plisken
After installing ROS 7.1beta2
Sun Sep 20, 2020 12:27 pm
I installed ROS 7.1beta2 on two RB750Gr3
If i change the name of ether2 ore another ethernet interface the router reboot automatically.
System log
System, error critical: router rebooted because some critical program crashed.
Znevna
Re: After installing ROS 7.1beta2
Sun Sep 20, 2020 1:05 pm
Only when doing it via WinBox/GUI, from terminal it works fine.
I wrote about it here: viewtopic.php?f=1&t=165248#p815503
PS: you could change the topic name to something closer to the issue though
aoakeley
Mon Sep 21, 2020 2:47 am
System log
I have just tested on a RB2011 with ROS 7.1beta2 and can confirm the same issue.
thadrumr
Tue Sep 22, 2020 1:09 am
I can confirm this also happens with CHR 7.1 Beta 2 running in Hyper-V. I also confirmed that it does work changing the name via the CLI and the new name shows up in winbox.
Users browsing this forum: No registered users and 25 guests
