Jlgo222
ROS V7 for ARM64?
Wed Dec 09, 2020 1:48 am
Looking to update my LHGG lte kit with ROS7. The device can't auto find/download the file. And the arm file i see won't work manually either.
Any help, is there a beta7.0 file any where?
normis
Re: ROS V7 for ARM64?
Wed Dec 09, 2020 10:17 am
You can't auto-upgrade to v7. You must do it manually as using any kind of BETA is not recommended. Only for testing setups, where you know what you are doing https://mikrotik.com/download
eworm
Forum Veteran
Forum Veteran
Wed Dec 09, 2020 11:49 am
Regarding the topic... LHGG is not ARM64 but ARM, no?
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
anav
Wed Dec 09, 2020 1:50 pm
I thought ARM products were going to stay on the 6.4X fork?
J/K of course, but with so many knives out for so long for V7.0, I thought I would bring a fork to the table.
(They do get better once Ive had coffee).
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Jlgo222
Thu Dec 10, 2020 7:09 pm
It shows arm64 in the current stable release file.
Meant the manual upgrade from within WinBox? Within the update section it shows error cannot find file arm64-7.1beta3.... something like that.
SiB
Thu Dec 10, 2020 7:17 pm
Jlgo222
This is not stable. ros7 is only as BETA
Show log or screenshot.
At #2 you have URL from normis, you go here. Found arm64 section, download a main npk file.
Drag & Drop file to winbox OR use Files > Upload button.
Do reboot
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
At vacation until 15.jan.2021
Jlgo222
Thu Dec 10, 2020 7:35 pm
I have downloaded from the downloads section, the arm file and the arm64 file and neither take when doing a reboot. I have several Mikrotik devices running ROS7, but this one is fighting me.
From the packages menu, I selected "Development" and that's when I get an error "can't find arm64...." file.
SiB
Thu Dec 10, 2020 10:02 pm
You can first clear space by: /system package update cancel
Do reboot
Show first few lines of log after reboot
Jlgo222
Sun Dec 13, 2020 3:52 am
It took that time. I downloaded a fresh file"routeros-7.1beta3-arm64.npk" dragged to File List and rebooted.
previously i had used all the files from "all_packages-arm64-7.1beta3.zip" and it never worked.
Thanks for the help.
SiB
Sun Dec 13, 2020 9:09 pm
Becasue, firm you use the MAIN package to upgrade only RouterOS.
Next you select few packages from All_packages and they will works only if you put them at the same RouterOS version what is currently works at unit.
Next time read first line at LOG and here is always answer !
Users browsing this forum: No registered users and 8 guests
