MUM Europe 2020
woqup5s0wf
[ROS 7.0b3] 64-bit support on x86
Wed Nov 13, 2019 8:36 pm
Dear Mikrotik team,
it seems you have enabled 64-bit support on the x86 platform. The command /system/hardware/print shows:
multi-cpu: yes
allow-x86-64: no
If you enable 64-bit support and reboot it correctly enables it, see the memory:
                   uptime: 2m20s
                  version: 7.0beta3 (development)
               build-time: Oct/22/2019 09:34:17
              free-memory: 3860.7MiB
             total-memory: 3904.0MiB
                      cpu: Intel(R)
                cpu-count: 2
            cpu-frequency: 1166MHz
                 cpu-load: 0%
           free-hdd-space: 110.8GiB
          total-hdd-space: 110.8GiB
  write-sect-since-reboot: 424
         write-sect-total: 424
        architecture-name: x86_64
               board-name: x86
                 platform: MikroTik
But if you do that the wireless support gets disabled, so I guess it isn't actually supported. Here you said it shouldn't be possible to enable it on the x86 platform.
Thanks!
PCT2015
Re: [ROS 7.0b3] 64-bit support on x86
Sat Nov 30, 2019 4:25 pm
Dear Mikrotik team,
multi-cpu: yes
allow-x86-64: no
                   uptime: 2m20s
                      cpu: Intel(R)
                cpu-count: 2
                 cpu-load: 0%
               board-name: x86
                 platform: MikroTik
Thanks!
Here is me screen for x86 whit activate 64 bits
Users browsing this forum: msatter and 9 guests
