PhotoshopPhilipp
7.1beta4 monitor-traffic restApi
Wed Feb 10, 2021 10:42 am
Is it possible to get the following information through the rest api?:
tx-bits-per-second
rx-bits-per-second
The command would be: /interface/monitor-traffic wlan1 once but I could not get to run in through the api. I think id have to do it through the POST methode as it is descriped in the documentation https://help.mikrotik.com/docs/display/ROS/REST+API
I think: ip/rest/interface/monitor-traffic?interface=wlan1 is the way to do it but it needs somehow the once param...
Does someone know how to do that?
mrz
Re: 7.1beta4 monitor-traffic restApi
Wed Feb 10, 2021 11:11 am
Check "Timeout" section in that manual. It has an example on how to use similar commands to "monitor-traffic"
PhotoshopPhilipp
Wed Feb 10, 2021 11:53 am
Mmm thats a thing but not exactly what im trying to do. I can messure the bandwith between 2 tiks but i want to know the traffic of the interface wlan1 for exampe...
Is there another solution to that?
mrz
Wed Feb 10, 2021 1:53 pm
It is not clear what you are not able to do.
Have you tried to run
POST 'https://x.x.x.x/rest/tool/traffic-monitor' -data '{"interface":"wlan1","duration":"2s"}'
PhotoshopPhilipp
Wed Feb 10, 2021 4:06 pm
Yes i already tried that on multiple tiks but it didnt work :(
mrz
Re: 7.1beta4 monitor-traffic restApi  [SOLVED]
Wed Feb 10, 2021 4:19 pm
Be more specific what exaclty is not working what errors you get and so on.
Here is an example of traffic monitor, it works as expected:
$ curl -k -u admin: -X POST 'https://10.155.101.214/rest/interface/monitor-traffic'   --data '{"interface":"sfp12","duration":"2s"}' -H "content-type: application/json"
[{".section":"0","fp-rx-bits-per-second":"45176","fp-rx-packets-per-second":"49","fp-tx-bits-per-second":"222160","fp-tx-packets-per-second":"30","name":"sfp12","rx-bits-per-second":"45176","rx-drops-per-second":"0","rx-errors-per-second":"0","rx-packets-per-second":"49","tx-bits-per-second":"222160","tx-drops-per-second":"0","tx-errors-per-second":"0","tx-packets-per-second":"30","tx-queue-drops-per-second":"0"},{".section":"1","fp-rx-bits-per-second":"24184","fp-rx-packets-per-second":"27","fp-tx-bits-per-second":"214616","fp-tx-packets-per-second":"31","name":"sfp12","rx-bits-per-second":"24184","rx-drops-per-second":"0","rx-errors-per-second":"0","rx-packets-per-second":"27","tx-bits-per-second":"214616","tx-drops-per-second":"0","tx-errors-per-second":"0","tx-packets-per-second":"31","tx-queue-drops-per-second":"0"}]
PhotoshopPhilipp
Wed Feb 10, 2021 4:25 pm
I tried it with curl and it worked right away. Well I guess I have to look at my not properly working tools.
Thank you for your answeres!
Users browsing this forum: No registered users and 4 guests
