nemoforum
v7.1beta2 | Bridge VLAN Filtering: unable to get IP via DHCP on VLAN
Sat Aug 22, 2020 7:39 pm
Dear Mikrotik!
I reported this bug on v7.0beta8 on 10/06/20, you confirmed it on 18/06/20 and wrote
we look forward to fixing this on upcoming RouterOS versions, unfortunately
See SUP-5149.
v7.0beta5 - no issue
v7.0beta8 - the issue appears
v7.1beta1 - not fixed
v7.1beta2 - not fixed
Is it so huge bug?
I kindly ask you to pay attention to it.
add name=br protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-wan
/interface vlan
add interface=br name=vlan10-wan vlan-id=10
add bridge=br interface=wlan24
add bridge=br interface=wlan50
add bridge=br interface=ether2
add bridge=br interface=ether3
add bridge=br interface=ether4
add bridge=br interface=ether5
add bridge=br interface=wlan24.1
add bridge=br interface=wlan50.1
add bridge=br interface=ether1-wan pvid=10
/interface bridge vlan
add bridge=br tagged=ether2,br untagged=ether1-wan vlan-ids=10
/ip dhcp-client
add disabled=no interface=vlan10-wan use-peer-dns=no use-peer-ntp=no
kivimart
Re: v7.1beta2 | Bridge VLAN Filtering: unable to get IP via DHCP on VLAN
Sun Aug 23, 2020 9:09 am
The same here.
Srv02
Wed Sep 16, 2020 11:51 pm
I also ran into the same error ... dhcp server „offers“ IPs, but no successful „bound“.
ROS v7.1beta2 on a hEX PoE
tuxtlequino
Thu Oct 22, 2020 7:36 pm
I have this error too. Has anybody solved this issue or has a work around?
tuxtlequino
Sat Dec 05, 2020 11:50 pm
Nemo, have you tried the new beta and seen the same issue? Not sure if I want to try the new beta till the problem is solved.
memelchenkov
Sun Dec 06, 2020 8:28 pm
There were DHCP issues in 7.1b2, and they were fixed in 7.1b3. Can't say regarding subj issue, though.
CTSsean
Wed Dec 09, 2020 1:05 am
Still broken on my HAP AC2 on 7.1beta3.
Users browsing this forum: No registered users and 12 guests
