Louis2
Multicast in a VLAN based network. How to handle that !!??
Sat Jun 06, 2020 2:41 pm
I need multicast to stream music form my server towards my PC-LAN and Guest Network. To get that working you need applications like PIM and/or IGMP-proxy. So I installed the multicast package.
Than I opend routing/pim to define the configuration. First thing there to define the involved interfaces ....
Up to my surprise :shock: , the only interfaces I could select in the menu, where the physical interfaces. However networks are build using VLAN's in the majority of situations, so that does not work, I think! :( :(
So, the big question is, how to setup multicast in a VLAN-oriented network ???
Is it possible at all using actual routeros multicast package !!??
Sincerely,
Louis
Devliner
Re: Multicast in a VLAN based network. How to handle that !!??
Mon Aug 10, 2020 1:41 pm
I have installed in other locations as well, and it was successful
Users browsing this forum: No registered users and 26 guests
