darencrew
SSH problems on 5.0rc1
Thu Oct 07, 2010 7:07 pm
I found a bug on ssh.
Before upgrade i use specific port for ssh, after upgrade i succeed in connecting but password is always rejected....
After a downgrade to 4.11 without any other change, i succeed in both connecting and logging....
So according to other posts, ssh seems to have a real problem.
Regards
ditonet
Forum Veteran
Forum Veteran
Re: SSH problems on 5.0rc1
Thu Oct 07, 2010 11:04 pm
For me SSH on specific port works fine, on x86 platform.
Regards, Grzegorz.
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
janisk
Fri Oct 08, 2010 4:03 pm
check if you have set ssh-key for that account. If you are using ssh-key you cannot login using password anymore. That is as intended with RouterOS 5
dssmiktik
Forum Veteran
Forum Veteran
Sat Oct 09, 2010 6:42 am
I just wanted say, nice feature addition. :-)
Doug
janisk
Mon Oct 18, 2010 4:27 pm
What's new in 5.0beta5 (2010-Jul-23 14:50):
*) ssh - password authentication is disabled for users with public keys;
well...
dssmiktik
Forum Veteran
Forum Veteran
Tue Oct 19, 2010 12:03 am
janisk,
I saw that in the changelog. I think this feature is a good feature for security, as it prevents brute-forcing a password if you use ssh-key for a user account.
Nice work :-)
Doug
femur
Thu Jun 16, 2011 9:16 am
I do approve of good default settings for security. But give me a chance to think by myself, please. :)
First case. I use public-keys from more than one place, and setting key from one place generates problem from another. I need to take roundabout route with key.
The second case. I use public-keys from central admin server. If I go to a customer for service, and can not use internet from there I can not login into machine, because have no access to central admin server.
There is a simple suggestion to patch this up. Let me disable this default environment. For instance:
/user set admin password-login=yes
or something similar.
Users browsing this forum: No registered users and 7 guests
