Railander
Re: Feature requests
Thu Apr 05, 2018 7:50 pm
Feature Request:
With the use of interface-lists, set customized permissions to which interfaces a user (and preferably also snmp community) can see or make changes to.
Some of our clients like to have read access to our routers, but sometimes it's a router supplying more than one client and giving even read access would mean they could see every other customer in it.
Currently we work around this using Traffic Flow, but it's not real time and generates a lot of traffic and CPU overhead.
doneware
Trainer
Trainer
Sat Apr 07, 2018 9:32 pm
this might be two things however. while the interface statistics could be worked out with "/tool graphing" even with resource visibility separation - currently using src ip address as differentiator - the "editing" part is tough. so if you can separate your customers based on ip address, you can define which interface/queue/resource the user may be viewing on the router's web gui.
but i don't really think this is a good idea, as routers are to forward packets and to run web servers. if you want real granular read/write control for defined routeros resources (interface, addresses, queues) you will be better off with an external web server using API integration.
pepek
Tue Apr 10, 2018 1:14 am
I've tried to search this topic, but I haven't found it (hope there are not any duplicates):
NTP Client - Possibility to use server name, not just IP address
exFAT (FAT64) or NTFS support - yes, MT is not NAS (it's slow), but it would be great to use file system capable of handling >4GB file complatible with Windows (you have HDD with big files and you want to share some files - you cannot connect it to MT, you have to reformat it to FAT32, copy everything except for big files back...)
Wireless - move Country and Distance setting to Simple Mode - you can set every other important "basic" setting in simple mode, but you have to switch to Advanced Mode for these two settings.
Quick Set - It's working with WPA1 password. It doesn't recognise, when you manually set WPA2-PSK AES only password. It requires also setting WPA1 password (even if WPA1 is not allowed), otherwise Quick Set shows WiFi password red and empty (WPA2 only is used)
zappulec
Tue Apr 10, 2018 6:15 pm
Secured DNS
- DNS over HTTPS
- DNS over TLS
pe1chl
Wed Apr 11, 2018 10:34 am
You will have to learn and understand that you should use QuickSet only ONCE and not look at it later!
It provides an overview of some basic config but it is not showing correct values after you made manual changes (not only this!) and should you later change some
things via QuickSet you will seriously mess up the configuration!
So please don't worry about things like this and don't use QuickSet.
In fact a more appropriate feature request would be: make QuickSet disappear once it has been used and manual changes have been made afterwards.
That would protect a lot of beginners from serious trouble.
miencek
Wed Apr 11, 2018 11:55 am
RAM Disk for temporaty files ex. configuration to/from other devices, scripts
pudjo
Request : alternative DNS Port for IP DNS Setting
Tue Apr 17, 2018 1:04 am
I've been waiting for along time MikroTik can provide alternative port for IP DNS Setting, other than 53 (default)
normally user input value ip address such as 8.8.8.8 and 8.8.4.4 for IP DNS Setting
alternative port, for example, can be set as easy as 8.8.8.8:553 and 8.8.4.4:533
The purpose is to get DNS service from non default port DNS Server.
Any response is greately appreciated,
Thank You
Miracle
Re: Request : alternative DNS Port for IP DNS Setting
Tue Apr 17, 2018 5:48 am
Thank You
Do you know dst-nat ?
Chupaka
Tue Apr 17, 2018 5:53 pm
Is there any DNS server on port other than 53?..
TomjNorthIdaho
Tue Apr 17, 2018 7:52 pm
There are some non port 53 DNS configurations/uses.
Example: DNS over TLS is often port 853 -and- I kinda remember something about 135 End-Point-Mapper being used also for DNS
Also - security through obscurity can help prevent some attacks - such as running ssh on non-standard ports , DNS could possibly be remapped to use a non-standard port other than 53 to achieve a security through obscurity.
However , the standard well-known DNS port is 53. I would think if there is a security concern , that a FW configuration would be easier and more compatible method to control DNS access and better prevent attacks against DNS servers.
North Idaho Tom Jones
pe1chl
Tue Apr 17, 2018 8:06 pm
The intended use case is probably where the ISP blocks or redirects access to port 53 outside (only allowing acces to their own resolvers)
but does not have advanced DPI in place. Then just using a different port may circumvent their efforts. E.g. OpenDNS listens on port 5353,
and one could sents the requests there. I don't know if Google DNS and CloudFlare DNS have similar alternate ports.
Of course this works only until the ISP admins know it and block or redirect that port as well. Not worth it to make a change in the router
for that, just use dst-nat.
Sob
Tue Apr 17, 2018 9:48 pm
Not worth it to make a change in the router for that, just use dst-nat.
Current RouterOS stores IP address of resolver and uses hardcoded port 53. Changing it to store IP address and port doesn't sound like anything big. But I guess dstnat would be enough. It's just that as it is now, you can do it only for clients, not for router itself. If router requires resolver on alternative port for own use, or if you want alternative port and also router as resolver for clients (because of caching, or because you want to override some records), you can't do it. It would require support for dstnat in output chain.
pe1chl
Tue Apr 17, 2018 11:10 pm
It may be possible to use a loopback interface and set the DNS server address to the address of this interface, then dstnat that traffic.
(I did not try, but I *do* use dstnat for traffic incoming to a router and that works)
msatter
Tue Apr 17, 2018 11:42 pm
Or you use an local DNS server on a RaspberryPI like DNSmasq, PiHole, etc.and you are able to control it all yourself.
TomjNorthIdaho
Wed Apr 18, 2018 1:17 am
As stupid as it might sound -almost a lol-
What happens if you add ":XY" to the IP address of the DNS server , where XY is the port #
Say you wanted you mikrotik to use port 5320
then use IP address format of the DNS server of:
a.b.c.d:5320
I remember this working on an old DSL router 15 years ago.
Sob
Wed Apr 18, 2018 2:03 am
@pe1chl: No, dstnat happens in prerouting, so traffic coming to router (no matter if it will end up in forward or input) can be matched by dstnat rule. Traffic from router doesn't come through prerouting in RouterOS.
@msatter: External device would work fine, but sometimes it may not be desired or even possible to add it.
@TomjNorthIdaho: Nope, to quote WinBox: "Error in - non zero ip address or non zero ipv6 address expected!"
But something can be done. I posted possible solution in the other thread, because it belongs there more. But I don't like it.
pe1chl
Wed Apr 18, 2018 10:38 am
Ok apparently it needs a real loop, I was thinking about adding a loopback interface (an empty bridge with an IP address) and sending the DNS queries there.
But maybe the address is considered local and it does not work then.
Chupakabra303
Wed Apr 18, 2018 1:39 pm
file get contents
Increase threshold 4096 byte, while reading the file or make the file reading by pieces. 4K is too little!
pe1chl
Wed Apr 18, 2018 2:34 pm
file get contents
It is not a limitation of those routines, but of the maximal length of a variable content.
What is needed is an open/readline/close feature so files can be read line-by-line into a variable.
(for completeness also a read(n) to read a fixed number of bytes instead of a single line)
juliokato
Wed Apr 18, 2018 3:44 pm
I have a solution to decrease costs with DNS filters like OpenDNS or SafeDNS, using a DNS resolver intermediate on UDP port 5353. All my 100 MK with different valid IPs points to this resolver.
This also helps in the security of this resolver.
I can give you more details if anyone has an interest.
Chupaka
Wed Apr 18, 2018 4:25 pm
So how do you point your Windows/Linux/MacOS machine to some non-53 DNS port?..
juliokato
Wed Apr 18, 2018 8:32 pm
I was using firewall nat:
add action=dst-nat chain=dstnat disabled=no dst-port=53 log=yes protocol=udp to-addresses=aa.bb.cc.dd to-ports=5353
this forces anyone to use my resolver, even if some user tries to use another different dns server.
This has other implications of redundance and security that is not part of this topic.
fernandolcx
Thu Apr 19, 2018 6:06 pm
Feature Request:
Actually it's possible to get a total number of active PPPoE sessions via SNMP using this OID:
1.3.6.1.4.1.9.9.150.1.1.1.0
But if we could get this number in a per interface (or PPPoE Server name) basis, should help to detect and troubleshoot issues when using
Mikrotik routers as BRAS/BNG/PPPoE Server.
If a large number of active sessions from a specific interface or servicename drops suddenly, any monitoring application can trigger an alarm for that interface/servicename.
To workaround we can use this:
/interface pppoe-server print count-only where service=service5
BUT it should be a nice feature to add to SNMP
samsung172
Fri Apr 20, 2018 12:20 am
Feature Request:
You can have this info from the radius server. (if used)
raymondr15
Fri Apr 20, 2018 1:34 am
Please add the ability to enable or disable successful login attempts for specific users, for example an API user, accounting software logging in and out updating information on the router.
lordcoke
Fri Apr 20, 2018 4:03 pm
Feature request for /tool sniffer. Please make it possible to submit a filter-port range to the sniffer to allow sniffing like this:
/tool sniffer set filter-ip-protocol=udp filter-port=32000-32255
pudjo
Mon Apr 23, 2018 3:16 pm
i have run several DNS servers using many port other than 53, the purpose is for internet filtering, users can select filtering level by choosing dns port, check out https://www.thenetpurifier.com/filtering.php
pudjo
Mon Apr 23, 2018 6:43 pm
vote +1 for dstnat in output chain
pudjo
Mon Apr 23, 2018 6:45 pm
Thank You
dst-nat not working in output chain, AFAIK
lugovoyma
Mon Apr 23, 2018 8:20 pm
openvpn UDP
pe1chl
Wed Apr 25, 2018 5:07 pm
Now that ip firewall address-list (and ipv6 firewall address-list) support DNS lookups, add a way to get subnet entries from DNS.
Unfortunately there is no standard DNS record type for subnets. There is the experimental APL record type (RFC3123) which would be exactly what is needed, but it isn't supported in DNS servers.
Therefore, I suggest to use TXT records.
Do a query for TXT records for the specified name (after or in parallel to the A and AAAA records already queried) and for each TXT record coming back, check if it conforms to valid subnet notation like 11.22.33.0/24 or 11:22:33:44::/64 and if valid, add it as an address list item.
Sob
Wed Apr 25, 2018 8:12 pm
If you have your own authoritative servers, some already have native support for APL (at least BIND and Knot DNS). And any sensible server allows to add unknown record types using generic syntax. If you have hosted DNS and you depend on some admin interface, it's another story and I guess support there will be very bad. That was the authoritative part. Resolvers should be transparent for unknown types since forever.
So it may sound perhaps a little too optimistic, but I'd say it's almost there. And a gentle push (like MikroTik adding support in RouterOS) might help to move things forward. Some people could start using it right away and others would have motivation to nag their DNS providers to add support.
erebusodora
Wed Apr 25, 2018 8:20 pm
It would be very nice to have a feature to hide rows. Column Hide and Show Footer Works is a great job on the look. Screenshot feature must be implementet too.
pe1chl
Wed Apr 25, 2018 8:28 pm
I googled for it and I cannot find any DNS server that has documented APL support, including Bind. We use bind 9.
However, if it is supported it would be fine to use APL. Probably with TXT there are less obstacles.
Sob
Wed Apr 25, 2018 10:31 pm
It doesn't seem to be advertised much, but it looks like BIND has it since 2002.
Advantage of using TXT would be instant availability everywhere. Probably even better reliability, at least in short term, because some broken resolvers will surely show up somewhere. But it's reinventing the wheel. Purists might also argue that we don't need yet another thing in TXT, there's enough of them already.
hurymak
Thu Apr 26, 2018 1:54 pm
Encrypt nand filesystem, so when some thieve unsolder it, cant read my config.
cis2131
Thu Apr 26, 2018 11:11 pm
Run a script when a port is closed by loop protect.
PtDragon
Fri Apr 27, 2018 12:08 am
Small feature request:
Please make Syn Cookies tunable!
I explain a bit: right now we can only turn on or off.
I wish we could have cookie timeout tunable in our hands (so if no cookie reply for example in 5 or 10 or 30 sec just drop connection).
That will make defense way easier :)
Chupaka
Tue May 01, 2018 3:26 pm
So, you'll need to enter encryption password each time router reboots? :)
5nik
Mon May 07, 2018 12:29 pm
Please, implement bandstearing for wifi, especially in CAPsMAN.
Please, add support 802.1x for wire interfaces.
pedromrocha
Mon May 07, 2018 2:48 pm
Please implement TACACS autentication.
We can't get your equipments certified in a ISP without that feature.
netwpl
Wed May 09, 2018 8:37 am
1+
psannz
Wed May 09, 2018 9:15 am
Yes! +1, pretty please?
TomjNorthIdaho
Simple Queues - Please increase limits - they max at 4,294 Meg
Wed May 09, 2018 9:29 pm
BUMP - I originally posted this: Wed Mar 21, 2018 3:28 pm
Please increase Simple-Queue limits - they max at 4,294 Meg (aka 4.294 Gig)
ROS Simple-Queue - please increase the possible maximum limits and thresholds.
Currently on v6.41.3 and v6.41.2 (don't know about older versions and I have read nothing in newer versions) ,
The current maximum possible value for "Max Limit" and "Burst Limit" and "Burst Threshold" is "4294M"
The Simple queue will not accept any higher numbers.
This presents a huge problem. I have multiple 10-Gig networks and on some networks I must use bandwidth limiters which are much faster than the built-in restricted values.
An example of need: 10-Gig physical Internet connection (using CHR) - Purchased Internet speed need to be maintained by my network equipment. Problem - the Mikrotik ROS will not accept any values greater than 4294M in any of the Winbox Simple-Queue fields
Chupaka
Thu May 10, 2018 11:39 am
Tom, did you write to support@mikrotik.com ? Because this looks not like feature request but like important fix :)
pe1chl
Thu May 10, 2018 6:45 pm
No this is just established standard functionality hitting limitations as technology proceeds.
The queue mechanism uses 32-bit values (variables) and so the values are limited to 2^32
In fact practical limits are lower because "buckets of data" have to be calculated to be transmitted on each timer tick
and when the datarate gets so high the buckets become very large and those bursts could hit other limits or not play
along with others as nicely as you would like.
So it is not as easy to fix as you might think.
TomjNorthIdaho
Fri May 11, 2018 6:48 pm
I suspect the simple-queue maximum value settings are going to be a bigger and bigger problem in the near future. - because of the new Mikrotik 40-Gig interfaces and newer/faster CPUs.
I can't help but wonder how much of the 64-Bit CHR software actually uses 64-bit instrustions.
Many 64-bit CPU instructions use fewer CPU clock cycles compared to a 32-bit set of instructions doing the same software function.
If Mikrotik is gonna compete in the router throughput world with the other guys in the faster than 3-Gig enviornment, they need to do everything possible to gain every speed/function/feature advantage possible.
I think I will write to Mikrotik support.
anav
Tue May 15, 2018 1:09 am
EXTRA TAB CHANGE!!
The mere fact of viewing any of the parameters ACTIVATES the parameter and this is WRONG.
All entries should be blank and if you want to offer default settings, GREY THEM OUT.
Suggest putting an apply button or something.
This is not consistent with the rest of the filter rules.
