mladenciric
OSPF problems
Thu May 07, 2020 2:39 pm
I just test ROSv7.0beta5 and found that OSPF wont work correctly.
First, this section is slightly changed and configuration steps was different for e.g. Network tab was missing.
I found this problem first between MT and Cisco. neighbor relationship was not established. when i change MT device with ROSv6 neighbor relationship was established.
I was interested to find what is the problem and test ospf connection between MTrosV7---MTrosV6 : neighbor relationship was not established
And last i was try ospf connection between MTrosV7---MTrosV7: it look like neighbor relationship is establish but neighbor tab is empty, neighbor status display instance unknown and area unknown.
OSPF Instance list:
OSPF Interfaces list:
OSPF Interface statuses:
OSPF Neighbors list:
OSPF Neighbor Statuses:
OSPF LSA list :
In the ip route list the ospf routes are DIo - Dynamic Invalid OSPF like on the picture below :
mafiosa
Re: OSPF problems
Fri Jul 03, 2020 6:46 pm
I am facing same issues with ROS7 beta8. Anyone can help? Followed the documentation throughly
mafiosa
Re: OSPF problems
Sun Jul 12, 2020 6:41 pm
anyone else who can confirm the above issue?
mducharme
Trainer
Trainer
Re: OSPF problems
Sun Jul 12, 2020 11:21 pm
Yes, I had encountered this above issue. I figure it is actually caused by the missing "gateway" setting. IPv6 BGP has the same issue - missing "gateway" causes the route to be invalid, since how can a route have no gateway?
mrz
Re: OSPF problems
Mon Jul 13, 2020 9:51 am
Please contact support with attached supout files. And at the moment do not use winbox for any tasks related to routing protocols.
Users browsing this forum: No registered users and 10 guests
