MUM Europe 2020
iwikus
CHR 7.0 beta4 vrrp kernel panic
Sun Jan 12, 2020 2:21 pm
I am playing with CHR 7.0 beta4 running in ESXi. Creating vrrp on bridge port cause router reboot when vrrp becomes master:
jan/12/2020 11:51:46 system,error,critical router was rebooted without proper shutdown
jan/12/2020 11:51:46 system,error,critical kernel failure in previous boot
Steps to reproduce
  • create bridge port and add ether1 into it
  • create vrrp interface on bridge port
  • add IP address to vrrp interface to enable it
When vrrp becomes master router will reboot. When you set vrrp priority to 255 you have endless reboot loop.
Configuration export (edited)
[admin@VRT] > /export hide-sensitive
# jan/12/2020 11:54:21 by RouterOS 7.0beta4
# software id =
add igmp-snooping=yes name=bridge-lan protocol-mode=none
set [ find default-name=ether1 ] disable-running-check=no
/interface vrrp
add disabled=yes interface=bridge-lan name=vrrp-lan
add bridge=bridge-lan interface=ether1
/ipv6 settings
set accept-router-advertisements=yes
add address=10.0.0.200/24 interface=bridge-lan network=10.0.0.0
add address=10.0.0.202/24 interface=vrrp-lan network=10.0.0.0
sid5632
Re: CHR 7.0 beta4 vrrp kernel panic
Sun Jan 12, 2020 5:24 pm
Address on VRRP interface should be a /32 not a /24.
iwikus
Mon Jan 13, 2020 11:35 am
Thanks, it seems work with /32. Anyway, other boxes with 6.46 does not crash with mask /24 on vrrp interface
sid5632
Mon Jan 13, 2020 5:17 pm
Agreed, but you need to report it to MikroTik support.
ChrisCCC
Wed Jan 15, 2020 11:58 am
Why? This isn't really a support issue; it's a v7 beta bug, which is precisely the purpose of this forum section.
sid5632
Thu Jan 16, 2020 12:21 am
Because that's what it says here:
https://forum.mikrotik.com/viewtopic.php?f=1&t=152006
Send them an email referencing this thread. Not hard is it?
ChrisCCC
Fri Jan 17, 2020 6:37 pm
This is neither a v6 bug, nor a security vulnerability, though.
Users browsing this forum: No registered users and 12 guests