Right now I call it the DANGER DANGER TAB. ;-)
Chupaka
Tue May 15, 2018 11:13 am
Huh... Any more details? What do you mean saying 'Activates'?.. Why can't you 'deactivate' it back? :)
anav
Tue May 15, 2018 2:14 pm
Sorry chupka, I am just a beginner. I didnt know I was changing router settings just by looking at the paramaters in the ExtraTab.
In my limited experience when I clicked on the little arrow tabs, I thought I was simply viewing the default parameters in those selections.
I did NOT REALIZE that I was activating those parameters.
This is not consistent with how we apply items elsewhere in winbox.
Thus suggesting that the default entries be grayed out and one has an implement button when one wants to turn grey into white.
Or it is like every other
Or add a warning at the bottom of the EXTRA TAB. Stating, opening these items ACTIVATES them.
If you do not want them activated CLOSE after viewing.
Chupaka
Tue May 15, 2018 3:54 pm
The same with TCP Flags and ICMP Option in Advanced tab.
Also, DO NOT OPEN Bridge -> Filters, there are 4 tabs and ALL OF THEM are like EXTRA! xD
anav
Tue May 15, 2018 4:25 pm
As I stated, I am new to mikrotik.
To have to rely on intuition vice standard methods is a ridiculous way of setting up programming the router.
Every other selection I make on the router is checking a box, typing in a selection, pulling a selection from a pull-down menu.
I am not saying its wrong, just that from my perspective its bad design and terrible for the non-expert.
Would it hurt that much to have a fixed text at the bottom of the EXTRA TAB.....
"CAUTION: Opening up the parameters via the arrow icons, activates the parameters. If the entries are not modified, the default settings are accepted"
OR
"NOTE: Up facing arrow icons indicates an ACTIVE parameter"
If I could add an image here, and not from an URL, I would post one to give you an idea. :-(
EDIT,,,,,,,,, posted in elsewhere for viewing here.............. the llama cannot be stopped.
Well that was less than useful....... argggg Lets try that again....
https://www.dslreports.com/speak/slides ... RhcnQ9MTgw
Bergante
Tue May 15, 2018 5:23 pm
I've posted a message on the forwarding protocols area, linked from here:
viewtopic.php?f=14&t=134423
BFD support for static routes would be extremely useful. Basicly, a static route would have an attribute to use BFD to check gateway availability. It's much better than check-gateway because it's a standard and it will help both a Mikrotik router and a router from a different manufacturer to detect a link down event.
I think it's simple to implement, even!
TomjNorthIdaho
Re: Feature requests - ability to select :port on a telnet
Wed May 16, 2018 2:00 am
A new added feature I would like to see (when using Winbox to a client Mikrotik) , would be the ability to Tools-->Telnet-->Select (*) telnet and also select a port # to telnet to (and the same for SSH).
Example: Lets say a client Mikrotik has a natted LAN IP address of 192.168.1.1/24 and there is a web server on IP address 192.168.1.20 (possibly not running a non-standard port).
Normally, you can do a telnet to IP-Address:Port# , and when it connects, you can simply type in "GET /" to verify the web server is running. However, if you can't telnet to an alternate port, then it becomes much harder to test out port - which might require a TCP/IP port forward on the outside WAN interface to the inside - then originate you telnet to alternate port from another machine.
Lets say you have a web server locally connected to the same network as your work station - try this: Telnet ip-address:80
At connection , you might not see anything - however type in this: GET /
And you will get some web server information so that you know it is actually running.
Sob
Wed May 16, 2018 2:17 am
I agree that selecting port in Tools->Telnet should be possible, but until it happens, you can do it from Terminal, it already works there:
/system telnet address=192.168.1.20 port=80
GuillermoHA
Tue May 22, 2018 6:30 pm
-Will be great in /ip hotspot active see directly what "user profile" are using without using address-list
WirelessRudy
Tue May 22, 2018 8:22 pm
Those units that have multiple PoE out ports under 'Health' menu the option to read the amps - watts of the input. Thus we can see what the total consumption is for attached devices AND this unit itself.
For many battery/solar operated units it's quit handy to see what the 'real' average power consumption is for a given actual setup.
(It would be even nicer if under 'graphs' a graph could be displayed for the last 24 hours of voltage amp/Watts consumption. Sometimes it is o so handy to know when batteries where charged (= high voltage) and when not (low voltage). The total power consumption also gives us a power budget over a 24 hour period. Power consumption depends on radio usage and that depends on actual data throughput. With a graph we can see if our actual power budget (batteries! Solar panels) are actually up to their task.
5nik
Fri May 25, 2018 12:03 am
It is possible add something like Web Aplication Proxy / redirector for HTTPS (SSL/TLS) trafic? Mikrotik will be able DNAT or redirect HTTPS(generaly SSL/TLS connections with SNI) for specific URL to another IP. It will be usable for hiding more HTTPS servers with diferent URL behind one public IP, or for very simple HTTPS (SSL/TLS) load balancing.
Wyz4k
Fri May 25, 2018 3:48 am
The woobm is awesome, but it lacks the ability to paste. Please add a "paste" button.
bdallen
Mon May 28, 2018 3:43 am
no, the list does not influence our priorities, just gives us ideas about what people want to see.
Sorry Normis, and no disrespect to you, but what does influence this list? People screaming for proper vrf seperation, IPSec VTI Support, DHCP Option 82 Snooping in ROS, Proper BNG Features, IPv6 Needs alot of fixing, BFD (YMMV), BGPv4 MIB and many others.
But yet Kid Control turns up on a CCR??
Confused :S
anav
Mon May 28, 2018 5:01 am
Apparently IPSET uses the hdd memory in my HEX for address tables.
I am very low on HDD due to lists being used.
This is despite the fact that Ihave a 16 gig sd card and 16 gig usb stick in the unit.
FEATURE REQUEST: REMOVE IPSET limitation of internal HDD and be able to apply lists to usb or sdc.
As to the question above rather amusing but a good example of something that doesnt make sense.
Typically easy and no usage of capacity wins - or Kid Control is a billioinaire and wants his feature (or significant segment of market) etc......
pe1chl
Mon May 28, 2018 10:37 am
ipset uses in-memory storage to be able to lookup an address quickly. the CPU can just walk along the list (using hashes and/or tree), without reading from SD card first.
when it would be on disk, it would take far too much time to do the lookup to do it in the routing path.
so it does not make sense to request ipset (ip firewall address-list) to be put on disk instead of in memory.
when your ipset uses too much memory, you should back down on the use you make of it and/or buy a router with more memory.
I don't think it makes any sense to have a list that is to be checked in the routing path to be offline on disk. That would only be useful in the proxy service.
anav
Mon May 28, 2018 2:08 pm
Thanks pe1chi, that makes sense.
Oh well I have two hexes, perhaps I could connect them with a vulcan mind meld and have more memory available.
Which model do you suggest for a home owner, who is only trying to keep the dogs away from the home network.
pe1chl
Mon May 28, 2018 2:55 pm
The hEX r3 has 256 MB of RAM which is normally enough for quite large lists.
You should not try to make a dynamic address list to which items are added e.g. upon unexpected incoming traffic, as this makes the list grow very large.
It is better to focus on firewall settings to keep all that traffic out. That should be easy to do on the typical NAT routing config used at home.
Just don't allow remote management (i.e. do not allow any input from internet except for established/related).
When you really have to have remote management, configure some form of VPN service on the router and allow management only from authenticated VPN users.
anav
Mon May 28, 2018 3:36 pm
I understand, I have fixed lists, based on firehol type information, and I do have some spammer,synflooder,scan lists but they are weighted or need x connections so they are rarely entered.
That said I have 3K left in hdd memory. Will see what I can do to reduce fixed lists..........
wfuzatto
Wed May 30, 2018 7:01 am
What about a fixed VHT data rate for AC device? It would be a nice feature!
doneware
Trainer
Trainer
better ping feedback in scripting
Wed May 30, 2018 10:03 am
can we have at least the summary of the sent/received ping probes returned as values? all we have right now in the number of successful responses received.
[me@router] > put [ping 8.8.8.8 count=3]
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 8.8.8.8                                    56  57 9ms
    1 8.8.8.8                                    56  57 10ms
    2 8.8.8.8                                    56  57 8ms
    sent=3 received=3 packet-loss=0% min-rtt=8ms avg-rtt=9ms max-rtt=10ms
3
Wyz4k
Wed May 30, 2018 10:12 am
In the scripts and schedules editor in winbox can we please add the ability to select all - ie ctrl a? At the moment in order to select a big script you have to manually drag from start to finish.
Sob
Wed May 30, 2018 4:14 pm
@Wyz4k: There's also Select All in right-click menu.
adziahel
Thu May 31, 2018 1:31 am
DNS-over-HTTPS or DNS-over-TLS, in that order of preference
Wyz4k
Fri Jun 01, 2018 3:18 am
There is indeed. Thanks Sob, you are a legend!
anav
Wed Jun 06, 2018 4:34 pm
Hi Chupakha I just wanted to say thanks for your patience, I am just a tad slow and finally get what you are saying.
Yes, without even knowing it I was using the up and down arrow functionality everywhere and thus should have realized what I was in effect doing on the extra page.
I still would like a note at the bottom of the page (text is cheap right?) for new users "Opening a field activates shown parameters, if Apply or OK is selected."
eroberts9
Fri Jun 08, 2018 5:15 am
I'm sure this is an extreme long shot for a feature but having multiple radios broadcasting same SSID and channel appearing as one AP to a client.
Not WDS AP/Slave where the bridge is wireless as it currently can work but having all radios connected Ethernet.
Chupaka
Fri Jun 08, 2018 1:11 pm
So what's the actual 'feature'? You just use same SSID and same security settings - and it works like this. Even if you mix MikroTik, TP-Link, Cisco APs, etc. :)
pe1chl
Fri Jun 08, 2018 1:54 pm
That is one way of doing it, but it does not really work well. Clients have to "hop" between access points and this often only happens when the signal has
become too weak to maintain the connection, so before that the client already experience bad performance.
There are other competitors (Aruba networks, Ruckus, Zyxel and maybe others) who offer true seamless roaming where all your access points have the
same MAC address and the client connects with a "virtual" access point (a controller or a function in a master AP) and remains connected to that, only
the radio layer solves the location issue (all access points try to receive the client, the one who receives it strongest is used to send data to the client).
Indeed it is a nice feature, of course it has drawbacks but it performs best when clients are wandering around in a building or park.
TomjNorthIdaho
Fri Jun 08, 2018 6:00 pm
When using multiple WiFi systems with the same SSID and wireless security settings, you should NOT have the APs perform NAT , but instead those APs should bridge the wireless wlan to an Ethernet network. Then have central core router perform NAT & DHCP on the inside LAN that the AP wireless clients are bridged to.
This will then permit client seamless roaming from AP to AP. When a client roams in your network of APs, the client maintains the same IP address.
If your APs are all doing NAT, then when a client roams to a different AP, you can experience all kinds of problems and end up with of two of the same IP address on the same network.
Chupaka
Fri Jun 08, 2018 6:27 pm
Yeah, but pe1chl tells about old wifi clients who cannot switch to another AP without timeout/diassoc on current AP. Anyway, by wifi standards it's up to the client how to select APs and when to switch...
TomjNorthIdaho
Fri Jun 08, 2018 6:45 pm
One of the problems with RFCs and standards is that often 90% of manufacturer network devices only follow RFCs and standards by only 90%.
When you think about it - it's amazing that the Internet even works with all of the different connected brands of devices
pe1chl
Fri Jun 08, 2018 10:51 pm
There are standards for fast handover but they weaken the security. Also there are standards to provide roaming information so the clients know what other AP's to look
for, still there is trouble all the time. Those seamless roaming networks do not have those problems because the controller decides how it operates and it has complete
knowledge of the topology. However, MikroTIk does not have products in that segment (and neither does Cisco, for that matter).
eroberts9
Fri Jun 08, 2018 11:50 pm
There is only one association, a client does not reassociate if they move from one AP to another. There is not a loss of service when a client moves to a closer AP.
Somewhat like WDS works now via WDS AP -> WDS Slave except backhaul isnt wireless, its via ethernet.
lesnikov
Sat Jun 09, 2018 4:22 pm
Hey,
Probably posted before but here goes again. We need 802.1x integration on routerOS for wired ports.
Been looking for this feature for years now...
anav
Mon Jun 11, 2018 3:24 pm
Due to SIP issues, a friend pointed out this thread.
viewtopic.php?t=129048
So requesting that mikrotik address the issues discovered .
Best to let the experts read and absorb just provided the following quotes....
The issue is stated as...... " A limitation of the UDP + NAT schema" in the mikrotik engine.
or stated another way......
"the conclusion is that the connection tracking engine's architecture on RouterOS is the root cause of this"
"The issue here is that Mikrotik's acceleration tactic of skipping the nat table for packets found in the connections list is the fault"
DanielJB
Tuneable wireless keep-alive interval
Mon Jun 11, 2018 5:21 pm
By default, RouterOS pings all idle wireless clients every 60s. With many associated clients over a larger area (therefore low bitrates) with 1-2 active at any given time, network efficiency is reduced and client battery life is reduced.
Disabling keepalive-frames causes issues wherein clients are listed in the registration table, but the wireless interface goes down.
Please make "/interface wireless set keepalive-frames" an adjustable delay, so we can set eg 300s rather than enabled at 60s or disabled.
Thanks!
Daniel
DummyPLUG
Fri Jun 15, 2018 10:10 am
Please add port redirect in IPv6 firewall, will much easier to force all http/https redirect to proxy and redirect all free/public DNS server access back to local dns server.
p.s. newer linux kernel and ip6tables already support this, hope routeros will have this feature as well.
craterman
Sun Jun 17, 2018 12:34 pm
OSPF and BGP Graceful Shutdown
TomjNorthIdaho
New type of APs - BaseStation - long range - PhassedArray
Wed Jun 20, 2018 9:34 pm
I would like Mikrotik to consider a new type of BaseStation AP
- Something that is possibly modular (where antennas can be mounted to other antennas to form an array of small spot-beam sectors.
- Something that falls under FCC point-to-point higher power rules
- Something that functions simular to a beam-steering phassed-array (where the system acts list a point-to-multi-point system).
Vivato (now out of business) did have two models of phassed-array outdoor BaseStation APs (rated at 2,000 wireless clients per Vivato BaseStation). I still have 16 of them. When Vivato went out of business , I switched over to Mikrotik - because firmware updates for the Vivato were old & dated. Note - I had both Google and the DOD performed testing on my Vivatos phased array BaseStations 10 years ago. They told me they were BLOWN-AWAY because of the long distance (10 miles) they could acheive with a stock notebook computer. Each set of 4 Vivatos (360 degree coverage) were 10 miles apart and they were able to roam from Vivatos to other Vivatos 10 miles away when both Google and the DOD performed their almost month long testing. Each Vivato had around 100 slot-beam antennas. The Vivatos were able to receive & transmit from/to multiple wireless clients at the same time. Their technology used beam-steering with MAC switching on the slot-beam antennas. Depending on where a wireless client was, a client might have a dozen antennas per Vivato they were connected to. Also, the Vivato BaseStations would slightly delay the tx of some antennas to form a directional beam (similar to how a radar system works in a fighter jet - no moving parts - beam steering).
