scrool
Bug: default configuration fails on 7.1beta6
Sat Aug 07, 2021 1:20 pm
  • Version number: 7.1beta6
  • Router's model: RB4011iGS+5HacQ2HnD
I decided to reset configuration and I found out that default configuration script fails. I ended up with a device without IP address. I was able to get the device working through serial console.
Steps to reproduce the issue:
[admin@router] > /system reset-configuration skip-backup=yes
Dangerous! Reset anyway? [y/N]:
y
system configuration will be reset
Rebooting...
[42031.635046] reboot: Restarting system
:00000050
AL31400X-140
RouterBOOT booter 7.1beta6
RB4011iGS+5HacQ2HnD
... (wait for login prompt) ... After login with admin and no password I get:
SCRIPT ERROR: expected end of command (line 101 column 16)
and to show more details:
[admin@MikroTik] > /log/print without-paging
00:00:04 system,info crossfig will upgrade version 6 configuration
00:00:04 system,info router rebooted
00:00:17 system,error,critical error while running default configuration script: expected end of command (line 101 column 16)
00:00:18 system,info,account user admin logged in via local
When I print default config:
[admin@MikroTik] > /system default-configuration print without-paging
I see:
                      /interface wireless {
                        set $ifcId channel-width=20/40/80mhz-XXXX;
                        set $ifcId secondary-channel=auto
                        set $ifcId frequency=auto
Syntax highlighting shows first "s" in "secondary-channel" with red and after that text is not highlighted. I believe it is because it doesn't exist anymore:
[admin@MikroTik] > /interface/wireless/
access-list  channels      interworking-profiles  nstreme-dual        sniffer  add      edit    find               print   reset-configuration  setup-repeater    wps-client
align        connect-list  manual-tx-power-table  registration-table  snooper  comment  enable  frequency-monitor  remove  scan                 spectral-history  wps-push-button
cap          info          nstreme                security-profiles   wds      disable  export  monitor            reset   set                  spectral-scan
And just to add, device doesn't have IP address set:
[admin@MikroTik] > /ip/address/print
[admin@MikroTik] >
Since I wanted to get default config, I followed First Time Configuration to set IP address, uploaded stable version of firmware, switched to it, reset again which worked and only then switch back to beta.
dmfr
Re: Bug: default configuration fails on 7.1beta6
Tue Aug 10, 2021 1:08 pm
Confirmed. Same hardware, same result.
Additionally, applying previous exported config through :
/system reset-configuration no-defaults=yes run-after-reset=myexport.txt.rsc
fails unless you add
:delay 20
on top of script.
michaelpau
Fri Dec 03, 2021 6:40 am
For any future Google searches. I am also seeing this issue on the RB4011iGS+5HacQ2HnD, but I'm NOT running (and NEVER have) a beta firmware. Running 6.49.1
There is a bad bug with the default-configuration of RB4011iGS+5HacQ2HnD and 6.49.1.
Steps to reproduce:
- Get a RB4011iGS+5HacQ2HnD
- Flash with 6.49.1
- Perform a system reset:
- /system reset-configuration
- y
Wait for reboot, and you’ll receive this console/error message[/list]
The lines in question that is failing is:
Line 99: set $ifcId channel-width=20/40/80mhz-XXXX;
Line 100: set $ifcId secondary-channel=auto
Line 101: set $ifcId frequency=auto
Expected result:
Router factory reset with default config, such as DHCP running on ether2
Actual result:
No default configuration restored
Testing:
I’ve replicated this on 2x RB4011iGS+5HacQ2HnD devices.
Users browsing this forum: No registered users and 15 guests
