terdinatore
Reset to Factory Default on every reboot
Fri Apr 30, 2021 12:14 pm
I have a rather unpleasant problem with my RB2011UiAS-RM on 7.1beta4. I bought the device used about a year ago and started using it in March 2021. Every time I need to reboot all of its configuration gets wiped. This is especially unlucky when I try to restore a backup which forces a reboot. I have now made a .RSC backup that can restore the config without a reboot, but still all the logs are gone.
Can someone advise how to troubleshoot this problem? Could it be that the reset button got stuck or is there a jumper that does this? Are there software settings which results in this behavior?
Thank you guys!
rextended
Re: Reset to Factory Default on every reboot
Fri Apr 30, 2021 12:26 pm
config do not matter
netinstall 6.47.9, update bios, and check if the problem persist
Zacharias
Fri Apr 30, 2021 1:07 pm
Go to /system packages and proceed to installation check... what is the result ?
Most problably you should perform a net install on your device...
Is there anything unusual on system shceduler ?
terdinatore
Sat May 01, 2021 3:19 pm
Yeah, I thought so but just wanted to give as much info as I can.
Let's assume I haven't got the latest bios and no issues on 6.47.9, would you suggest trying 7.1beta again?
I have nothing but a Dyndns script, which I am pretty sure is innocent.
It returns
installation is ok
I will try the netinstall and report back. Fortunately, it is easy to check if the issue persists. Thanks for the suggestions
lobito
Tue May 11, 2021 12:22 pm
I have the same Problem on 2 Routers, RB2011UiAS-2HnD and hAP ac. Nothing helps only restore backups, but not in every case. At random reboots fails the restore and I have still Factory Default Settings.
rextended
Tue May 11, 2021 1:26 pm
kiler129
Sun May 16, 2021 5:59 am
I can add another RB2011 with the same problem. The funny thing is there is SOMETHING in the config which triggers that. I have a backup which restores and works throughout reboots but if I go and import my full config it works until reboot. After the reboot the router is wiped to factory defaults ;)
frank333
Sun Jun 20, 2021 8:11 am
I can add another RB2011 ...
I have the same problem as you how did you solve it?
Zacharias
Mon Jun 21, 2021 9:44 pm
Perform a Netinstall and then check again...
https://wiki.mikrotik.com/wiki/Manual:Netinstall
frank333
Tue Jun 22, 2021 2:20 pm
ok!.seems to work now on rbm11g ROS 7.06 tnx
Users browsing this forum: No registered users and 23 guests
