gstubbe
Unable to route on my local breakout 7.1beta2
Wed Sep 16, 2020 11:27 am
I'm having issues with routerOS 7 beta. It was working fine for a few weeks but a reboot of the router seems to have broken something. This also happened to other hardware and I just swapped the hardware and it was working again, until now.
RouterOS: 7.1beta2
model: 750GL
firmware-type: ar7240
current-firmware: 7.1beta2
I can connect to the router on a L2 basis (mac connect). But I'm unable to ping it or route over it even though I receive dhcp from the device.
Ip & Route on laptop:
$ ip route
default via 192.168.33.1 dev enp0s25 proto dhcp metric 20100
192.168.33.0/28 dev enp0s25 proto kernel scope link src 192.168.33.9 metric 100
$ ip a
2: enp0s25: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 54:ee:75:2a:ba:92 brd ff:ff:ff:ff:ff:ff
    inet 192.168.33.9/28 brd 192.168.33.15 scope global dynamic noprefixroute enp0s25
       valid_lft 3303sec preferred_lft 3303sec
    inet6 fe80::57d3:5a3f:a87b:3517/64 scope link noprefixroute
       valid_lft forever preferred_lft forever
ping from laptop to routerboard:
$ ping 192.168.33.1
PING 192.168.33.1 (192.168.33.1) 56(84) bytes of data.
--- 192.168.33.1 ping statistics ---
2 packets transmitted, 0 received, 100% packet loss, time 1020ms
ping from routerboard to itself & dhcp client
[admin@CR] > ping 192.168.33.1
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 192.168.33.1                               56  64 0ms
    1 192.168.33.1                               56  64 0ms
    sent=2 received=2 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
[admin@CR] > ping 192.168.33.9
    0                                                         22 (Invalid argument)
    1                                                         22 (Invalid argument)
    sent=2 received=0 packet-loss=100%
I'm not sure why the device is doing this.
Below my export of config
# sep/16/2020 10:23:42 by RouterOS 7.1beta2
# software id = ZN49-6NQS
# model = 750GL
# serial number = 467A04C1AED6
add mtu=1500 name=BRIDGE_UP protocol-mode=none vlan-filtering=yes
/interface l2tp-client
add connect-to=ip max-mru=1500 max-mtu=1500 name=asgard user=ironman
/interface vlan
add interface=BRIDGE_UP name=VLAN2_LB vlan-id=2
add interface=BRIDGE_UP name=VLAN33_TEST vlan-id=33
add interface=BRIDGE_UP name=VLAN201_OPS vlan-id=201
add interface=BRIDGE_UP name=VLAN202_RND vlan-id=202
add name=WAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
add name=dhcp_pool0 ranges=192.168.33.2-192.168.33.14
add address-pool=dhcp_pool0 disabled=no interface=VLAN2_LB lease-time=1h name=dhcp1
/ip vrf
add list=all name=main
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add bridge=BRIDGE_UP interface=ether1
/interface bridge vlan
add bridge=BRIDGE_UP tagged=BRIDGE_UP,ether1 vlan-ids=2
add bridge=BRIDGE_UP tagged=BRIDGE_UP,ether1 vlan-ids=201
add bridge=BRIDGE_UP tagged=BRIDGE_UP,ether1 vlan-ids=33
add bridge=BRIDGE_UP tagged=BRIDGE_UP,ether1 vlan-ids=202
add interface=VLAN201_OPS list=WAN
add address=192.168.33.1/28 interface=VLAN2_LB network=192.168.33.0
/ip dhcp-client
add add-default-route=no disabled=no interface=VLAN201_OPS
add add-default-route=no disabled=no interface=VLAN33_TEST use-peer-dns=no use-peer-ntp=no
add address=192.168.33.0/28 dns-server=10.10.8.21 gateway=192.168.33.1
set servers=10.10.8.21
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=10.201.0.1 pref-src="" scope=30 target-scope=10 type=unicast
/system clock
set time-zone-name=Europe/Brussels
/system identity
set name=CR
sknx
Re: Unable to route on my local breakout 7.1beta2
Fri Sep 18, 2020 12:19 pm
I'm having the same issue with my Chateau:
Everything was working fine for a day after upgrading to 7.1beta2 (from the chateau default 7.0beta6), but after some ssh issues (same as this thread), I rebooted the Chateau and it refuses to route since.
My PC is connected to a hap ac (with stable firmware), which is connected to the lan-bridge of the Chateau. After putting the Chateau on the same bridge with the PC, everything was working. Directly connecting my PC to the chateau was working too.
But routing via the hap ac to the Chateau is not working.
As a workaround I downgraded to 7.0beta8 for now and everything is fine, except the SSH issue.
dekana
Sun Sep 20, 2020 1:40 pm
A temporary workaround this issue is to disable the primary route after boot and then re-enable it.
I found this fixes it for me, until the next boot of course.
gstubbe
Tue Sep 29, 2020 10:09 am
This doesn't seem to work. Routing to the internet is not the issue, routing to the gateway itself is atm the issue, that is the connected route.
gstubbe
Tue Sep 29, 2020 12:31 pm
You did put me on the right track, disabling & enabling the ip address on the VLAN interface actually fixed it.
leopardus2
Fri Dec 04, 2020 1:50 pm
having the same problem on my RB3011
leopardus2
Tue Dec 15, 2020 1:00 pm
Anyone knows if beta3 solves this? The changelogs are useless...
Users browsing this forum: No registered users and 16 guests
