userid
LTE APN with fix IP
Wed May 27, 2020 10:09 am
Howdy,
just got my Chateau LTE12 and it came with latest beta preinstalled v7.0beta6. Seems like this release is not in public channels yet, it's OK but, I have just configured it to use with Telia LT fixed IP APN, and I'am still getting dynamic IP. It works as expected with same SIM and APN config on Huawei router. May be there some known issues with beta release? Should I downgrade to stable instead? Which debug information should I provide?
Thx.
SiB
Re: LTE APN with fix IP
Wed May 27, 2020 2:47 pm
Please read a documentation, general about lte: https://wiki.mikrotik.com/wiki/Manual:Interface/LTE
Please activate log-s:
/system logging add topics=lte
In logs try search what APN is used in reality... I know that APN can be not used, or used after usb power-reset, or just works only 1x after reboot... some strange behaviors with APN at ros7b6.
I not have Chateau then cannot test the ros7b6, at public7b5 I have more problems and just wait for new betas.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
At vacation until 15.jan.2021
mada3k
Wed May 27, 2020 6:24 pm
Sounds a bit strange that it was shipped with beta software. Sure it hasn't been used before?
Manages some CCR's, RB750Gr3, RB922 and wAP's
SiB
Wed May 27, 2020 6:43 pm
Chateau is with ROS7 only, the official release is ROS7beta5 but at Chateau is ROS7beta6.
MikroTik never publish release candidate or stable ros7 and all person who buy Chateau receive ros7b6.
userid
Thu May 28, 2020 8:22 am
Thanks for the reply. After digging through logs I see this:
08:12:54 lte,debug lte1 mbim: lte status: attached apn: omnitel
08:12:54 lte,debug lte1 mbim: apn: omnitel user: omni
seems like You right, and LTE apn is ignored, so then default is taken from BS?
SiB
Thu May 28, 2020 10:42 am
probably.
you can try few actions to check they behhavior
* usb power-reset
* at+reset or proper for that modem
* re-enable lte1
* reboot
maybe apn is used after one of that action and you can found some schema to fix it.
sknx
Tue Jun 02, 2020 11:47 pm
I had the same problem. Turns out there is an option for the APN profile "use-network-apn", which is only accessible via CLI and default yes.
Enabled, it ignores your APN settings and uses the APN provided by the network. Set this to no and it starts using your configured APN.
SiB
Re: LTE APN with fix IP  [SOLVED]
Thu Jun 04, 2020 2:58 pm
True, I just have access to one of Chateau and grab all possibility options.
[admin@MikroTik] > interface/lte apn/set
add-default-route       ipv6-interface         passthrough-subnet-selection
apn                     name                   password
authentication          numbers                use-network-apn
default-route-distance  passthrough-interface  use-peer-dns
ip-type                 passthrough-mac        user
[admin@MikroTik] > interface/lte apn/set use-network-apn=
no  yes
[admin@MikroTik] > interface/lte apn/set passthrough-subnet-selection=
auto  p2p
[admin@MikroTik] > interface/lte apn/set ip-type=ipv
ipv4  ipv4-ipv6  ipv6
userid
Wed Sep 30, 2020 9:57 pm
This solves the issue. Thx SIB
apn                     name                   password
no  yes
auto  p2p
ipv4  ipv4-ipv6  ipv6
tonie16
Tue Nov 10, 2020 12:37 pm
apn                     name                   password
no  yes
auto  p2p
ipv4  ipv4-ipv6  ipv6
Thank you SIB, this helped me alot.
sapphire112
Re: LTE APN avec IP fixe
Sun Nov 15, 2020 7:39 pm
good evening I have Château LTE12 which was in beta v7.0beta6 which works very well in my country but since then I went to beta 7.1beta 2 its not working poorly lost connection lte that I did not have before, I would like to go back to the old one beta but not found on the net someone can help me find this firmware thank you
SiB
Mon Nov 16, 2020 12:09 am
Château LTE12 which was in beta v7.0beta6... I would like to go back to the old one beta
Go to https://mikrotik.com/download
CTRL + F for searching: Chateau and you discover it at ARM family
RMouseB and copy URL
https://download.mikrotik.com/routeros/7.1beta2/routeros-7.1beta2-arm.npk
and edit it to:
https://download.mikrotik.com/routeros/ ... a5-arm.npk <- WORK ✔️
https://download.mikrotik.com/routeros/ ... a6-arm.npk <- NOT WORK
https://download.mikrotik.com/routeros/ ... a7-arm.npk <- WORK ✔️
https://download.mikrotik.com/routeros/ ... a8-arm.npk <- WORK ✔️
redhatperl
Tue Nov 17, 2020 6:57 am
Thanks SiB. I am wondering why v7.0beta6 is not available? Does anyone have the beta6 npk? I tried searching all over the web and even mailed on support.
SiB
Tue Nov 17, 2020 11:50 am
We not know, ask directly support@mikrotik.com or https://mikrotik.com/support :)
Users browsing this forum: No registered users and 14 guests
