akrao
v7.1beta6: netPower 16P: Cannot enable L3 Hardware Offloading
Mon May 31, 2021 2:08 am
as the title says, I cannot enable L3 Hardware Offloading on CRS318-16P-2S+. There are no firewall rules, and L3 HW support cannot be enabled whether Bridge VLAN filtering is on or off.
[admin@CRS318-L3-test] > /sy ro pri
       routerboard: yes
        board-name: netPower 16P
             model: CRS318-16P-2S+
     serial-number: D55A0D63020F
     firmware-type: dx3230L
  factory-firmware: 6.47.4
  current-firmware: 7.1beta6
  upgrade-firmware: 7.1beta6
[admin@CRS318-L3-test] > /sy reso pri
                   uptime: 58m46s
                  version: 7.1beta6 (development)
               build-time: May/18/2021 14:49:50
         factory-software: 6.46.6
              free-memory: 202.3MiB
             total-memory: 256.0MiB
                      cpu: ARMv7
                cpu-count: 2
                 cpu-load: 0%
           free-hdd-space: 2504.0KiB
          total-hdd-space: 16.0MiB
  write-sect-since-reboot: 179
         write-sect-total: 9857
               bad-blocks: 0%
        architecture-name: arm
                 platform: MikroTik
[admin@CRS318-L3-test] > /sy reso cpu pri
Columns: CPU, LOAD, IRQ, DISK
  #  CPU   LO  IR  DI
  0  cpu0  0%  0%  0%
  1  cpu1  0%  0%  0%
[admin@CRS318-L3-test] > /sy reso irq pri
Flags: ro - READ-ONLY
Columns: IRQ, USERS, CPU, ACTIVE-CPU, COUNT
  #      IR  USERS        CPU   A  COUNT
  0      27  ttyS0        auto  0      7
  1      28  mv64xxx_i2c  auto  1      0
  2  ro  30  pdx_eth_0    auto     7 472
  3  ro  31  pdx_eth_1    auto     1 396
  4      32  pdx_misc     auto  0      1
  5      33  gpiolib      auto  1      0
[admin@CRS318-L3-test] > /int eth swi pri
Columns: NAME, TYPE, L3-HW-OFFLOADING
  #  NAME     TYPE              L3
  0  switch1  Marvell-98DX226S  no
[admin@CRS318-L3-test] > /int eth swi pri det
Flags: I - invalid
 0   name="switch1" type=Marvell-98DX226S mirror-source=none mirror-target=none l3-hw-offloading=no
[admin@CRS318-L3-test] > /int eth swi set 0 l3-hw-offloading=yes
failure: L3 HW Offload not supported
[admin@CRS318-L3-test] > /sy check-installation
  status: installation is ok
Also, the device shows 2 active CPU cores, with CPU load differing on each one.
Is this expected, and if yes, can we expect a doubling of software routing performance?
raimondsp
Re: v7.1beta6: netPower 16P: Cannot enable L3 Hardware Offloading
Mon May 31, 2021 9:12 am
The issue has been identified and already fixed. Please contact support@mikrotik.com and we will provide you a hot-fixed firmware, so you don't have to wait for the next beta.
Thanks for the feedback!
akrao
Mon May 31, 2021 3:10 pm
Email sent, thanks!
Users browsing this forum: No registered users and 21 guests