Another company just announced a BaseStation (Ubnt) which is claimed to support the following; 5 Gbps real Aggregate wireless throughput , MU-MIMO , 1,500 wireless clients , 10-Gig Ethernet interface (some serious stuff here !!!)
If the Ubnt BaseStation performs even close to what my Vivatos were doing , then this is a real serious contendor for high-density high-volume high-throughput system.
The current issue today with trying to achieve this with current Mikrotik hardware is that it would require a 120 foot tower physically saturated with almost 100 narrow-beam high-gain overlapping Point-to-Point APs and dish antennas to do the same thing.
I would like to see a Mikrotik system that can achieve the same thing.
WirelessRudy
Re: New type of APs - BaseStation - long range - PhassedArray
Thu Jun 21, 2018 12:41 pm
Sounds interesting. But is part of the evolution in wireless also not that now the spectrum is saturated where 10 years ago is was hardly used? I mean, my first Mikrotik 2,4Ghz 802.11b outdoor AP on a 8dBi omnidirectional had no problem to communicate with my laptop at some 300-400 meters away. And that communication was the sending of an e-mail.
Now I am glad my new dual chain 802.11a/b/g/n/c laptop still has a connection to a 18deBi dual chain 90º sector with Netmetal 30dBm radio some 50 meters away. And I am not interested in sending an e-mail, it needs to be a 4K streaming full duplex Skype video conversation (I am a bit exaggerating).....
10 years ago in a 2,4Ghz scan I'd performed all I saw was my own AP..... Now a scan reveals some 100+ radios..... Ok, we have 5Ghz now, but that is sort of similar. My 5Ghz AP's easy pickup 20 other AP's.... and there must be several hundreds of CPE's communicating with them.
I must mention though we have one 'alien brand' AP working on a village that is also full of 5Ghz AP's and users, but they work with their own protocol on the 5Ghz band. They work with 4 antenas on one AP and then each of these 60º sectors are overlapping to get some 200º reach. The AP works on 10Mhz wide channels but each antena has its own frequency slightly different from the others. Now the OS switches connected CPE's to that sector with a good enough signal to supply the top PHY rate achievable that carries the least traffic. The result is that each of the connected clients have no issue to reach the OS limited top download of just over 30Mbps and sustain that for prolonged times. Basically each sector can sustain a full 30+Mb download to a single client thus the AP can do 4 at once.... in a 10Mhz channel! Low latency, sustained speed...... Try that with a Mikrotik 20 or even 40Mhz normal Wifi solution....
Over the same village we have 2 more AP's, both Netmetal and working 5Ghz NV2 or plain 802.11ac but 30Mbp is only possible if that client is the only one using the AP and only peak speeds. This is with -45dB signals all duo chain 20Mhz wide channels.....
So yeah, there are better ways of doing wireless.....
TomjNorthIdaho
Thu Jun 21, 2018 6:48 pm
WirelessRudy
un-releated to this forum topic ...
Back in 2002, I did a site-survey in all areas we now service (20+ towns/citys). I found zero APs.
Earlier this year , I did a site-survey using 1,000 customer Mikrotiks I manage (I used a Linux script). I found several thousand different APs.
datajerk
Fri Jun 29, 2018 4:02 am
If you are only interested in the switch/router the woobm is connected to via USB, then use telnet instead. You're telnet client C&P will work just fine.
Wyz4k
Fri Jun 29, 2018 4:46 am
This is the feature requests channel. I am requesting a very basic feature that will take all of 30 seconds for somebody to add.
New request:
[admin@MikroTik] > { :put [:resolve www.example.com]; :put "lala";}
failure: dns name does not exist
Please add a way to read the error ("failure: dns name does not exist" in the error above) when using the on-error catch below.
:do {
} on-error={ :put "resolver failed"};
raymondr15
Mon Jul 09, 2018 9:39 pm
Please add support for USB booting on RouterBoards so we can have the ability to install RouterOS onto a USB drive.
Maybe in NetInstall also make it possible which device RouterOS should be installed to if there is more than one. ie: nand, USB...
Reason 1: In case something happens to the nand chip on the RouterBoard.
Reason 2: For testing purposes to test RouterOS releases without making changes to the nand config/software.
Reason 3: In case someone is doing heavy changes all the time that will put undue strain on the nand.
Wyz4k
Tue Jul 10, 2018 6:33 am
Hi everyone,
Please add a way to authenticate with the Mikrotik router using a certificate similar to how you can authenticate with an ssh server using a private/public key pair.
Also then please add a way to disable username / password logins.
Chupaka
Tue Jul 10, 2018 12:34 pm
Hi everyone,
This is already available for SSH. You just upload your public cert to the router - and now you can connect only with this cert, unless you set
/ip ssh set always-allow-password-login=yes
Wyz4k
Tue Jul 10, 2018 1:03 pm
Hi everyone,
Not for winbox though.
genesispro
Tue Jul 10, 2018 1:19 pm
I would also like to be possible to set winbox to a state where changes are pending and the moment all changes done to be able to say commit.
If for example we have the wan port in a bridge with a dhcp-client on the bridge and the we want to remove it from the bridge remotely and add the dhcp-client to the ether1 for example we can't.
To avoid loosing remote access you would need to modify the dhcp-client to the ether1 but you can't because it is a child!
So one needs to remove it from the bridge port and then modify the dhcp-client which would of course has to be done locally... or with a script!
Chupaka
Tue Jul 10, 2018 1:27 pm
Yeah. Also not for WebBox, not for Telnet, not for API...
Anyway, your initial message was not about WinBox. If you need WinBox - use SSH with port forwarding for WinBox :)
Chupaka
Tue Jul 10, 2018 1:31 pm
Not a script, but in a Terminal:
  /interface bridge port remove [find interface=ether1]
  /ip dhcp-client add disabled=no interface=ether1
or
/interface bridge port remove [find interface=ether1]; /ip dhcp-client add disabled=no interface=ether1
genesispro
Tue Jul 10, 2018 1:50 pm
Well I use winbox and/or API so with neither I could do it remotely since I would loose at the first step the remote connection
or
Chupaka
Tue Jul 10, 2018 2:18 pm
Just press Terminal on the left of WinBox. If you use "{ }" - commands inside of brackets will be executed when you press Enter after the bracket. Like this:
[admin@s.internal] > {
{... :put "here"
{... :put "we"
{... :put "go!"
here
we
go!
nicutdk
Mon Jul 16, 2018 1:27 pm
I want to make a suggestion for IP cloud
So...
Will be nice to have feature to associate IPcloud from routerOS with Mikrotik Account to manage all mikrotik router.
For Example I have many clients and I make my own structure to manage. If I forgot to add is to hard to put again.
Regards,
pe1chl
Mon Jul 16, 2018 2:18 pm
A WiFi TDMA mode that is compatible with UBNT airMAX.
We usually have a mix of MikroTik/UBNT access points and clients in our network so we can only use bare 802.11 even when TDMA would perform much better.
Alternative: an IEEE standard for this mode that is implemented by both companies.
pe1chl
Tue Jul 17, 2018 10:36 am
Netinstall for Linux, or documentation of the netinstall process so it can be programmed for Linux by someone else.
diode
Tue Jul 17, 2018 12:24 pm
Having an integrated 5 GHz Backup in LHG 60.
Now I need to mount 2 dishes plus a HEX POE for power ...
WirelessRudy
Tue Jul 17, 2018 2:29 pm
Now you'd wish manufacturers to give one of their main tools to keep clients with them away...
tdma is 'proprietary' protocol. Meaning every radio manufacturer can deviate from the IEEE standard to improve (or at least try to...) the standard on their own. Hence they do and each and every manufacturer has its own ideology and arguments to do it the way they do.
And why should Mikrotik allow Ubiquity to use their standard, or vice versa. And others?
Many wisp made a choice some years ago to go for one brand. Now they are 'married' to that brand if they use tdma. Imagine tdma could be freely used in-between brands. Mikrotik probably would have been bankrupt by then since many WISPs would over time then have move to other platforms.
And to show how complicate it is anyway. The eCambium 'elevate' product line was supposed to be working with 3rd party devices. So far after 2 years of promises it still only worked for Ubnt devices and I believe one model of Mikrotik.
So if you really want to stick to a 'multi brand' network you have to stick to plain 802.11 and to be honest, if you use 'ac' with good antennas and properly configure (RTS/CTS!) that protocol might work in several circumstances better then tdma what I already proved in some posts and just the last week still see is the case. Even after the latest ROS v.6.42.6 I have some P2MP network running in 802.11 instead of NV2 because it give much more capacity for the single client and in total over the AP...
pe1chl
Tue Jul 17, 2018 2:47 pm
We are operating an amateur radio network and we do not control the manufacturer of equipment chosen by the users.
And in fact, the product gamma of the two main manufacturers has been varying over time to give preference to one or the other.
e.g. before the LHG there was no cheap MikroTik user device with some gain, the SXT was too small for many users.
UBNT has the AirGRID devices which, although single-polarization, work over longer distances.
Now with the LHG this has changed, but we still have:
- sites with UBNT AP and a mix of AirGRID and LHG/SXT clients
- sites with MikroTik AP and a mix of AirGRID and LHG/SXT clients
Pracitce shows that the UBNT AP works better in the presence of interference (less problems with spurious RADAR detection)
but the LHG is the better choice for user equipment because it uses both polarisations.
It would be nice if both of them could operate under the same managed access protocol. I have no idea of the internals
of the different protocols now in use. The term TDMA is a bit worrying, hopefully (and likely) it does not mean there is a fixed
timeslot allocation for clients. A good protocol would use some form of round-robin polling of the clients with polling priority
dropping when traffic is low. Something more like DAMA.
I think when neither MikroTIk nor UBNT come up with some openness, the IEEE should publish a standard. Then both
manufacturers can do nothing but implement that standard (possibly alongside their own offering) or they would lose all
their marketshare to a manufacturer that does.
Cha0s
Tue Jul 17, 2018 4:32 pm
+1
Also it would be nice if a MikroTik installation itself can be a netinstall server for another RouterBoard.
pe1chl
Tue Jul 17, 2018 5:44 pm
And install of a clean new RouterOS in an inactive partition on a router with 2 or more partitions.
Router running from Active partition part0, download new npk files and do "install into part1",
optionally copy config from part0 to part1, set part1 to Active and reboot: new clean install without doing netinstall.
andreiroos
Wed Jul 18, 2018 4:26 pm
I saw that it is mentioned to have the ability to set limits in queues from child queues to be expressed in a percentage value of the parent, This have been mentioned about in 2012 (Saw it on tab 5). Would also like it to be implemented especially for the fact that our internet connections get throttled (shaped) at times and this would make life much easier to adjust only the parent queue to implement speed changes.
TomjNorthIdaho
Wed Jul 18, 2018 11:40 pm
Winbox proxy ???
It might be nice to be able to connect to another Mikrotik using the 1st mikrotik as a proxy to be able to connect up to a 2nd Mikrotik.
Where , an admin might not be able to directly connecte to the 2nd mikrotik, but if the 1st mikrotik can mac/IP connect to the 2nd then allow a winbox proxy connection through the 1st mikrotik to a 2nd mikrotik.
ditonet
Forum Veteran
Forum Veteran
Thu Jul 19, 2018 1:04 am
@TomjNorthIdaho
RoMON
https://wiki.mikrotik.com/wiki/Manual:RoMON
Regards,
pe1chl
Thu Jul 19, 2018 11:43 am
@TomjNorthIdaho
RoMON
RoMON works only over L2 transparent links. A proxy could be operating at IP level. A nice feature would be to add an IP-level layer to RoMON so you can
extend the RoMON network like this:
PC <---------IP link--------------->Router1<----------L2 link ----------->Router2
and then access Router2 "via RoMON" from the PC. This can now be done only at commandline-level, not winbox.
mikruser
Long time Member
Long time Member
Thu Jul 19, 2018 12:04 pm
craterman
Thu Jul 19, 2018 2:31 pm
Please make the opportunity to make rules for the firewall with timerange starting today and ending at some time tomorrow. For example from 20:00:00 to 06:00:00
mrz
Thu Jul 19, 2018 2:37 pm
[admin@rOS] /ip firewall> filter add time=
Time ::= [!]Start-End,Day
Start -- 0s..1d (time interval)
End -- 0s..1d (time interval)
Day ::= sun|mon|tue|wed|thu|fri|sat[,Day*]
WirelessRudy
Fri Jul 20, 2018 1:08 am
When testing P2MP networks for best throughput and latency you need to run a test from several CPE's (in a 'all MT' network) and then switch between the different protocols and setting to see what gives best result.
Each time though the connection with AP is lost due a config change, the CPE needs to be opened up again in its winbox session. And each time all settings for the bandwidth test are gone... each time you need to fill these again..
Can bandwidth test not be made to at least remember its settings? It has to be stopped when the CPE drops the connection over the interface the test runs, but it would be o so helpful if the settings for the test just come back after the winbox session is opened again. Just click on 'run' and the test can run again..
Would make it a great time saver in troubleshooting and fine tuning P2MP networks...
metricmoose
Sat Jul 28, 2018 5:25 am
I would like some way of hiding profiles in usermanager from the customer-facing parts, like in the signup and user pages. This would allow us to generate vouchers that will be priced differently or have different limitations than what's available on the self-signup, without making those packages available to self-signup customers.
wpeople
Sat Jul 28, 2018 4:21 pm
Winbox proxy ???
If you can connect to 1st mikrotik via TCP (ssh), than using putty, you can configure additional port forwards on the fly.
(using linux, port forward should be added at connection - windows based putty allows on the fly)
Like: ssh into box1, open putty configuration (connection/ssh/tunnels) add new tunnel: 8291 -> 192.168.1.2:8291
that means connection to localhost:8291, putty will grab those packets, push to ssh server (remote mikrotik) what forwards them to 192.168.1.2:8291 on remote site.
and vice versa
taduikis
Sat Jul 28, 2018 5:53 pm
I use The Dude for this. Leave the Btest windows open and configure as you want..
Wyz4k
Wed Aug 01, 2018 9:04 am
Please implement a proper auto channel selection that looks at the usage and noise floor of each frequency in the scanlist before choosing a channel.
And not one that just counts how many devices it sees per frequency (as per now): viewtopic.php?f=7&t=122063&p=677377#p600476
TomjNorthIdaho
Wed Aug 01, 2018 6:05 pm
+1
When a WISP has multiple APs with the same SSID (nv2 APs), often a client will not select the best AP but rather the 1st AP it finds.
I would like to see some client optional settings that will allow an administrator to define some parameters when scanning for an AP to connect to. Such options might include:
- Scan time prior to making a connection to an AP
- AP selection by one of the following:
-- Strongest AP signal strength
-- Best Signal To Noise ratio
-- Best estimated CCQ
-- Fastest connect receive rate
The current client scan to find an AP is not adiquate and very often does NOT select the best possible AP when there are many candidate APs to connect to.
Example … As a LAB test … If you use SuperChannel with a scan list of 5000-6000 and you have 30 APs. The clients will probably NOT select the best AP to connect to. And also some APs might never get a connection and some APs will get almost all of the client connections. There needs to be a better system for client to AP load distribution so that multiple APs balanced with near equal clients per AP.
