ofca
ROS7, announce single address
Fri Feb 12, 2021 9:20 am
How do I announce one single /32 prefix over BGP? After upgrading from 6.48.1 to 7.1b4 connection has converted properly, it gets established, but:
/routing bgp network add network=10.100.10.41/32 synchronize=no
did not.
Is there any recent documentation somewhere? Rules from examples I found over the net doesn't seem to be working.
mrz
Re: ROS7, announce single address  [SOLVED]
Fri Feb 12, 2021 10:58 am
With output networks in a bgp template. The example is here:
https://help.mikrotik.com/docs/display/ ... g+Examples
ofca
Fri Feb 12, 2021 11:25 am
Thank you for the link; I've seen it earlier though. Turns out problem laid with badly converted (actually not converted at all) input filter that I missed. After removing it, things started to work. Do you know how the new "rule=" thing works?
Users browsing this forum: No registered users and 8 guests
