dacoshild
OSPF Cost
Wed Mar 24, 2021 8:58 pm
Can you guys tell me where to set cost for OSPF? It looks like the option is missing. Thanks
tdw
Re: OSPF Cost
Wed Mar 24, 2021 10:11 pm
Per interface under /routing ospf interface (or Routing > OSPF on the Interface tab in Winbox)
joegoldman
Forum Veteran
Forum Veteran
Re: OSPF Cost
Wed Mar 24, 2021 11:44 pm
You can also set default cost under instance - which will be the cost given to 'Dynamic' interfaces (entries under routing -> ospf -> interfaces created dynamically due to network statements etc) - to set individual cost per interface you'll have to move them to being a static entry.
mafiosa
Re: OSPF Cost
Fri Mar 26, 2021 6:31 am
As confirmed by Mikrotik support setting cost is not available in beta 5 and will be added in next betas. Check the original post.
dacoshild
Re: OSPF Cost
Mon Mar 29, 2021 10:29 am
OK, so that is the reason I cannot find it. Thank you
Users browsing this forum: No registered users and 53 guests