Or one possible solution --- I suspect the current client scan for AP mechanism scans starting at the lowest frequency in the scan list then walks up through higher frequencies. I suspect a better client scan system might be to randomize the scan list search order to find an AP. Then multiple APs might have near equal client connection counts.
DmitryAVET
Wed Aug 08, 2018 11:07 am
Graphing is very cool tool, but... it killing Flash when using "Store on Disk" option (Interface/Queue/Resources).
7 days = 100K+ writes to flash...
Please, add posibility to store data on external storage, like USB Flash or microSD card.
Wyz4k
Wed Aug 08, 2018 11:13 am
Please add all items that are in wireless -> registration table to CAPSMAN -> registration table. I regularly use the last-ip column for example which is not available in CAPSMAN.
mlow
Thu Aug 09, 2018 3:10 pm
I'm throwing this on the list a second time.
Support for RFC6939, i.e, the client link-layer address option, enabling a DHCPv6 relay to pass a client's link-layer address (MAC address) as an option (number 79) to a DHCPv6 server, whereupon the server can use that information for static lease reservation, etc.
The need for such is currently described on the DHCPv6 wikipedia page, here: https://en.wikipedia.org/wiki/DHCPv6#RF ... ess_Option
dimonana
Thu Aug 09, 2018 3:23 pm
I'd like to ask to complete IPSEC/IKEv2 implementation.
Motivation is : lots of VPN providers - NordVPN and others - are moving to that, leaving L2TP/IPsec disappearing.
Lombart
Mon Aug 13, 2018 6:34 am
add dual-wan mode at quickset
it realy help for us
thank you
liwest_alx
Mon Aug 13, 2018 1:30 pm
CRS112-8P-4S:
SNMP Oid's for PSU1 + PSU2 Voltage or at least a status.
Currently only Temperature under system health supported.
Jotne
Mon Aug 13, 2018 1:33 pm
CRS112-8P-4S:
So you see it under /system healt print ?
If so you can us Script/Syslog/Splunk to graph it.
See here on how I monitor Temperature.
viewtopic.php?t=137338
magnavox
Mon Aug 13, 2018 9:23 pm
Hi Mikrotik Staff,
any chance for implement MLPPP server ?
Read: viewtopic.php?f=1&t=66192&p=679772#p679772
eroberts9
Tue Aug 14, 2018 4:15 am
DFS certification for the US .
paulct
Tue Aug 14, 2018 10:53 am
Until there is version 7, or whatever it is called. Can we get a BGP peer priority?
e.g say if you need to upgrade ROS, swap out a CCR, or reboot - each BGP is assigned a priority and receives/sends routes according to that policy in order?
e.g:
Peer 1 - default route (priority 1)
IX route server - priority 2
IX2 route server - priority 3
Private peer 1 - Priority 4
Private peer 2 - Priority 5
In that way, essential peer routes are loaded into the routing table first according to what you decide. This would help when provider A peers on a route server and you privately peer with them - rather load the routes from the route server first and so on. We know ROS is not great loading thousands of routes - but at least with this method there is some control.
Maybe even a timer or such?
Basically a stop gap solution until we have higher clocked CPU's / better software.
LucZWFM
Tue Aug 14, 2018 1:06 pm
Making the headers of the tables sticky, so when one scrolls down one still sees the header...
What I mean with header:
Make the gray part sticky please. It's much more comfortable that it will not dissapear when scrolling down...
Thanks!
TomjNorthIdaho
Re: Feature requests - SNMP OID Ethernet link speed
Tue Aug 14, 2018 5:59 pm
It would be great to have SNMP OIDs for Ethernet link speeds. (if they are there , I have not spotted them yet).
These could be very useful to detect when an Ethernet link changes link speed. Such as when what is/was supposed to be a 1-Gig link changes to a 100 meg link.
Omniflux
Tue Aug 14, 2018 8:22 pm
$ snmpwalk -v2c -c public 192.168.88.1 |grep ifSpeed
IF-MIB::ifSpeed.1 = Gauge32: 0
IF-MIB::ifSpeed.2 = Gauge32: 1000000000
IF-MIB::ifSpeed.3 = Gauge32: 1000000000
IF-MIB::ifSpeed.4 = Gauge32: 0
IF-MIB::ifSpeed.5 = Gauge32: 100000000
IF-MIB::ifSpeed.6 = Gauge32: 1000000000
IF-MIB::ifSpeed.7 = Gauge32: 0
IF-MIB::ifSpeed.8 = Gauge32: 0
IF-MIB::ifSpeed.9 = Gauge32: 1000000000
IF-MIB::ifSpeed.10 = Gauge32: 1000000000
IF-MIB::ifSpeed.12 = Gauge32: 100000000
IF-MIB::ifSpeed.14 = Gauge32: 1000000000
IF-MIB::ifSpeed.15 = Gauge32: 0
IF-MIB::ifSpeed.17 = Gauge32: 0
IF-MIB::ifSpeed.18 = Gauge32: 100000000
IF-MIB::ifSpeed.21 = Gauge32: 10000000
IF-MIB::ifSpeed.22 = Gauge32: 0
IF-MIB::ifSpeed.24 = Gauge32: 0
IF-MIB::ifSpeed.25 = Gauge32: 1000000000
StubArea51
Trainer
Trainer
Tue Aug 14, 2018 10:53 pm
+1 !!!!!!
pe1chl
Tue Aug 14, 2018 11:06 pm
As was written above, this feature is already available. And has been for as long as I use RouterOS. So "that could be" and "+1" is completely meaningless.
Jotne
Wed Aug 15, 2018 8:25 am
It works fine on my hEX RB750Gr3
snmpwalk -v2c -c public 192.168.0.1  .1.3.6.1.2.1.2.2.1.5
IF-MIB::ifSpeed.1 = Gauge32: 1000000000
IF-MIB::ifSpeed.3 = Gauge32: 0
IF-MIB::ifSpeed.4 = Gauge32: 1000000000
IF-MIB::ifSpeed.5 = Gauge32: 1000000000
IF-MIB::ifSpeed.8 = Gauge32: 1000000000
snmpwalk -v2c -c public 192.168.0.1 .1.3.6.1.2.1.2.2.1.2
IF-MIB::ifDescr.1 = STRING: ether1-Wan
IF-MIB::ifDescr.2 = STRING: bridge_vlan1
IF-MIB::ifDescr.3 = STRING: ether3
IF-MIB::ifDescr.4 = STRING: ether4-Win_Server
IF-MIB::ifDescr.5 = STRING: ether5-Linux_server
IF-MIB::ifDescr.6 = STRING: pptp-in1
IF-MIB::ifDescr.8 = STRING: ether2-Cisco-Switch
IF-MIB::ifDescr.9 = STRING: bridge-vlan20
IF-MIB::ifDescr.10 = STRING: eth2-vlan20
And on hAP lite 941-2
snmpwalk -v2c -c public 192.168.0.80 .1.3.6.1.2.1.2.2.1.2
IF-MIB::ifDescr.1 = STRING: wlan1
IF-MIB::ifDescr.2 = STRING: ether1
IF-MIB::ifDescr.3 = STRING: ether2
IF-MIB::ifDescr.4 = STRING: ether3
IF-MIB::ifDescr.5 = STRING: ether4
IF-MIB::ifDescr.6 = STRING: bridge
snmpwalk -v2c -c public 192.168.0.80 .1.3.6.1.2.1.2.2.1.5
IF-MIB::ifSpeed.1 = Gauge32: 50000000
TomjNorthIdaho
Wed Aug 15, 2018 7:26 pm
It would be nice if there was a "print oid" output result that contained the OID for ethernet link speed.
mikruser
Long time Member
Long time Member
Sat Aug 25, 2018 3:09 pm
Feature request: AES hardware acceleration for OpenVPN
tigro11
Tue Aug 28, 2018 12:11 am
hi guys, it seems to me that it is still not possible to change the date format in dd/mm/yyyy. It would be very useful as I also work with userman reports.
Does anyone have a solution?
thank you
Valerio
doneware
Trainer
Trainer
Wed Aug 29, 2018 1:00 am
rfc 6286 - AS-wide Unique BGP Identifier for BGP-4 support for routerOS BGP.
it relaxes some strict definitions: routerid can be now an arbitrary 32 bit unsigned integer, while the older definition restricts it to "valid unicast address".
this breaks BGP compatibility with mikrotik devices right now if not taken in consideration.
in general you only need to remove the check that was required in rfc4271.
this needs to be worked out with IPv6-only devices where you don't have no IPv4 address to be used as bgp identifer.
TomjNorthIdaho
Wed Aug 29, 2018 1:05 am
A somewhat simple feature I would like to see in ROS.
The ability to restore a backup and have the option to "Do Not Re-Write MAC Addresses"
it would be great to be able to restore a Mikrotik and have the option to NOT re-write every ethernet & wlan & bridge MAC address
TomjNorthIdaho
Feature Request CLI site-survey include Radio-Name
Wed Aug 29, 2018 10:17 pm
I would like to see the CLI site-survey include "Radio-Name" in the results.
When using winbox, you can see "Radio-Name" in the site-survey results - however when using the CLI such as my example below:
/interface wireless> scan wlan1 duration=90 save-file=SiteSurvey.txt
the CLI site-survey does not include "Radio-Name" in the results.
FYI - I am using NV2
FYI - in all of my Mikrotik APs, I use radio names similar to this: Radio-Name 172-16-10-89-Mica-N/AC-2x2
FYI - I can't simply use SSID , because I have hundreds of Mikrotiks APs using the same SSID.
Without the radio-name in the survey results, it makes it difficult to quickly identify which APs are actually being seen and I have to refer back to MAC addresses and frequency to determine which AP is actually being seen.
DummyPLUG
Mon Sep 03, 2018 5:40 pm
resend syslog email if fail to send, currently any syslog email will be discard if fail to send which raise a problem if wan or mail server down.
Simono
Mon Sep 03, 2018 5:56 pm
Support for ups APC Back-CS via USB cable.
tigro11
Mon Sep 03, 2018 8:35 pm
thank you
Valerio
news?
thobias
Mon Sep 03, 2018 9:22 pm
1. IP firewall address lists could include one another (or firewall rules could match multiple lists at once, e.g. "src-address-list=list1,list2").
Please this to be able to use several lists on a single rule without having to copy them together manually or by scripting.
http://prntscr.com/kq653h
Also do the same on src/dst-address and in/out-interface so we don't have to create a list if just needing a rule with two or three addresses as it makes config more neat.
helipos
Wed Sep 05, 2018 12:14 pm
I would like to see something like triggers when an interface state changes, so router can run a script (like ip-up/ip-down on "real" Linuxes).
+1
pe1chl
Wed Sep 05, 2018 2:10 pm
The underlying Linux mechanism does have a "list of lists" feature so it would be easy to add a "list12" that has "list1" and "list2" as members and then specify that as src-address-list.
There is no support to have several lists or several addresses in a single firewall item. You can only do that by having several separate items and indeed that is what happens when you try that in Linux.
(you insert a simple rule with different addresses and when you look later you have several rules in your table)
Moky
Wed Sep 05, 2018 3:29 pm
I would like to suggest two things:
  1. Webproxy HTTPS support (any of two listed options or both):
    • Possibility to address HTTPS domains with SNI parameter like "tls-host" option in MikroTik filter (e.g. ability to create rules in webproxy with "tls-host").
    • MitM HTTPS decryption support with imported certificate which is trusted on client machines.
  2. NTP client option to show more information about NTP server (like "stratum" etc. - Cisco has a nice info about any configured remote NTP server).
Kind regards,
Moky
thobias
Wed Sep 05, 2018 4:12 pm
But what is preventing Mikrotik from making it possible to create hidden lists from several IPs specified in a single rule or having a rule match if IP exists in list A or list B?
w0lt
Long time Member
Long time Member
Feature requests: Winbox
Wed Sep 05, 2018 4:36 pm
1. Please allow the ability to make multiple window column selections instead of "one at a time".
2. Please move the "Torch" selection from the "Tools" to the "Main Menu" !!! :D
-tp
pe1chl
Wed Sep 05, 2018 5:56 pm
It would not be a good idea to do that because it introduces new possibilities for bugs.
It is also not good for your own network management.
On routers in complicated networks I have lots of address lists often with only a single address or subnet in them, sometimes 2 or 3, and I use them all over the place in the firewall.
That makes it much easier to maintain things, once you get the hang of it (and have a good naming convention).
I can understand the utility of having the list-of-lists feature so you can define a list which contains other lists as members, I sometimes have multiple lists containing the same addresses in different combinations, and that could be cleaned up this way.
TomjNorthIdaho
NV2 - increase NV2 client scan-for-AP b4 connect to AP
Wed Sep 05, 2018 10:47 pm
I need/want a longer nv2 client scan time prior to an nv2 client connecting to an nv2 AP (a new setting would be nice for nv2 scan time before connecting to a nv2 AP)
The wireless AP enviornment:
- The small town/city I am in has 20+ nv2 APs (soon to be 40+ APs)
- All nv2 APs are the same SSID
- nv2 APs do NOT receive near-equal nv2 client connection counts.
- almost 400 nv2 wireless clients
- sustained customer bandwidth during peak periods is always more than 325 meg
The problem:
- Almost always , nv2 wireless clients will connect to APs that are the lowest frequencies in the scan list
- Very often , nv2 wireless clients are not connecting to the best/strongest nv2 APs that are in the upper frequency part of a client nv2 scan list
- This mostly results in an un-blanaced nv2 AP customer-connected-load (where lower frequency APs normally take 80+ percent of all nv2 client connections.
- nv2 APs in the upper part of wireless nv2 client scan lists often only get 20 percent of all clients (the other 80 percent always favor lower frequency APs in the scan list)
Info - I believe that nv2 clients have a limited scan time prior to the nv2 client making a decision on what nv2 AP to connect to. I believe the client scan period needs to be extended/lengthened by about 250 percent longer. With a longer client nv2 scan time-period, nv2 clients searching for a nv2 AP can then choose the best nv2 AP to connect to instead of the lowest-frequency first-found nv2 APs.
If all nv2 clients could fully scan everything in the full (superchannel) nv2 scan list, then all APs would be better client-connect balanced -and- the entire nv2 network could run much faster because the lower frequency APs would not be saturated with nv2 client connections.
Mikrotik , is it possible to add a feature (optional setting) for nv2 clients to have more time to perform a nv2 client scan prior to connecting to an nv2 AP ?
I really like Mikrotik's hybrid version of TDMA ( nv2 ) , however the nv2 client scan time has always been a problem. Unlike 802.11 or nstream, nv2 clients do not background scan for better APs to connect or roam to. All client nv2 connections want to stay connected to the original nv2 AP they first connected to. Longer nv2 client scan times would at least get equal client-connect loads distributed evenly among all nv2 APs of equal signal strength found in the client nv2 scan list.
