dakobg
Wireguard peers endpoint port
Wed Aug 26, 2020 10:56 pm
Any idea how I can add port for peer endpoint ip address ? Look like only ip address is allowed aka (1.1.1.1 vs 1.1.1.1:51821)
Or I miss something ?
dakobg
Re: Wireguard peers endpoint port
Thu Aug 27, 2020 12:00 am
Maybe is not important but is good to have
Sob
Thu Aug 27, 2020 12:36 am
It's currently not possible to enter it in Winbox. Until it's fixed, you can use command line, it's possible there.
m0x35
Thu Aug 27, 2020 12:42 am
You can specify port via /interface wireguard edit
It will even show you some sort of mask if endpoint is not set yet.
Paternot
Forum Veteran
Forum Veteran
Thu Aug 27, 2020 12:46 am
Webfig doesn't work too. I tried to create a tunnel with WebFig, and it didn't work (it uses the zero port - 10.10.10.10:0 - and You can't change it).
At this moment, Wireguard should be used through the CLI.
Users browsing this forum: No registered users and 23 guests
