lapsio
Long time Member
Long time Member
L3 hardware offload in FW mode - will there be any other devices than CRS317 supporting this mode?
Fri Sep 25, 2020 5:48 pm
While I believe other devices will obviously eventually get basic L3 hardware offload (which is not all that interesting and unique since there's plenty of L3 switches out there) - most of them feature super weak sauce MIPS CPUs. However few switches (in particular CRS317 and CRS309 with dual core ARMs and few others with single core ones) feature beefier CPUs which I believe will perform quite well with L3 offload in FW mode and fasttrack enabled. Making them wire-speed stateful firewalls. Which is kinda insane if you think about it.
I mean I don't think I've ever seen such thing in the wild. Performance of this monstrosity is yet to be benchmarked but I believe it really does have potential to become something like 160 gbps stateful L4 firewall. Which is incredibly impressive like holy crap...
MTCNA, MTCRE, MTCINE
raimondsp
Re: L3 hardware offload in FW mode - will there be any other devices than CRS317 supporting this mode?
Fri Oct 02, 2020 1:30 pm
I wouldn't be so critical regarding ARM vs. MIPS CPU in terms of packet processing. Comparing CPUs relatively to HW (ASIC) performance is similar to comparing 10,000 RPM HDD vs. 7,500 RMP HDD relatively to SSD. Yes, 10K RPM HDD is faster. However, the benefit is negligible in comparison with SSD. Same here. The ARM CPU on CRS317 or CRS309 is faster than MIPS CPU on CRS312 or CRS326q. But it is not even remotely as fast as HW in terms of packet processing.
Nonetheless, you are right that CRS317 or CRS309 is a better choice (than CRS312/326) for hardware-accelerated stateful firewall, but for a different reason: CRS317 and CRS309 have twice larger hardware memory. CRS317/CRS309 can offload up to 4.5K connections to the hardware (4K in case of NAT) while CRS312/CRS326q - only 2.25K. Add here an ability to move connections back and forth between CPU and HW based on the actual data rate, and CRS317 can keep up with up to 10K L4 connections where CRS312 would give up on 4K.
mbovenka
Fri Oct 02, 2020 2:14 pm
I'd love for the CRS305 to get L3 offload, but that's probably not going to happen, is it? (What with the 98DX3236 being an 'L2+' ASIC)
raimondsp
Fri Oct 02, 2020 4:08 pm
Investigation of 98DX3236 switch ship's L3 capabilities is on the roadmap. Please do not misread: it is investigation not development.
IPANetEngineer
Trainer
Trainer
Fri Oct 02, 2020 4:36 pm
I agree that HW accelerated security devices at a low price point is a *huge* gap in the market. One feature that would really push the adoption of this is a stateful failover feature between two CRS switches so that it doesn't have to be a customized script + vrrp.
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
raimondsp
Mon Oct 05, 2020 1:42 pm
RouterOS v7 supports connection tracking syncing between two Mikrotik routers (or CRS switches). Here is more info:
VRRP sync-connection-tracking setup
mbovenka
Mon Oct 05, 2020 4:19 pm
Interesting nonetheless. I await with bated breath ;-)
Users browsing this forum: No registered users and 6 guests