North Idaho Tom Jones
WirelessRudy
Re: NV2 - increase NV2 client scan-for-AP b4 connect to AP
Thu Sep 06, 2018 2:44 pm
Tom:
As far as I know nstream and 802.11 also cannot do a background scan and then connect/roam to the best signalled AP. The background scan is possible, but only to 'see' what is out there. The client stays connected to what he was. So its only a manual tool the operator can use which in NV2 indeed is not even available. But correct me if I'm wrong! Maybe you have some script that forces de CPE to switch to another AP when that other one has better signal?
Second; I agree on the scan 'low frequencies first'. I observed the same when running a scan or when I have a CPE that is allowed to connect to two or three different AP's (Even with different SSID's). If both frequencies come with roughly the same strength the low ones are picked up first and if allowed used to connect.
But why have free roaming clients to start with? If you are using NV2 I'd presume all your clients are fixed installations? Like we have.
I just make sure all clients that have the option to connect to 2, or 3 different AP's it connects to the best one upon my decision as an operator.
Because I know what the average usage is on each AP.
So if I have 2 options for a client to connect to, I'd look to which AP gives the best signal and pick that one. But if signals are good for both AP's I decide to make it connect only to the one with the best P2MP network. And here comes the amount of connected CPE's as well the signals they all have in consideration. I know how the AP's perform in general.
So I'd balance the client load then more based upon my insight as network operator which usually beast any automated process. (Don't forget that most data that could be used in an automated decision making process is variable anyway. Signals vary, traffic vary, which clients are generating traffic vary.. etc.)
As soon as the decision is made that specific client will be add into the 'access list' of that preferred AP, and that same preferred AP will be add as first listing in the 'connect to' list of the CPE.
I might have both units (AP + CPE) to know about the other but in the AP's 'access list' only in a 'disabled' function. So only in case AP1 goes down, I stil allows the CPE to connect to AP2 so at least we can still serve the client. (Most of the times we disable the alternative 'connect to' listing because the setback is that when we do an upgrade on AP1 the clients jumps to AP2. After that we can upgrade AP2 so the client jumps back but for some clients it might be the other way around. And sometimes you just need to reboot an AP and I don't want the kind of client to jump to the alternative AP)
This is all manual work. MT units are pretty reliable so it happens rarely we have to make use of a 'backup AP' because one AP goes down.
A semi automated proces as you suggest imho is hardly achievable. Even when CPE's would automatically populate AP's in a more balanced way by numbers of associated clients to AP, it still doesn't mean you really balance the load on an AP. It is still pretty expectable that one AP has much more traffic then the other. And that variate between those AP's too....
The client would be best connect to an AP with little (overall) traffic then one with high traffic even with only a handful of clients.
I think the experience of the operator is a much more better decisive tool then any automated proces performed in these little intelligent devices.
We set everything manual and in 98% of the case we never have to adjust or change the client's CPE preferred AP any more...
TomjNorthIdaho
Thu Sep 06, 2018 6:06 pm
Wireless Rudy
Thanks for your reply post
Re: Maybe you have some script that forces de CPE to switch to another AP when that other one has better signal?
I don't have a client script to do this. I am not that good of a programmer. However I think a client boot-up script to first scan and then have the script select the best AP and modify the scan list for the best AP. And - upon failure , re-scan and select the 2nd best AP and upon failure of ability to connect to any AP in the site-survey , the fall back to the default (or custom configured scan lists.
Re: But why have free roaming clients to start with? If you are using NV2 I'd presume all your clients are fixed installations?
correct
Here is an example of a potential issue with many nv2 APs and many nv2 clients:
- lets say you have a bunch on nv2 APs and a bunch of nv2 clients (all using the same SSID)
-- You have the ability to update the client ROS versions (no problem here)
--- When you update the ROS on your bunch of nv2 APs , there is a problem. When you update an nv2 AP and reboot the nv2 AP, nv2 clients are then forced to re-scan & re-connect to a different AP. After your ROS updates of your bunch of nv2 APs, you end up with the majority of your nv2 clients connected to the nv2 AP that has been up the longest and few nv2 clients connected to your nv2 APs that are the most recent updated/rebooted AP. This forces the Mikrotik network admin to manually bounce weak nv2 clients off of some nv2 APs so that they can again reconnect.
---- Thus , with 20 nv2 APs, updating those AP in sequence of AP#1, then AP#2 through AP#19, AP#20, you will end up with the bulk of nv2 clients connected to lowere # APs and fewer nv2 client connections to your higher # AP. Thus , it may well be worth it to have a nightly script fire off on all nv2 clients to auto-scan and re-distribute the client to AP connect loads. (my thoughts).
TomjNorthIdaho
Re: Feature requests (ability to view wireless capabilities)
Thu Sep 06, 2018 6:37 pm
Is there a feature to see/view the capabilities of a wireless wlan ?
If not , then I would like to see a new feature to show the wireless capabilities and possible settings.
My issue, I have more than 1,000 nv2 client Mikrotiks. I currently use a Linux expect script to sequentially connect up to each client and perform some commands. The results of the commands are stored in a directory on my Linux machine (results-directory/IP-address-of-client-mikrotik). I am then able to grep the results-directory for pattern matches I am looking for and with this list, I am then able to obtain a client list of IP addresses I am searching for.
I am searching for a method to find all client Mikrotiks that are AC capable, and/or Ceee capable, and/or 2x2 capable. My problem is, I don't know the client wireless capabilities without actually attempting to configure the wireless interface. Thus, it would be a nice feature to be able to print the wireless capabilities without actually making wireless configuration changes.
Simono
Thu Sep 06, 2018 7:58 pm
Address lists on Simple queue as target
WirelessRudy
Fri Sep 07, 2018 1:09 pm
How about performing an IP / neighbor command on your main router (that should 'see' all units) and order by device type? You'll immediately see if a units is 'n' or 'ac'. My antenas all have their designated AP in their name so I can then also set the filter and thus see in an instance which units are 'n' or 'ac' (and thus can do 80Mhz wide channel in 'ac') for each AP.
xxiii
Fri Sep 07, 2018 8:19 pm
Just ran into this issue today. Can't establish peering with a neighbor because of:
10:57:39 route,bgp,error Remote RouterId is not a valid unicast address: 247.255.0.240
ros 6.42.7
doneware
Trainer
Trainer
Fri Sep 07, 2018 11:12 pm
opened a support request for it earlier today:
Ticket#2018090722004616
Wyz4k
Thu Sep 13, 2018 3:26 pm
Please add the ability to authenticate with a ssh certificate in Winbox - thereby providing an alternative to passwords.
Yes, this is available for ssh, but lots of people (myself included) prefer using Winbox most of the time.
tnrclkr
Tue Sep 18, 2018 3:47 pm
Advanced management for cap devices,
it would be great if i can change my all cap devices user password, port, service, interface status etc.
pe1chl
Tue Sep 18, 2018 9:23 pm
Stop the use of the bundle package, deliver the routers with the packages required for typical home router use:
advanced-tools, dhcp, ppp, security, system, wireless (the latter only on devices that have wireless) and most important:
add some method in system->packages to download and install packages selecting them from a list of available packages on the download server.
This will make it easy for everyone to add the packages they require, no need to download and unpack zip files and update part of them to the router.
The required files are already on the download server, because upgrade of a router with separate packages downloads only what is required.
Maybe an index file would have to be added and it would be downloaded when you click the new "add package" button.
A list of available packages is displayed, you select one or more of them and click "download&install" just as when upgrading.
anuser
Long time Member
Long time Member
Tue Sep 18, 2018 9:46 pm
Within Winbox I would like to see a "reboot button" within capsman for all CAP devices
Reason: If you have 2 CAPSMAN controller in active-active configuration, you have CAP devices on both controllers. If you upgrade one of them the CAPs use the other controller to connect to. But they won´t go connect back to their primary controller. So we need a simple "reboot" button after which they will connect to the primary one.
TomjNorthIdaho
Tue Sep 18, 2018 10:43 pm
One of the things I would like to see for all new ROS updates/upgrades is more information as to what the new/fixed featured do.
Example - with the following two lines below - it is not clear what the problem was and what was fixed and what actually improved:
*) wireless - fixed wireless interface lockup after period of inactivity;
*) wireless - improved Nv2 reliability on ARM devices;
More information on new features & things fixed & things improved is almost always useful.
Even a URL in the upgrade menu for more information about the upgrade features/functions/fixes would be very much appreciated.
bennyh
Wed Sep 19, 2018 3:17 pm
I didnt find, but sorry if exists.
There sould be a new section, a table in webfig and in winbox for global variables with initial values.
TomjNorthIdaho
Thu Sep 20, 2018 4:30 am
A bit of fun - but a potential very useful tool …
Info - back in the late 1980s and early 1990s, early notebook computers did not have sound cards , however they ususally had the PC-speaker (in this case a piezo speaker was normally mounted on the motherboard and used for the beep sounds) , well back then there was a Windows piezo speaker driver that could be loaded which offered the ability to play anything that would come out of your normal sound card computer speakers.
Now thinking about Mikrotiks routers with basically the same piezo speaker on the mother board and 99 percent the same electronics, it could be a usefull tool to be able to play a small sound file to/out the Mikrotik piezo speaker. Software PC-motherboard-piezo driver to emulate sound cards have been available for almost 30 years.
I suspect all that might be needed would be an optional Mikrotik ROS package to drive the Mikrotik piezo to behave like a sound card speaker. The software drivers are already out there.
Now as to why this might be a usefull , nifty, handy tool on a Mikrotik ... Rather than a script playing beeps of varing levels , a script could possibly just play a small sound file. This could come in handy for script files that beep messages. Instead , a Mikrotik could announce something you want to hear and a person could know about right away rather than get an alert via another computer device. A WISP could possibly use something like this to play a sound file that contains "Warning - Internet WAN connection is down/up" and/or "Call your ISP tech support at phone number xxx-yyy-zzzz" and/or play any usefull sound file such as "Wireless network information - new device connected using WPA2 encryption". The sound files could be small files with high compression which could fit in the flash file system.
Any-ways , I think the ability for a script to play a sound file could be a very usefull tool.
And to really totally show off your Mikrotik router (such as at a trade show or something) , then have it play full blown music out the piezo --- that would get everybody stopping by your booth.
I've used such tools on old notebook 16 MHz CPU computers with motherboard piezo speakers only and even watched full blown movies with the piezo speaker drivers hundreds of times , it works. If the Mikrotik motherboard hardware is already there then how about an optional ROS package to enable the piezo to do much much more.
Sob
Thu Sep 20, 2018 5:59 am
A WISP could possibly use something like this to play a sound file ...
@TomjNorthIdaho: So it's enterprise feature then? That's good, it won't agitate people for being another frivolous home feature. :D
TomjNorthIdaho
Thu Sep 20, 2018 5:54 pm
It would pretty much be a tool for what ever a Mikrotik admin might want/need. Also , because I am suggesting it be an optional package, it would not necessarily be pre-loaded on a fresh Mikrotik router. This optional package could potentially be a nifty tool when used with scripts (including netwatch) to provide audio/verbal information. Also , because I know this type of motherboard speaker driver works on old/slow 16 MHz 16-bit computers , it would not be a Mikrotik resource drain sucking performance away from L2/L3 throughput.
TomjNorthIdaho
Thu Sep 20, 2018 6:17 pm
Related to optional ROS packages …
Because ROS is Linux based (and many of us know Linux very well) -and- because Linux/Unix may be one of the top two popular operating systems of all time , I would like to ask Mikrotik to consider a creating an optional developer package for ROS. Something that provides real programmer features and a compiler/cross-compiler which also includes an ability to make custom packages.
There are hundreds of small Linux developer motherboards out there already. Why not make a ROS programmer developer package. Who knows what the limits are for a RB ROS developer package ... A programmer could create custom drivers for PCI interfaces. Heck , I could see a possible use for a custom wireless/networked controller in many common things such as security systems, new additional drivers , hardware/interface/software/firmware support for use in all kinds of electric/electronic devices from heating & cooling systems, environmental systems and many everyday home/business devices already being developed using non-Mikrotik motherboards. I for one would tinker with it and see what useful devices I could create.
FYI - Did you know that Linksys released a full-blown Linux developer system with all of their Linksys source code and documentation for their Linux based wireless routers over 10 years ago (for free)? Where do you think DD-WRT came from (and many other systems) - and some of those operating systems derived/created from the Linksys developer system run on Mikrotik devices as a Virtual system right now ???
And also related to this post , when I started my WISP , I started out with 1,000 Linksys WRT routers running DD-WRT. I was very pleased with the DD-WRT Linux back then and it worked great.
Sob
Thu Sep 20, 2018 9:06 pm
Good luck with that. It doesn't seem to me that MikroTik is much for opening up. For example, according to developer of open-source MAC telnet, they don't even want to share details about new 6.43+ authentication, which is something that has no reason to be secret. And you want them to let you plug in your own code in their kernel...
But it could be nice. Even if it was something significantly more modest, just custom packages for strictly user-space non-root stuff. You could easily add custom services, simple web server, full-featured DNS server, UDP proxy, etc. Things that people sometimes want and MikroTik is not eager to implement. Combine it with some API to integrate own configuration interface for these things in WinBox/WebFix/CLI and it would be wonderful. But I'm not holding my breath.
TomjNorthIdaho
Thu Sep 20, 2018 10:32 pm
How about the possibilities of a new wireless driver for Wireless chipsets ? With a developent package , a new wireless driver could be created (using all of the available Atheros chipset registers/settings) to make new high-performance high-thoughput wireless drivers (such as a new/better nv2 'TDMA') system that might way outperform the current Mikrotik properitery hybrid TDMA (nv2). Or how about the tens of thousands of Linux drivers and applications/tools/utilities already freely available.
I think a development package would give the Mikrotik ROS the ability to enter other markets - more sales for Mikrotik in custom verticle markets. Even the US DOD could use this because they could then run their version of high-secirity high-encription special-functionality because they could then control their code and what does what. (I've been down this road a few times in the past...)
EDIT - back in the 90s, I was part a team that sold some custom very low power motherboards which supported special DOD software to control some battlefield devices and communications. Thanks to a software developer system , we were able to make $$$ millions in DOD sales of motherboards. With an optional Mikrotik ROS software developer package, new markets could be made available. A single order could potentially add many zeros to Mikrotik's $$$ income - ( I know - been there and did that !!! )
Last edited by TomjNorthIdaho on Thu Sep 20, 2018 11:10 pm, edited 2 times in total.
pe1chl
Thu Sep 20, 2018 11:04 pm
I think MikroTik want to be in the market of selling relatively inexpensive hardware with a relatively powerful routing OS which is relatively easy to configure and which can be supported.
(all those parameters of course can vary a little and some may have different opinions about them than others)
It appears you want hardware with an open software environment. However, that is already widely available from other manufacturers.
(many network-oriented system boards are available from our Chinese friends and there is also a lot of Linksys-like hardware)
You can install Linux or OpenWRT and do everything yourself. However, it is difficult to support when everyone can add their own things.
Some other manufacturers have experimented with partly-open boxes (e.g. you enter some code and it becomes open, and you lose support).
But some of them have reverted that and now you cannot do that anymore without installing entirely your own software.
And you can already do that on MikroTik's hardware!
To be successful and make money you have to find some market where people want your product and you can manufacture and support it at reasonable cost.
