rpra
OSPF redistribute and routing filters in v7
Wed Mar 17, 2021 4:18 pm
Trying to set up lab on 7.1.beta5
I simply want to redistribute loopback addresses into ospf, but by default it does not work.
Started to set up filters, but they do not work as said in https://help.mikrotik.com/docs/display/ ... g+Examples
[admin@R1] > routing/filter/rule/add chain=ospf_out
failure: empty rule specified
[admin@R1] > routing/filter/rule/add chain=ospf_out rule="dst<subsumes>10.0.0.0/8"
failure: invalid action at dst
Maybe someone knows?
StubArea51
Trainer
Trainer
Re: OSPF redistribute and routing filters in v7
Wed Mar 17, 2021 5:12 pm
The syntax for routing filters has changed:
Details here:
viewtopic.php?f=1&t=173567#p848792
I'd expect something like:
/routing/filter/rule/add chain=ospf-redist rule={if [protocol connected] then={action do=accept}}
rpra
Wed Mar 17, 2021 5:24 pm
Details here:
Thanks, but I still can't understand how to use that "chains" or "select chains"
Can you please show full config for "redistribute static/connected with some filtering" scenario?
mrz
Wed Mar 17, 2021 5:34 pm
Just need to specify chain in instance and add one rule.
/routing ospf instance set <xxx> out-filter-chain=myChain
/routing filter rule add chain=myChain rule={ if ([protocol connected]) then={num-value ospf-ext-metric<assign>10; ospf-ext-type type1; action accept}}
rpra
Wed Mar 17, 2021 5:40 pm
Ok, it looks working now.
What for are select-chain and select-rule?
And please help to figure out how to filter by prefix and prefix length?
dacoshild
Thu Mar 18, 2021 1:57 pm
How would make equivalent of this?
- redistribute default route - never
- redistribute connected routes - as type 1
- redistribute static routes - as type 1
Can it be like this?:
0 chain=final rule=if ([protocol connected] || [protocol static]) then={action do=accept; ospf-ext-type type1}
1 chain=final rule=if ([prfx-value is=dst<equal>0.0.0.0/0] || [protocol static]) then={action do=reject}
mrz
Thu Mar 18, 2021 2:02 pm
Firsts reject default route and then accept static,connected
or you can write in one rule
if ([prfx-value is=!dst<equal>0.0.0.0/0] || [protocol static] || [protocol connected]) { ospf-ext-type type1; action accept}
dacoshild
Thu Mar 18, 2021 2:49 pm
Thank you mrz!
mrz
Thu Mar 18, 2021 8:01 pm
Some more info on new filter syntax now is available here:
dacoshild
Fri Mar 19, 2021 11:19 am
How can I set ospf cost? Before it was just "routing ospf area set <xxx> default-cost=<xxx>
I just cannot find it enywhere.
Users browsing this forum: dioeyandika and 15 guests
