https://stubarea51.net/2020/10/12/mikro ... e-testing/
This. In fact you did well to get 1 Mpps from a Linux box (Proxmox/KVM) without any tuning. CloudFlare had to put a lot of effort into tuning to get that number - https://blog.cloudflare.com/how-to-rece ... n-packets/That is a typical case for CPU, where each packet causes an interrupt, which, in turn, adds performance overhead. ASIC doesn't care much about the packet count.
+++Regarding small MTU tests (tests #1 and #2), I suppose that the bottleneck is on the packet generator or receiver side, not the CRS317. As you see, PPS (packets per second) value is almost the same in all three cases, and the transfer speed depends purely on packet size. That is a typical case for CPU, where each packet causes an interrupt, which, in turn, adds performance overhead. ASIC doesn't care much about the packet count.
/routing/filter/
Hello.Did some work on testing the L3 performance last week in 7.1beta2 and published it today.
Very very interesting.
Using RouterOS we could use BGP to have some internal routes (less than 1000).
we could route them L3 in hardware...
Is something related to fastpath here? Or can we use some firewall filters?
we wont need conntrack or something similar.
/interface/ethernet/switch/rule/
No, ROS firewall (/ip/firewall) does not work simply because packets never enter CPU.In routerOS will be enabled fastpath then?
The traffic to the router itself (packet destination IP = router IP; INPUT chain) is unaffected by the l3hw. The firewall stays fully functional here. The same applies to outgoing traffic (OUTPUT chain).If we set some rules on the INPUT chain just to protect the router, we lose the hardware feature?
Yes, unfortunately, the number of hardware connections is limited. Actually, it is 4500 if used without MPLS. Mikrotik smart offloading algorithm picks the heaviest (traffic-wise) connections for offloading at any given time. Other (slower) connections get processed by the CPU. So the number of connections can be much greater. For instance, we tested CRS317 with 10k connections, and it worked fine.Is there a table? I have seen in the link at the first post, but it is not clear what the number means... 3750 connections, really? it is very low...
Thank you for you explanations.
The idea was to use a CRS to route l3 between interfaces at FAAAAST speed via BGP.
The issue is how can I protect the router itself then ?
Never tried the switch rules...
@raimondsp: can you kindly compare different modes of operation of l3hw to HW-offloaded L2? I can imagine many parallelisms, but as I don't have any experience with CRS3xx L3 offloading, I can't say if those parallelisms are real or imaginary.
Hello and good morning.
I was not sure about your first claim about the input/output. Thank you very much for claryfing it.
So the CRS can be a full functional BGP router, with hw forwarding, I dont see the traffic passing by, it is not an issue, but I can protect the router itself.
At the moment I use a CCR1036+10G switch with fasttrack, It could be easily replaced with a CRS317 that has all the 10G ports on it.
Basically:
From the wiki, I understand that L3 hardware offloading is currently only in the CRS317.
^ thisRecently one of MT support guys wrote that currently they're running feasibility study for supporting L3 switching on CRS328. He explicitly said that nothing is determined yet ... so it may end up with no L3 switching on this device ... and even if it does happen, it may take a while before it gets implemented.