Sob
Thu Sep 20, 2018 11:26 pm
I don't know, maybe there are people or organizations willing to make drivers for RouterOS (or port existing Linux drivers) and keep up with possible changes done by MikroTik, instead of just using completely free Linux and have everything under their control. I can't really say. Another matter is how attractive prospect it would be for MikroTik. If they like to be in control, it would end, because driver can do anything. For this, "my plan" (if we can call it that) seems more realistic, because even though they would lose some control, isolated package could not easily mess up whole system. It could also be interesting for more people, because dealing with drivers is not for everyone, but to compile some simple daemon, that could be done by almost anyone.
pe1chl
Fri Sep 21, 2018 10:06 am
Yes it would certainly be nice to have user-mode daemons under isolated user IDs so they cannot mess with the MikroTik part of the system, but frankly I doubt that the infrastructure for that is currently in place.
I mean: probably now everything runs as root and there has been no attention to file and directory permissions for a long time, so first that would have to be prepared.
It would improve overall security and decrease the risk for vulnerabilities as we have recently seen when services would run as restricted users, but apparently the webserver runs as root (only Linux system where I have seen that for a long long time!).
Of course the CHR provides a way to look into that, maybe I will do some research now that we have a shiny new ESXi server with lots of spare capacity.
Dragonk
Fri Sep 21, 2018 10:51 am
I join the request, i need secure way to use NordVPN.
helipos
Mon Sep 24, 2018 2:23 am
System > scripts > environment (both winbox and webfig) ( it's only the current values however)
It would be nice to be able to properly append to text files. So we can get around the whole reading the file to another variable, adding what we needed and then writing the whole thing out again.
mrz
Tue Sep 25, 2018 11:30 am
Such request is pretty useless. Defince what you consider "complete"? Which features you are missing?
bennyh
Tue Sep 25, 2018 1:04 pm
Please fix webproxy with IPv6 sites.
It doesnt work, more people said in the forum, that there is some problem with IPv6 sites trough webproxy. Someone said, only direct ip address works in url (if remote webserver accepts direct IP address behalf domain name).
I tried with IPv6 address of the IPv6-test.com, and i got the error message of the remote webserver ("these aren't the droids you're looking for").
IPv6 test webpage (http://testipv6.com/) results trough proxy:
Test with IPv4 DNS record ok (2.023s) using ipv4
Test with IPv6 DNS record timeout (17.107s)
Test with Dual Stack DNS record ok (2.022s) using ipv4
Test for Dual Stack DNS and large packeto ok (3.011s) using ipv4
Test IPv4 without DNS skipped (3.118s)
Test IPv6 without DNS skipped (17.099s)
Test IPv6 large packet timeout (17.110s)
Test if your ISP's DNS server uses IPv6 ok (3.013s) using ipv4
Find IPv4 Service Provider ok (0.782s) using ipv4 ASN 8990
Find IPv6 Service Provider timeout (16.692s)
logicwrath
Tue Sep 25, 2018 11:39 pm
Please consider adding FQDN and DDNS support to the Local and Remote Address fields of the GRE Interface.
pe1chl
Wed Sep 26, 2018 9:19 am
This can be done using scripting. The underlying mechanism in the kernel does not support a DNS name so it would have to be solved in a similar way.
Chupaka
Wed Sep 26, 2018 1:18 pm
Isn't the support already here for some time?.. quite long time...
What's new in 6.33 (2015-Nov-06 12:49):
*) tunnels - eoip,eoipv6,gre,gre6,ipip,ipipv6,6to4 tunnels now support dns name as remote address;
Sob
Wed Sep 26, 2018 4:48 pm
Yes, it's there, but only for remote address. Local address accepts only IP address.
Chupaka
Wed Sep 26, 2018 5:36 pm
Why not just unset it? :)
What should router do if FQDN resolves to non-local address?
pe1chl
Wed Sep 26, 2018 6:22 pm
Well, when you unset the local address, you cannot enable IPsec.
Chupaka
Wed Sep 26, 2018 6:47 pm
Good point. Then I vote for the ability to set local-interface instead of local-address, so that IP address from that interface got used automagically.
As a workaround, simple scripting does this job.
TomjNorthIdaho
Wed Sep 26, 2018 8:03 pm
Hey Mikrotik marketing staff …
I think Mikrotik should include a Mikrotik bumper sticker in every Mikrotik product box shipped from Mikrotik.
Guess I'll have to stick around and see what happens.
2jarek
Wed Sep 26, 2018 10:06 pm
Please add Multipath TCP according to RFC 6824.
scampbell
Trainer
Trainer
Thu Sep 27, 2018 8:10 am
I would like to see an "add comment" feature on any rule that allows you to add an address to an address list so the created address list entry has info about why it was added.
e.g
add action=add-src-to-address-list address-list=Blacklist address-list-timeout=5d chain=input protocol=tcp dst-port=8291 address-list-comment="Winbox Attempt"
joegoldman
Forum Veteran
Forum Veteran
Thu Sep 27, 2018 9:19 am
A few suggestions I'd love:
1) Line item groupings, specifically in firewall stuff - basically a completely empty 'rule' / line thats just a comment, stays in block when comments are set to inline. The work around for this is setting dummy unmatchable rules or putting the comment on the first line in the block, but then I also like to comment all my rules, so having a 'header' comment stay in block and all the normal comments go inline would help organise firewall tables with heaps of chains/100's of rules etc.
2) Custom release cycle channel, basically to make it easier for the router you add custom, set a name to it and give it a URL, that URL might be a format that Mikrotik provide / documentation on how we should respond to the server to give it the latest firmware we want it to have. An example would be, im currently keeping my fleet of Routerboards on 6.42.x (mix of 5/6/7), as I haven't been able to test some of the bigger changes in 6.43.x, but some staff will just hit the check for updates and do updates that way, if we could have a custom release channel maintained by ourselves I could keep routers more inline.
There's plenty more but thats just some 'smaller' ideas I dont think would be too hard to implement.
pe1chl
Thu Sep 27, 2018 9:32 am
I agree with the above two. In addition with #2 I would like to add the possibility to make the release channel refer to some URL on a local webserver that
has information about the releases to track. E.g. a single version, or a major/minor version (like 6.42.x). So the routers configured that way will upgrade
to a version you set on a central system and you can change it without having to go all along those routers.
E.g. you set a custom release channel with URL http(s)://server.local.domain/mikrotik-release which would return a small textfile with either a MikroTik
release channel name (current, bugfix or whatever) or a specific version (6.42.7) or version range (6.42.x) and you can change that as a result of your local
testing outcome and/or security announcements. Of course you can have several of those URLs internal to your organisation so you can test on a couple
of routers first.
This also covers the problem that "current' is suddenly updated by MikroTik but you don't want to jump to it immediately but wait a week or two, but still
want to update some routers from an even older version.
Chupaka
Thu Sep 27, 2018 11:51 am
Well, as I can see, you just create static DNS entry on the router "upgrade.mikrotik.com" with the IP of your server, then run HTTP server on that IP, serving one-line files "/routeros/LATEST.(6|6fix|6rc|7)" containing "$VERSION $TIMESTAMP" (for example, "1.0 1"). Then create "/routeros/$VERSION" dir with CHANGELOG (any text you want to see) and .npk files. Done :)
pe1chl
Thu Sep 27, 2018 12:57 pm
Well in that case it would be nice when there was a custom setting that allows to configure another DNS name for the "upgrade.mikrotik.com" in a router.
Preferably two different settings: one foe the LATEST file and another one for the actual npk files.
In that case one can choose to retrieve the LATEST file from a local server and still get the npk files from "upgrade.mikrotik.com".
(so it is not required to keep a complete mirror of those files)
But of course it should be possible to mimic that with a reasonably flexible "transparent proxy" (that allows some files to be served locally and the remainder to be proxied)
Chupaka
Thu Sep 27, 2018 1:26 pm
Yeah, in nginx you simply use try_files for your custom files on local server and proxy_pass to the original MikroTik server for the rest :)
BartoszP
Thu Sep 27, 2018 2:02 pm
Please add:
MAC address lists
Port lists in Firewall
nicolasemmanuelc
Thu Sep 27, 2018 4:44 pm
Hello!
Please add an option to do "force cloud update" in an time interval, that is useful when have public dynamic IP
And yes, I know that this can be done with an script but will be great and easy if we have an "auto update in X time" function!
MikroTik is great! Have a good day!
logicwrath
Fri Sep 28, 2018 9:22 pm
I should have provided more detail.
If you use an FQDN on the remote address I suspect it then resolves it to an IP one time for the IPSec policy. There does not appear to be any kind of ongoing resolution of that FQDN. The support I am looking for would be compatible with the IPSec wizardry that is built into using the IPSec Secret field. The idea here would be to better support for creating GRE/IPSec tunnels with dynamic IPs without resorting to scripting.
logicwrath
Fri Sep 28, 2018 9:31 pm
Please add:
MAC address lists
+1 for allowing MAC address prefixes in lists as well for identify entire classes of devices like VoIP phones.
We currently have a script that does this using the ARP table.
pe1chl
Fri Sep 28, 2018 10:11 pm
Having MAC addresses in a list would not be very useful for that. What you want is to match MAC address by prefix, usually by the first 3 octets (manufacturer).
It looks like you can now only match the full MAC address in rules, it should allow a partial address and match that from the left.
(of course this is already possible in the where clause in commands)
Cha0s
Sat Sep 29, 2018 1:47 pm
So, updates work via plain HTTP? No encryption?
Shame!
pe1chl
Sat Sep 29, 2018 6:01 pm
Shame!
Why shame? There is absolutely no problem with that!
Remember the update files themselves are signed! The signature is verified before they are installed.
So http is fine.
You know, Windows is using http download for windows update as well.
Cha0s
Sat Sep 29, 2018 6:09 pm
Why shame?
Because there is no excuse anymore for any service to run without TLS. Certificates are free (if not dirt cheap for those that don't - for whatever reason - like Let's Encrypt).
Why should any entity between the router and the update server even need to know what is being downloaded? TLS will prevent any type of eavesdropping.
So http is fine.
Yeah, it's fine. Until it somehow gets exploited in the future.
Winbox was considered safe as well, and we all saw the mess we got into recently.
Just because it seems secure now, it doesn't mean it will always be.
Microsoft's policies are not an example to be copied.
So I'll stick to my original comment on this. Shame.
pe1chl
Sat Sep 29, 2018 7:30 pm
I don't agree with you. TLS is a hype and some people believe that nothing can be done without encryption anymore.
But that is of course not true at all. In the case of downloading updates, encryption is not an issue (everyone knows what is being
downloaded!) and the only issue is authenticity. This is guarded MUCH BETTER with the signing using a keypair managed by
the signing authority themselves (as it is done now by MikroTik and also by Microsoft) than by any publicly signed TLS certificate.
The whole system of signing of certificates by "trusted issuers" has too many unreliable parties so it really cannot be relied
upon (anymore) for authenticity. And there is really no point at all in downloading updates using TLS when they are verified
before installation anyway.
Cha0s
Sat Sep 29, 2018 8:59 pm
Sure,
So next time you login to your web-banking do not check for TLS. Just go blindly with http. Don't even check if you typed the correct domain or weather you got hijacked and redirected to another domain. What's the point anyway? Too many parties involved! :facepalm:
People, it's 2018. Not 1996. Everything MUST be TLS. For encryption, authenticity, everything. Having anything over the public internet in clear text is stupid. It doesn't matter what the content is.
Sob
Sat Sep 29, 2018 9:31 pm
It's a little different. Well, completely different. I don't want anyone on the way to see what info I exchange with my bank and I don't want evil hacker substituting target account number with their own, when I send some money out. I couldn't care less about downloaded RouterOS updates (*). Even if an evil hacker hijacks the connection and sends me something different instead, RouterOS won't be able to verify signature and will reject it. No harm done.
(*) As long as there's no flaw in MikroTik's package signing. So yeah, TLS would not hurt and could help some people sleep better. But it's not like there must necessarily be an apocalypse without it.
pe1chl
Sat Sep 29, 2018 10:16 pm
Sure,
I never inferred that. Logging in to some website is COMPLETELY DIFFERENT from downloading a firmware update.
Please don't post crap like that!
pe1chl
Sat Sep 29, 2018 10:18 pm
TLS would remove the possibility to have a local update repository on a closed network. At least until the update URL is made configurable.
Chupaka
Sun Sep 30, 2018 2:26 am
So the problem is that you don't trust MikroTik package signing and you do trust TLS and some "trusted" certification authorities (or just trust it more). It's your choice.
But the problem is you don't actually have a choice :) At least for now.
helipos
Sun Sep 30, 2018 5:07 am
The ability to force CPU, uptime, date etc on all winbox sessions.
Instead of having to do it individually
Wyz4k
Wed Oct 03, 2018 4:59 am
Please add average cpu usage for the last day / month / year whatever. This makes it possible to at a glance see how hard a router is working.
joegoldman
Forum Veteran
Forum Veteran
Wed Oct 03, 2018 5:34 am
This is done in 'graphing' you can set up resource graphs and access them through webfig (at login hit the 'Graphs' button underneath the login)
This will keep a daily, weekly and yearly graph if i remember correctly, daily being 5 minute poll, weekly being 2 hour and yearly being 1 day or something to that effect.
joegoldman
Forum Veteran
Forum Veteran
Wed Oct 03, 2018 5:37 am
Create a 'viw' /session, with those things enabled (And maybe your favourite screens setup and layed out), then use that as your default session view, along with unticking autosave so no matter what you do in that session it resets next time you log-in.
I have 5 or 6 different sessions, some set up for BGP routers, others for Shapers, for PPPoE Servers etc, to give me relevant information as quick as possible.
On this note though, my feature request would be to perhaps have a quick-access drop down of your session files (top left/right), so when logging into a router, you can quickly swap between different views based on what you want to look at (Firewall centric view, wireless centric view, routing centric view etc etc)
Wyz4k
Wed Oct 03, 2018 5:59 am
That would be almost okay if the graphs had some authentication built into them as well as opposed to just an ip whitelist.
First prize would still be something that doesn't require the graphs though, which can be scripted through the CLI.
joegoldman
Forum Veteran
Forum Veteran
Wed Oct 03, 2018 6:15 am
You are correct, I dont use the graphs for the same reason, but I generate the same graphs using one of many SNMP based monitoring tools out there, so I have a clear idea on CPU usage of routers.
Jotne
Wed Oct 03, 2018 8:11 am
Here is a screenshot form my Splunk Mikrotik project found here: viewtopic.php?t=137338
TomjNorthIdaho
Wed Oct 03, 2018 6:11 pm
Although my graph below is way to small to read - On some of my Mikrotiks I graph everthing. I can go back years and see , interface bandwidths , CPU loads, temperature , frequency , signal-to-noise , Signal-strengths , TX & RX rates , connected client counts.
Most SNMP based bandwidth graphing programs allow you to use just about any SNMP Mib OID you want and turn it into a graph item. I use Cacti.
The graph below shows an entire year for one of my Mikrotiks. On some devices, I have graphs going back to the early 2000s.
