nissandata
cAPac and wAPac bricked?
Thu Jun 25, 2020 5:37 pm
Tried to upgrade to rOS 7 Beta8.
RB4011iGS+
CRS125-24G-1S
RBwAP2nDr2
RB962UiGS-5HacT2HnT
RBcAPGo-5acD2nD
RBwAPG-5HacT2HnD
The wAP AC and the cAP AC both became unreachable after upgrade.
I managed to reach the wAP via netinstall after multiple boots, installed ros7beta8 succesfully and it also booted up. But after next reboot it was unreachable again. Never got it to show up in netinstall again.
On both wAP and cAP ethernet LED blinks and network port auto-negotiates. But cannot reach it from winbox nor netinstall. LED behaves as expected when using the reset button, tried all reset-button function several times.
Are these devices doomed, or is there anything else I can try?
Hominidae
Re: cAPac and wAPac bricked?
Fri Jun 26, 2020 9:49 am
...did you try the method using the on-board backup RouterBOOT firmware? -> https://wiki.mikrotik.com/wiki/Manual:RouterBOOT
nissandata
Fri Jun 26, 2020 12:09 pm
Yes, did try this to.
To be clear, holding reset button during start (when connecting power) and releaseing it after 1-4 seconds, before the LED light starts flashing
Hominidae
Fri Jun 26, 2020 11:04 pm
not quite sure what you are saying you did....I'd gather this would reset the config of the current (possibly not working firmware) only.
You*ll have to activate the (old), backup firmware that is also present in the board,
Read the extra "Note" below the instructions.
RouterBOARD reset button
RouterBOOT reset button has three functions:
Hold this button during boot time until LED light starts flashing, release the button to reset RouterOS configuration (total 5 seconds)
Keep holding for 5 more seconds, LED turns solid, release now to turn on CAPs mode (total 10 seconds)
Or Keep holding the button for 5 more seconds until until LED turns off, then release it to make the RouterBOARD look for Netinstall servers (total 15 seconds)
Note: If you hold the button before applying power, backup RouterBOOT will be used in addition to all the above actions. To do the above actions without loading the backup loader, push the button right after applying power to the device.
...so, whichever variant you choose...press - and keep holding down - the reset-button before applying the power to the device.
I had a similar situation once, when having my first encounter with the CAP-ac...did struggle as well, and had to try several times.
Maybe using the RooterBoot method, together with netinstall option is the safest one to make sure a stable version will end up on the device.
Users browsing this forum: bpwl and 10 guests
