ykleet
New Feature Request: run script after Wireguard connection status changed.
Sun Dec 27, 2020 7:53 am
Currently, I have some scripts running after VPN connections status changed (inside ppp security profile) and its very useful. I think its great if Wireguard has that feature also.
erkexzcx
Re: New Feature Request: run script after Wireguard connection status changed.  [SOLVED]
Sun Dec 27, 2020 10:25 pm
Can you use netwatch as a workaround for this (using any internal IP of wireguard)?
ykleet
Fri Jan 01, 2021 9:42 pm
Thx a lot and will try to try to see it work.
ykleet
Mon Jan 04, 2021 1:45 pm
Yes, it works. Thank you very much.
Users browsing this forum: No registered users and 12 guests
