mmlea
Wirguard on version 7.1beta2
Sun Nov 08, 2020 12:59 am
Hello guys
1-
Bug in wireguard peers in the endpoint it is not possible to insert domain names only IP.
In oficial wireguard i can add peers via ddns domain.
Whould be great if you can correct this
2-
When i add endpoit i can't set a diferent port for it , sometimes wireguard servers don't run on default listen port.
If you can correct this too whould be great.
Thanks guys
Grettings
Lea
Sob
Re: Wirguard on version 7.1beta2
Sun Nov 08, 2020 4:54 pm
Good news for you, both are known problems (you'd probably find them reported if you tried to search) and likely to be fixed in next version.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
mmlea
Thu Nov 12, 2020 5:54 pm
Thanks guru
Another bug , when i insert a comment on wireguard peers once exited winbox the comments dissapear.
Hope it helps you.
tylermmoore
Sat Nov 14, 2020 5:25 am
Hi same issues for me. It seems if you modify anything In the wireguard settings you need to re enter the listen port via terminal.
Users browsing this forum: No registered users and 11 guests
