Proxmox host running version 6 which has the up to date crypto and hash enabled. I get the same result no matter what I try and SSH to.
mrz
Mon Nov 11, 2019 9:24 am
Problem will be solved in next beta.
Users browsing this forum: No registered users and 12 guests
