neutronlaser
Add sFlow
Wed Aug 26, 2020 7:11 pm
Add sFlow
jvanhambelgium
Forum Veteran
Forum Veteran
Re: Add sFlow
Wed Aug 26, 2020 7:50 pm
Add sFlow
Perhaps they should start to FIX the broken IPFIX implementation to start with...
Chupaka
Re: Add sFlow
Wed Aug 26, 2020 10:14 pm
Is it broken in v7 only?
jvanhambelgium
Forum Veteran
Forum Veteran
Re: Add sFlow
Wed Aug 26, 2020 10:42 pm
Nope, also in 6.4x
I've opened a case for that long ago ... latest reply on 21/07.
Let's hope the release-notes from any future 6.x release contain the fix. This is so very trivial. Probably never tested or something after coding it....how else could you miss this one.
Thank you for contacting MikroTik Support. And sorry for the late reply.
I have forwarded this information to developers and we'll look into it. Likely flowStartMilliseconds and flowEndMilliseconds should be added and used here.
Chupaka
Re: Add sFlow
Wed Aug 26, 2020 10:58 pm
So what's actually broken?..
jvanhambelgium
Forum Veteran
Forum Veteran
Re: Add sFlow
Wed Aug 26, 2020 11:48 pm
Well ... flowStartMilliseconds and flowEndMilliseconds fields in the template are not correctly embedded, putting 1970-01-01 00:00:00 (Epoch) in there. So basically useless.
I've tried some netflow tooling and they cannot really work with that IPFIX data like this. It should be embedded correctly.
As per spec :
(field 152) flowStartMilliseconds dateTimeMilliseconds default current The absolute timestamp of the first packet of this Flow.
(field 153) flowEndMilliseconds dateTimeMilliseconds default current The absolute timestamp of the last packet of this Flow.
nz_monkey
Re: Add sFlow
Thu Aug 27, 2020 7:23 am
This IPFIX issue was fixed YEARS ago. Maybe there was a regression!
Users browsing this forum: No registered users and 58 guests
