andrewe02000
Feature Request - BGP RPKI
Wed Jan 22, 2020 9:56 pm
Please add BGP RPKI Filtering.
https://www.arin.net/resources/manage/rpki/
guipoletto
Re: Feature Request - BGP RPKI
Thu Jan 23, 2020 6:19 am
Important.
Really excited to see some BGP development in V7
schadom
Thu Jan 23, 2020 8:43 pm
+1 Open-Source RPKI/RTR implementation in C available over at http://rpki.realmv6.org/
alfredo
Sun Jan 26, 2020 4:15 pm
RPKI would be awesome. But I would be more than happy with decent BGP performance, including route ingestion and interactive lookup.
IPANetEngineer
Trainer
Trainer
Sun Jan 26, 2020 5:30 pm
It's only a matter of time before RPKI becomes a standard for most IP transit peerings. This is a feature we desperately need to keep using MikroTik routers to peer into the DFZ.
BGP FlowSpec is also important for DDoS mitigation.
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
schadom
Mon Jan 27, 2020 8:22 pm
By replacing their custom routing implementation (Quagga fork or whatever) with something more recent like the frrouting protocol suite they could probably do both... https://github.com/FRRouting/frr
mrz
Tue Jan 28, 2020 12:03 pm
ROS didn't use Quagga and no there will not be FRR.
patrick7
Tue Jan 28, 2020 12:46 pm
There will not even be a fixed ROS BGP implementation for the next decades.
Cha0s
Tue Jan 28, 2020 3:22 pm
ROS didn't use Quagga.
This is not true.
Back in 2.x days ROS was using quagga. And a rather buggy version at that.
But yes, the current implementation AFAIK is not based on quagga.
andrewe02000
Wed Feb 12, 2020 11:03 pm
What about RPKI? Is it being discussed at least?
andrewe02000
Wed Feb 12, 2020 11:35 pm
+1 for BGP Flow Spec as well.
schadom
Sun Mar 15, 2020 3:41 am
Any news on RPKI Route Origin Validation on ROS? As written above, there's an open source C library available under MIT license... http://rpki.realmv6.org/
IPANetEngineer
Trainer
Trainer
Sun Mar 15, 2020 3:08 pm
Yes, please add this to the list. More and more people are asking for it.
omidkosari
Trainer
Trainer
Mon Mar 16, 2020 2:37 pm
Yes +1
It is important feature
MTCNA , MTCRE, MTCWE, Mikrotik Certified Trainer
alfredo
Tue Mar 17, 2020 9:50 am
+1 for:
  • Decent ingestion performance
  • Decent lookup performance
  • RPKI
In this order. Much as I want RPKI, I feel that without significant improvements in basic performance, ROS is out of the border.
markwien
Thu Apr 02, 2020 11:52 am
RPKI Origin Validation
Is a urgent must have - otherwise I need to switch to some alternative to keep my perring links up and running ...
chubbs596
Tue Apr 07, 2020 12:26 pm
+1 for RPKI and Flowspec
mrz
Thu Apr 09, 2020 11:28 am
Currently work in progress
vntnet
Thu Apr 09, 2020 2:32 pm
Hi mrz,
Do you have an estimate of the release date for BGP in the development channel?
Even if it's full of bugs or without RPKI ... but so that we have an idea of performance.
Several of my clients have asked me for alternatives to Mikrotik because of the RouterOS 6's poor performance in learning routes, in particular.
Thanks in advance,
Regards,
Alexandre
andrewe02000
Thu Apr 09, 2020 10:39 pm
Thank you @mrz
I am super excited to start playing with whatever you release and give feedback for BGP. I cannot wait to be able to finally share full routing tables between my edge routers to have a truly blended table of all connections let alone to start filtering out all the BGP hijacks with RPKI.
https://photos.app.goo.gl/UG4DihVvKxMqZ6mk6
schadom
Fri Apr 17, 2020 8:08 pm
Hi mrz,
Thanks in advance,
Regards,
Alexandre
No software update will ever fix this. The architecture (tile-gx) used in CCR-series was simply not designed for BGP routing.
vntnet
Fri Apr 17, 2020 8:30 pm
Hi mrz,
Thanks in advance,
Regards,
Alexandre
I'm not talking specifically about CCRs.
But x86 for example ...
I currently have x86 in production with several customers. And it would be good that at last I could take advantage of the 16 cores at 3.2 GHz and the GB of RAM installed in case mikrotik decides to accept more.
Going to CHR is not a very good solution in my opinion in terms of performance since there will always be a loss of performance due to virtualization.
It would be nice if Mikrotik adapts its 64-bit version to the new ranges of physical servers (released in recent years) or if they present us with a series of routers with correct performance!
Paternot
Forum Veteran
Forum Veteran
Fri Apr 17, 2020 9:42 pm
Take a look at this video.
Yes, it is real - we already have confirmation from Mikrotik itself.
https://www.youtube.com/watch?v=NbfKplzda7I
omidkosari
Trainer
Trainer
Sat Apr 18, 2020 9:49 am
Time passes quickly.
https://isbgpsafeyet.com/
Users browsing this forum: No registered users and 7 guests