TomjNorthIdaho
Wed Oct 03, 2018 6:21 pm
Re graphing , I suggest using a 3rd party SNMP server and not using the Mikrotik graphing utility because it helps to lessen the Mikrotik CPU load and overhead which helps increase Mikrotik throughput and reduce L2/L3 packet propagation delay
Wyz4k
Thu Oct 04, 2018 3:11 am
I just want to see average cpu usage on a router somewhere in the field.
Now I either have to run:
1) unsecured graphing which can't be queried using a script anyway
2) have to run a 3rd party snmp server because there is no snmp server from Mikrotik and no ability to query snmp registers from the router itself.
Surely there's a point where it's simpler to just add in an average counter in the resources tab which can be scripted...
vecernik87
Forum Veteran
Forum Veteran
Thu Oct 04, 2018 3:57 am
If IP whitelist is not enough, you can limit it to VPN via firewall.
Mikrotik has "The Dude" which works well enough as SNMP server. It is not masterpiece, has its own bugs, but works.
... and no ability to query snmp registers from the router itself.
Unsure what do you mean. You can query SNMP from router.
Everyone will ask for different average. Someone will ask for 5m, someone for 1hour, someone for 1day... Cmon, if you have such specific requirements, is it really that hard to make own script, which will grab SNMP counters and show you absolutely anything you can imagine?
To sum up - we got two methods - either very simple graphing, or fully featured SNMP. You want something simple, yet advanced...
ilovepancakes
Thu Oct 04, 2018 4:39 am
Would like a way to be able to send user agent header with the fetch tool. For example, Google DDNS with Google Domains and other DDNS providers can accept IP updates through HTTPS get requests, but they need a valid user agent sent with the request. Right now, a script to do this returns a "badagent" error from Google. A way to send and even customize a user agent with the fetch tool would be great.
Wyz4k
Thu Oct 04, 2018 4:57 am
My mistake. I thought this was the "Feature requests" topic, not the "We'll find creative ways to partially solve your problems in inefficient ways" topic.
That being said the snmp get functionality on the mikrotik is useful and isn't something that I've used before. Thanks for that suggestion. I'll look into it.
Sob
Thu Oct 04, 2018 5:40 am
@Wyz4k: Actually, people are trying to help. Problem with your original request is that averages are not very useful. If you check your router and see daily CPU average 40%, what does it tell you? It could mean plenty of power to spare, but it can also mean that CPU is maxed out during whole business hours and router is struggling to survive. And the longer interval, the more useless the numbers get. So what would be such misleading feature good for?
vecernik87
Forum Veteran
Forum Veteran
Thu Oct 04, 2018 6:15 am
@Wyz4k No. I should apologize. I didn't realize it will sound so aggressive. This is certainly about "feature requests". Sometime, requests are great. Sometime not - people submit them due to misunderstanding or lack of information. I just tried to correct some of your statements and I didn't mean to offend you
Wyz4k
Thu Oct 04, 2018 11:27 am
It's okay, I apologize for getting a bit irritated as well. I appreciate your suggestion and will give it a try.
fneto
Thu Oct 04, 2018 5:04 pm
Hello!!
I'm new to the forum, and I'd like to know where is the right place for a feature request.
Actually I think Mikrotik should authenticate itself through radius in a uniform way, Winbox uses CHAP-MD5 what's on, but terminal uses PAP??? We uses centralized authentication in a very hostile environment and transmit password in clear way is not an option for us!!
Thanks!
pe1chl
Thu Oct 04, 2018 8:54 pm
Your feature is already implemented in RC/testing version. And some people don't like it...
joegoldman
Forum Veteran
Forum Veteran
Fri Oct 05, 2018 9:14 am
Clustered PPPoE servers....to an extent of course.
Basically only really IP Pool clustering - with limited IP addressing and a decentralised core, I currently have 4 different routers doing PPP termination. Rather than split up a /25 and have to try manage enough IP's in the pool between the routers, would be cool if I could give the whole range in the pool, and have the routers be aware of each others state and not give out an already used address.
pe1chl
Fri Oct 05, 2018 11:26 am
That is already possible via RADIUS!
joegoldman
Forum Veteran
Forum Veteran
Fri Oct 05, 2018 2:40 pm
No, RADIUS is not a pool manager it can assign statics, software behind RADIUS would need to still manage a pool, which can get out of sync if you miss a stop record or something.
tinodj
Fri Oct 05, 2018 4:07 pm
What about Copy rule option in Webfig?
It would be nice to be there. Thanks.
dihrmax
Fri Oct 05, 2018 11:17 pm
It's not a feature request but a model request. I didn't find a Topic about it.
I need a CCR with 4S+. I know there have a 1072 with 8S+ but it's to high and expensive for what I need. I need like CCR1009-8G-4S+ (1016 or 1036) dual PSU rackmount. (Doesn't matter how many Gig port)
Thank you
pe1chl
Sat Oct 06, 2018 11:49 am
Maybe when you don't really need the full 10G performance you could use one of the new SFP+ switches together with a CCR1009 as router-on-a-stick?
expert
Sat Oct 06, 2018 12:27 pm
1. Please allow adding many to many entries into vlan table for CRS1xx,2xx. Currently, only many to one entries are allowed:
Current:
/interface ethernet switch vlan add ports=sfp1,sfp2 vlan-id=200
/interface ethernet switch vlan add ports=sfp1,sfp2 vlan-id=201
Proposed:
/interface ethernet switch vlan add ports=sfp1,sfp2 vlan-id=200,201
The same should also work for egress-vlan-tag table.
2. This is improvement over point (1). Please allow interface lists to be added into vlan table for CRS1xx,2xx:
Current:
Proposed:
/interface list add name=sfp-list
/interface list member add interface=sfp1 list=sfp-list
/interface list member add interface=sfp2 list=sfp-list
/interface ethernet switch vlan add ports=sfp-list vlan-id=200,201
Idea: vlan lists similar to interface lists would be amazing...
pe1chl
Sat Oct 06, 2018 1:08 pm
Remember that interface lists are handled by the CPU. An interface list is just a bit set in the interface definition which can be matched e.g. in the firewall ("is this bit set for the interface where this packet arrived") by the processor.
This is entirely different from switch programming, where a fixed mapping between devices and vlans is programmed in an external chip essentially one-time (at startup) and the mapping is only used by the switch chip, not by the processor.
expert
Sat Oct 06, 2018 6:40 pm
Thanks for explanation, I didn't know what's the underlying implementation of interface lists. Well, the idea(1) is still nice to have, since my vlan table entries contain same trunk ports.
logicwrath
Wed Oct 10, 2018 11:24 pm
It would be great if all forms in Winbox.exe had a help button you could press that would take you to the relevent online documentation.
example:
http://prntscr.com/l4lfty
schadom
Thu Oct 11, 2018 3:21 am
MT please consider doing some BGP and routing-related fixes for christmas.
Would make A LOT of MT users very, very happy! Just to give some examples:
- multi-threading
- BGP4 SNMP MIBs
- better BGP convergence time
- faster route table searches
- fix ipv6 route reflection
- add RPKI support
TomjNorthIdaho
Re: Feature requests (IP Services)
Fri Oct 12, 2018 10:56 pm
It might be a new nice feature to add a couple of items under IP-Services.
In /ip service , add the follwoing:
snmp ( normally SNMP uses port 161 , add ability to set what IP addresses can even get to the SNMP service )
icmp ( add ability to set what IP addresses can even get to the icmp service when pings are directed to a Mikrotik )
And yes , I am aware in Mikrotik ROS there is the ability in SNMP access using the /snmp community addresses=IPs name=community , however should this possibley be added to /ip service ???
Re icmp , withoug going into firewall rule settings , shouldnt icmp be located in /ip service ?
Also - what other services are running on Mikrotik ROS that can/should be also in the /ip service area ?
Any possible btest server settings in /ip service ?
What about any service that uses a username (where we want to control what IPs have access to the service and the ability to control which username can be accessed from different IP-lists.
Also - If there is a IP service which is locked down by username (and possibly an IP-address-list) , if the service is running then there is a possibility of a denial-of-service attack. So , any ideas about adding additional functionality in the [/i] /ip service area ?
Also - re /ip service for any Mikrotik service running , how do we limit repeated connections from the same remote IP address over and over again --- Such as a remote attacker repeatedly trying usernames and passwords using a dictionary sequence of logins/passwords ( telnet , ssh , winbox , http , https , snmp , ftp , api ).
raymondr15
Sat Oct 13, 2018 4:12 pm
It would be really nice if MikroTik would add the ability to graph health information such as voltage and temperature and no I'm not referring about SNMP and API, I am referring to tools->graphing,the same way as resources, queues and interfaces are graphed.
pe1chl
Sat Oct 13, 2018 4:51 pm
There should simply be the possibility to add "user graphing" where an SNMP OID is entered and the value is graphed. It has been requested before.
giorgiop
Trainer
Trainer
Sat Oct 20, 2018 6:57 pm
Features Request!
a. Winbox, lets suppose we want to remove 5 columns and add 6 more. That would require to do 11 times the same thing since the list closes every time. Wouldn't it be easier (for the users not the programmer!) to have check box in front of every option, so as to check-uncheck whatever needed?
b. Winbox again. Wouldn't a rule copy from the start page be easier using the right click? got add-remove-enable-disable etc but no copy. Less windows-less clicks
c. Again winbox! Start page of a menu again (e.g. Firewall). A drop menu for the options (when double-clicked?) would be much faster to change an option. Combined with the second request, making a copy of rule and changing one option would be sth like right click-->copy rule--> double click new rule option-->choose new option.
marosi
Capsman SNMP Clients per AP
Mon Oct 22, 2018 1:36 pm
I would like to have the capsmanager push back informations to an accesspoint about connected clients (per interface)
this would be the easiest way to put snmp queries into dude for each ap (or any other monitoring tool), place accesspoints on a map and see how many clients connected.
facubertran
Wed Oct 24, 2018 7:02 pm
Hello, why mikrotik does not have the ability to better define user permissions based on roles?
facubertran
Wed Oct 24, 2018 7:04 pm
- multi-threading
- BGP4 SNMP MIBs
- add RPKI support
PLEASE!
vortex
Wed Oct 24, 2018 11:22 pm
There's still not quick (or slow) way of seeing which port are all devices connected to.
If a port is in a bridge, the latter is shown in the ARP table. It also does not show the DHCP name, just the IP address.
Chupaka
Wed Oct 24, 2018 11:44 pm
Hello. It's not a feature request.
Swordforthelord
Thu Oct 25, 2018 4:15 pm
I would love to see the functionality of the Mode button expanded. Specifically, it would be useful to be able to assign different actions taken based on whether the button was pressed once, double-pressed, triple-pressed, or long-pressed.
WirelessRudy
Thu Oct 25, 2018 6:31 pm
Features Request!
I fully underwrite these features requests. The problem is only I have made almost the same, and more, request on Winbox improvement several times over the years and never even got a reply..... None of these 'ergonomic' adjustments are ever implemented.
Long pull down list need every setting apply to be opened again to go to the next setting. My keyboard wear out only by the use of winbox!
pe1chl
Sat Oct 27, 2018 5:21 pm
And now, for something completely different: (no, not the larch)
With all those YouTube videos from MUM taken from all over the world, it would be nice when the language of the video is always visible in the title.
Some of them are in English or another language I could understand, but more often they are completely incomprehensible to me and it would be useful to make that selection already in the title listing.
TomjNorthIdaho
Mon Oct 29, 2018 4:37 pm
Yup - it can be a little frustrating when a video about Mikrotik is not in English (the only language I know).
But - I am also very aware that English is not the only language used in the world. - However , with todays technology , I suspect that somewhere there just might be a really smart computer than in real-time can verbally translate the spoken language in a video to English and optionally print the translated language on the bottom of the video at the same time.
pe1chl
Mon Oct 29, 2018 8:04 pm
Very true! Note that in no way I would suggest not to put videos in other languages on the channel.
It is very good that they are there, it only would be much more convenient when you can look in the listing and play only videos in languages you understand.
Which of course is different for everyone.
Youtube has that, but it is not really usable right now except when you want to have fun.
NEOhidra
Tue Oct 30, 2018 2:56 am
Indeed - it would be nice to separate the non-English videos.
pe1chl
Tue Oct 30, 2018 10:46 am
I don't want to advocate separating English from non-English videos. We should not consider one language "better" than another.
I just would like to see the language of the video in the listing.
schadom
Wed Oct 31, 2018 9:09 pm
RPKI/ROV guys, please. No need to re-invent the wheel.
See RTRlib for a lightweight, open-source C library: http://rpki.realmv6.org/
PS: Perfect for a weekend hackathon @ Mikrotik HQ while the weather outside is bad ;-)
chubbs596
Thu Nov 01, 2018 7:18 am
RPKI is really needed
pants6000
Fri Nov 02, 2018 5:43 pm
Actual tcpdump.
I know and use the existing local and remote sniffing tools, but they are not a satisfying replacement for a quick and simple "tcpdump -X" from the CLI.
bkusic
Fri Nov 02, 2018 7:58 pm
it would be great to develop a new product - an edge next-generation firewall (NGFW)...
My whole network is Mikrotik based - its GREAT. The only thing I would see is a real and fancy Mikrotik firewall.
Bruno Kusic
Chupaka
Sat Nov 03, 2018 2:06 pm
What's not real in current firewall? :)
anav
Tue Nov 06, 2018 5:34 pm
I am an english speaker and quite enjoy foreign language MUM and mikrotik youtube videos. One can sense the passion for the products in the voices.
Of course it helps when some languages revert to use english for the numbers LOL. All to say, the only comment I have is the lack of PDFs and/or videos for some of the presentations can be frustrating. At least a PDF I can translate very easily. I am with pelchi in that diversity is grand and an indication of which language would be helpful.
I was looking at DHCP leases (static) on youtube just last night and went through a number of non-english ones. Some were rather long, but in the end it was
either choose the dhcp lease menu selection of (make static) or right click on the mouse for that lease and at the popup windows type menu, select at the bottom (make static) and in both cases the mysterious D (dynamic) disappears on the far left of the lease line. There, Video of about 20 seconds. :-)
StreamlinkUK
Tue Nov 06, 2018 11:50 pm
Would be great to get support for either dnsmasq, or some other feature to enable forwarding of mac-address to remote DNS server, (i,e for parental controls and other applications)
http://www.thekelleys.org.uk/dnsmasq/do ... q-man.html
specifically these options :
--add-mac[=base64|text]
Add the MAC address of the requestor to DNS queries which are forwarded upstream. This may be used to DNS filtering by the upstream server. The MAC address can only be added if the requestor is on the same subnet as the dnsmasq server. Note that the mechanism used to achieve this (an EDNS0 option) is not yet standardised, so this should be considered experimental. Also note that exposing MAC addresses in this way may have security and privacy implications. The warning about caching given for --add-subnet applies to --add-mac too. An alternative encoding of the MAC, as base64, is enabled by adding the "base64" parameter and a human-readable encoding of hex-and-colons is enabled by added the "text" parameter.
--add-cpe-id=<string>
Add an arbitrary identifying string to o DNS queries which are forwarded upstream.
OnixJonix
Mon Nov 12, 2018 12:01 pm
Something like TORCH on firewall rule!
