ykleet
Memory reduced after using NetInstall
Fri Jan 01, 2021 10:01 pm
After using NetInstall, my hap ac^2 report that it memory is 128M but its supposed to be 256M. This also happened on another ac^2 after using NetInstall. Anyone know how to reclaim the memory back?
Also note that there is no problem to upgrade some of my other ac^2 to 7.1 beta 3. But upgrade on those two NetInstall'd devices did 'brick' the devices and have to use NetInstall again to downgrade it to 6.48.
uptime: 22m12s
version: 6.48 (stable)
build-time: Dec/22/2020 11:20:49
factory-software: 6.43.10
free-memory: 81.4MiB
total-memory: 128.0MiB
cpu: ARMv7
cpu-count: 4
cpu-frequency: 716MHz
cpu-load: 0%
free-hdd-space: 2300.0KiB
total-hdd-space: 15.3MiB
write-sect-since-reboot: 918
write-sect-total: 918
bad-blocks: 0%
architecture-name: arm
board-name: hAP ac^2
platform: MikroTik
mkx
Re: Memory reduced after using NetInstall
Fri Jan 01, 2021 10:26 pm
Are you 100% sure your hAP ac2 devices have actually 256MB RAM installed? Device is actually supposed to have only 128MB RAM (product page always stated that amount of memory), but some early batches had 256MB due to manufacturing "defect" ... Mine with 256MB RAM had factory default ROS version 6.42.3 installed, your is quite newer.
BR,
Metod
ykleet
Fri Jan 01, 2021 11:19 pm
You're rite. Just double check with another guy and he did swapped the devices with a newer one. So the topic of this post become invalid. See if anyway to remove this topic.
However, failure of 7.1 Beta 3 upgrade on two 128MB ac^2 is still valid.
Thx for your prompt reply.
Users browsing this forum: No registered users and 15 guests
