ahmedelbarbary
problem with pppoe server
Thu Jun 17, 2021 5:08 am
Hello mikrotik team
I had an issue with v7.1beta6 pppoe users when loggedout they already deleted from interface and they stay in active connections
i tried ti delete them, no way to delete just restart, i tried to disable pppoe servers all router restarted
Could you fix this problem in next release ?
i use CHR
Thanks.
rextended
Re: problem with pppoe server
Thu Jun 17, 2021 9:01 pm
Write to support@mikrotik.com sending also the Supout.rif file.
ahmedelbarbary
Fri Jun 18, 2021 12:14 am
Thanks, Done
Users browsing this forum: hzdrro, Lifz and 7 guests