It would be great if i can select firewall rule and click on torch - and see what traffic is triggering on that rule!
pe1chl
Mon Nov 12, 2018 2:29 pm
It is sort of possible to do that, by clicking the "log" checkmark on the last page (the matched traffic will appear in the log).
Of course you must be careful when doing this on large amounts of traffic. But I have often used it for traffic that has only
a few pkts/second and it works fine.
msatter
Mon Nov 12, 2018 5:06 pm
On that being logged many many times the same loglines it would be nice if that could be avoided by buffering the new and same loglines till an other different logline is going to be written to the log. The first two and last one/two lines are writen so the time between lines can by seen.
First the two logline written. When it is repeated then the shown counter is increased:
time - same logline
time - same logline
the line above are repteated X times.
time - end of repeated lines
time - new logline
pe1chl
Mon Nov 12, 2018 7:11 pm
As long as you have connection tracking, and do not use the log on the "established/related" rule (which should be at or near the top of the list), logging on rules further down the list will usually have less volume and certainly not a duplication of the same info.
Of course there can still be a lot of new connections logged this way.
Jotne
Mon Nov 12, 2018 7:36 pm
the line above are repeated X times.
When you dealing with external logs, this is something you like to avoid at all cost like here in my Splunk - Mikrotik project:
When you read logs external programs its hard to understand what is repeated and get the message back together.
And do you have many boxes that sends syslog to same server, it makes it even worse.
So if implemented, this need to be an option.
msatter
Mon Nov 12, 2018 8:44 pm
In RAW I don't have those control options and thinking further about it.
On enabling logging the option to group logline for that specific rule. Control is so still with the user.
msatter
Mon Nov 12, 2018 8:49 pm
Making it optional on rule level is the way to go. The user have to decide, if it is going to be used or not.
pe1chl
Tue Nov 13, 2018 4:18 pm
Please consider implementing a way to run a user program in an environment as far protected as possible, but lighter than MetaROUTER which requires a full OS and hardware virtualization.
Some discussion is on page 4 of the Feature Request: OpenVPN [ovpn] udp tunnels topic.
E.g. make a folder on the flash device or external storage, the user puts the executable binary there and possible configuration data, RouterOS runs the executable
in a chroot to that folder, normal networking is possible but possibly also a tun/tap device that is configured just like for the MetaROUTER.
User code is run as a nonprivileged user and without any access to RouterOS configuration or environment.
This would allow users to run their own OpenVPN server, Wireguard server, advanced DNS server, DNS to HTTPS relay and more, without
having to wait for MikroTik implementing those services.
Only support required would be some common shared library files to link to (others could be statically linked).
Users can use the usual gcc cross-compilation facilities to generate their binaries.
Advanced tricks like virtual machines with their associated stability issues and unavailability on certain processors would be unnecessary for this feature.
Wyz4k
Thu Nov 15, 2018 8:11 am
RFC 5424 compliant syslog client so that I can use a cloud syslog server. https://help.sumologic.com/03Send-Data/ ... log-Source
eduplant
Sat Nov 17, 2018 8:38 am
Hello, I just posted a feature request in a separate thread but wanted to at least link it here for possible visibility:
[Feature Request] :resolve DNS Client Improvements
One of the advantages of RouterOS is its scriptability and the strength of its shell syntax for getting things done. New improvements in the :system and :tool areas have given us more tools than ever, and augmenting existing features with script="" hooks have given us even more places to use those tools. However, it seems like an important scripting primitive (for a network device, at least) has been neglected for some time: :resolve.
The rest can be found in the thread here.
Thanks!
mada3k
Long time Member
Long time Member
Sat Nov 17, 2018 7:25 pm
  • Netinstall for Linux/BSD
  • DMVPN or something smilar would be great
  • SNMP monitoring of OSPF-neighbour and BGP peer-status
  • Sectioned view in Firewall/Filter.
  • TACACS
  • 802.1x
GuJack20
Trainer
Trainer
Sat Nov 17, 2018 9:25 pm
You are right. That’s why in this year’s MUM in Tirana i changed the title and description of my presentations from English to Albanian (the language I was going to give them) :)
So the video in youtube has an Albanian title, the .pdf has an albanian name too. Very easy i think for everyone.
MikroTik should just ask the presenter to write the title and description of each presentation in the language that is going to be given. ☺️☺️
usv111
Thu Nov 22, 2018 1:40 pm
Please,
add multi-cpu(multi-core) support to Bandwidth Test Tool.
this is required for 10G/SFP+ speeds testing between CCR1036/ or between CRS317-1G-16S+RM devices.
At the moment Bandwidth Test Tool can generate only 2Gbps and utilize only 1 core on CCR routers.
Chupaka
Fri Nov 23, 2018 2:11 pm
https://wiki.mikrotik.com/wiki/Manual:T ... _Generator
WirelessRudy
Fri Nov 23, 2018 3:24 pm
When do we ever see the option of select and copy text in the winbox log files? This has been asked for years.
Plus the option to search for string of caracters?
When studying your logs in winbox it's at times hard to get the eyes focused on what you want to see if there are many lines to read through.
And copy and paste into a text file would make is so easy to quickly select what you are looking for.
expert
Fri Nov 23, 2018 5:20 pm
What's hard on doing
ssh mikrotik "/log print" | less
WirelessRudy
Fri Nov 23, 2018 5:50 pm
1. I am not doing ssh. 2. I don't want to print anything. I just want to quickly look in my log and highlight a line or try to find just one setting (one mac leaving or connectiong for example on an antenna) so I can see what happened or where something went wrong.
Why do I need to ssh into it when I am after 15 years still perfectly happy with winbox. And why should I need to print a log first before I do the things that is already any other program running on my screen?
What is so hard to just make my mouse highlight a line? This feature has been asked for by many over the years...
muetzekoeln
Feature request: address lists for routes
Sat Dec 01, 2018 7:21 pm
I have a small feature request. For me it would be very helpful. There are some (about 35) IP networks better reachable by a special gateway than by default gateway (no BGP!).
It would be great if there would be an address list table where all these networks listet and add only one ip route for the list. Today address lists can only be used in firewall.
I know one can use firewall rules to establish routes, but I find this a little bit confusing.
Please make address lists available as destinations in ip route menu.
pe1chl
Re: Feature request: address lists for routes
Sat Dec 01, 2018 11:31 pm
That is actually already possible.
You add a route to 0.0.0.0/0 via your special gateway in the ip route table with a routing mark name you choose.
Then in your ip firewall mangle table you add a forward rule matching your address list and setting the action "mark routing" and select your mark name.
schadom
Sun Dec 02, 2018 8:35 am
I'd love to see some routing and BGP-related improvements and features (like RPKI Origin Validation).
According to ROS changelogs, it's now almost over a year ago since the last BGP-related fix has been released:
What's new in 6.41 (2017-Dec-22 11:55):
*) bgp - added 32-bit private ASN support;
We've seen a lot of bridge, cloud, wireless and w60g-related stuff going on during the last months.
Now it's really the time to focus a little bit on routing again... make routing great again ;-)
lucasimo88
Mon Dec 03, 2018 9:56 pm
I'd like to ask to complete IPSEC/IKEv2 implementation.
Motivation is : lots of VPN providers - NordVPN and others - are moving to that, leaving L2TP/IPsec disappearing.
i need me too complete supporto for IPSEC/IKEv2 with EAP Authentication implementation for NordVPN
muetzekoeln
RFC 4191
Tue Dec 04, 2018 2:37 pm
Please support preference field in IPv6 router advertisements. Incoming and outgoing. RFC 4191.
TomjNorthIdaho
Wed Dec 05, 2018 2:49 am
Please,
Of note: I have some CHRs running on VMware ESXi servers with 10-Gig network cards.
A single btest session uses a single CPU - however … multiple btest sessions (a mix of send & receive btest(s) appear to use multiple CPUs.
A single CPU assigned to my CHR ROS system can actually btest using vmxnet-3 Ethernet interfaces through the physical 10-Gig network cards can reach near 10-Gig throughput to another CHR btest device on a different VMware ESXi server.
Additionally , two CHRs running on the same physical VMware ESXi servers using vmxnet-3 interfaces can easily btest to each other at rates faster than 10-Gig (in my case , I have tested two CHRs on the same system at almost 19-Gig. And , a CHR running a btest to the loopback interface 127.0.0.1 can easily hit over 20-Gig. I have never seen a Mikrotik motherboard btest to the loopback 127.0.0.1 interface at even 1/4th that speed.
Also - in my opinion , a CHR running on a decent SuperMicro with fast Intel XEON CPUs and lots of CPU cache has always totally and easily way out performed all Mikrotik motherboards that I have tested. For example, a full BGP load on a 10-Gig feed is almost 10-times faster than a CCR1036 Mikrotik router.
Also - again in my opinion, a CCR1036 is good at speeds less than 2-Gig , and a CRS is more of a switch than a router and they are slower. On both your CCRs and CRS mikrotiks , run a btest to 127.0.0.1 and you will discover they are not all that fast or even in the neighborhood of performance a CHR with good hardware can deliver.
North Idaho Tom Jones
antonsb
Wed Dec 05, 2018 8:24 am
Multithread support for btest is already added:
Version 6.44beta39 has been released.
*) btest - added multithreading support for both UDP and TCP tests;
Guntis
Wed Dec 05, 2018 8:42 am
Please,
Since beta version "6.44beta39", bandwidth test utilizes all of the CPU cores.
shiyiqiang08
Wed Dec 05, 2018 9:04 am
can rb450Gx4 add wireless?
i need small device but high performance ,but the rb450Gx4 or RB850G has no wireless.
iperezandres
Wed Dec 05, 2018 10:51 am
It would be awesome to be able to save the winbox personalized views, instead of having to rearrange every window every time we connect to a new device.
UPDATE: as it turns out, it already exists the solution: viewtopic.php?f=14&t=120033 :)
marosi
MPTCP-Kernel, Pound
Thu Dec 06, 2018 11:42 am
So dudes, christmas is coming soon and here are my wishes
- a mptcp enabled kernel
- sstp vpn combined with mptcp
this would make it possible to take (v)dsl lines combined with 4G/lte and establish vpn tunnels to a central vpn server.
the reassambling of packets is done by the mptcp kernel.
this would be a outstanding feature.
https://en.wikipedia.org/wiki/Multipath_TCP
and the second one would be to implement pound as a loadbalancer service combined with letsencrypt certificates, wich would be my third wish.
implement letsencrypt including automatisation for certificare renewals.
the ppl could use routerboard hardware from 3011 to ccr1072 as loadbalancers for reasonable costs and connect the ports direct to a webfarm.
the useability in sum would increase quadratically.
muetzekoeln
Re: MPTCP-Kernel, Pound
Thu Dec 06, 2018 12:15 pm
+1, although it's status is "experimental". Would also play nicely together with LISP (RFC6830) viewtopic.php?f=19&t=81674&p=699943&hil ... 30#p699943. In addition BBR is included in mptcp, which would be great.
BBR together with a proxy service (see below) would help for legacy end user devices with old tcp stacks.
+1, something like Pound would be really useful!
+1 again ;-)
pe1chl
Wed Dec 12, 2018 11:25 am
winbox: please add some "windows list" feature, e.g. a button for every open window to the right of the "Session:" field below the menu bar.
this can be useful to have an overview what windows are open and to raise them when they are inadvertently lowered below another window.
I normally have the "Log" open fullsize and open all other windows on top of that. When I click somewhere outside of a window by accident,
all opened windows disappear behind that Log window and I have to re-open them from the menu.
Alternatively, it could be useful to have a "lower window" widget or right-click option so I can lower the Log window again (so all other open
windows appear on top of it).
WeWiNet
Long time Member
Long time Member
Wed Dec 12, 2018 6:12 pm
pe1chl +1,
that would be awesome. hate to fiddle around the various windows...
Also a green/yellow/red color field within WINBOX to indicate if you are still connected to the router (green - connected, yellow - don't know, red-disconnected)
pe1chl
Wed Dec 12, 2018 7:46 pm
That isn't required because when you have no link, you will be disconnected (far to) quickly and lose the open window (reverts to connections list)!
What I would like to see is an option to disconnect only after 1-2 minutes of link-down, so it is possible to survive a router reboot somewhere inbetween.
eworm
Fri Dec 14, 2018 9:47 pm
That is possible with scripts. See my RouterOS Scripts (or at github), especially mode-button-event and mode-button-scheduler.
solelunauno
Wed Dec 19, 2018 11:47 am
I use the USB port to activate a N.O. relais that will remove power form an IP surveillance camera to hard reset it.
I use the N.O. relais because 1) a relais failure will let the camera ON, instead than OFF; 2) the relais consumes almost 0,6W of power and my installations are often battery powered (solar panels, etc).
But until now there isn't a feature in RouterOS to let usb power OFF all the time, so I use a script scheduled at startup:
/system routerboard usb power-reset duration=720d
It will be great if I could power ON and OFF usb as I already do with POE output.
bmatic
Wed Dec 19, 2018 1:36 pm
If anybody from MikroTik is reading this I would make a sugestion that I can somehow disable fetch tool log messages.
I wrote a simple script for fetching public IP address for updating No-ip address, and it works OK, but now I have log flooded with fetch messages.
eworm
Wed Dec 19, 2018 3:11 pm
You can get rid of this. If you do not need the file just add "keep-result=no" to your fetch command. If you do need the file I suppose you read the content later? Just switch to return value to a variable.
muetzekoeln
Feature requests: zero-wait DFS
Thu Dec 20, 2018 12:44 pm
It would be nice to have zero-wait DFS in RouterOS, like AVM and Aerohive have it.
This is to eliminate wait time on 5GHz band after changing operational channel because of Radar detection.
RouterOS could do continuous background scanning (using Scanlist) to find "available" and "unavailable" channels (https://www.etsi.org/deliver/etsi_en/30 ... 20007a.pdf). On radar detection (on active channel) it could (randomly) choose a new channel from the available channels and inform clients of the frequency change before shutting down current operational channel and switch to the new channel.
WeWiNet
Long time Member
Long time Member
Fri Dec 21, 2018 1:56 pm
Pe1chl
Not true on MacOS/Wine Winbox.
You get disconnected but it won't through you out (but the clock stops to work!). I can open still windows, with data/settings, modify them etc.
Then after a while you might really get thrown out but you won't know when the disconnect happened, and from which point
onwards the modifications were lost.
For this a clear flag (green=clock updates, yellow=no update for 1-3 seconds, red= no update for over 4 seconds) would be really helpful.
Knowing that the clock is precised and stops (even on Mac) using that as trigger should be simple to implement and really nice at same time.
pe1chl
Fri Dec 21, 2018 2:13 pm
Strange! Under Windows and with Linux/Wine this does not happen, whenever the link is lost you get disconnected within 3 seconds.
Very inconvenient, because sometimes I have 3-4 devices open at the same time and when I reboot one of them I lose all windows even before BGP+BFD re-calculates the routes.
I would in fact prefer such a status indicator and some more patience from winbox (and the router at the other side) so that it survives such events.
cowgirl
Fri Dec 21, 2018 4:35 pm
Multi Chassis Link Aggregation for CCR1xxx and CRS3xx
Best regards
Alexandra
Users browsing this forum: Bing [Bot] and 195 guests
