SDFadfasdfadsf
Re: Feature requests
Sun Feb 19, 2017 2:47 am
RFC 8092 BGP Large Communities implementation Feature Requested 2016090522001073
timeline available?
JanezFord
Thu Feb 23, 2017 12:58 pm
Please add some kind of "find router" feature. I often take over projects from other people and have to search for bunch of devices sometimes in many rooms even buildings. A simple "beep constantly" feature could save me a lot of time. You wouldn't believe where people put their routers and wifi access points. This way devices can be located without disrupting their operation. Beep constantly + maybe some kind of LED visual feedback would be nice to have.
JF.
mrz
Thu Feb 23, 2017 1:14 pm
JF.
This is already possible, there is a :beep console command and also leds can be turned on/off. Simple script will do the trick.
JanezFord
Thu Feb 23, 2017 8:30 pm
Thank you, I will look at your suggestion ... but anyway I find it would be way more user friendly to have for example a "Locate" button in Routerboard menu instead of having to program scripts for such a task.
JF.
anuser
Long time Member
Long time Member
Mon Feb 27, 2017 5:40 pm
What about enhancing CAPSMAN:
- centralized upgrade for RouterBoot (button for "/system routerboard upgrade") would be nice.
- "Right click" into remote CAPs list and directly connect to one of the CAP device itself
- management of all routerboards, also without wifi
CerpinTaxt
Wed Mar 01, 2017 3:16 am
Usermanager:
Currently, maintaining users via web browser provides more information than can be obtained using the CLI directly on the router (e.g. Total time left/Till Time can be seen on browser, but not Winbox) this makes using the API to get this information impossible. Could this be added in the output of
/tool user-manager user print
or even
/tool user-manager user print detail
would be great. The CLI should have everything a GUI has (plus more?!)
gilson
Feature requests: In Winbox, copy from Log panel to clip board.
Sat Mar 04, 2017 10:02 pm
While using Winbox, I always missed the ability to allow to mark and copy form the log panel to clip board, as well a Find box. It would be very useful.
Wyz4k
Mon Mar 06, 2017 3:04 am
The ability to copy and paste data more easily.
1) Selected text from the log to the clipboard.
2) From random tables into the clipboard in csv format.
hyperpaccket
Mon Mar 06, 2017 6:15 am
More than 2GB of ram for the X86 Build.
JanezFord
Fri Mar 10, 2017 2:39 pm
JF.
Hmm... can't make any of the 20 wAP devices beep.... is it just me or the damn thing does not have a beeper??? The 850Gx2 beeps OK...
JF.
mlow
Fri Mar 10, 2017 11:43 pm
RFC6939 for the DHCPv6 relay.
Would be extremely useful for doing MAC address based DHCPv6 reservationsRFC4649
exploit
Mon Mar 13, 2017 7:55 am
1. I believe that you need to add ability to associate an IP address with two different mac-addresses. This allows you to give the same network address to a device that connects at different times from different interfaces (for example, ethernet or Wi-Fi in laptops)
This feature is implemented in dnsmasq (for example, dhcp-host=38:B1:DB:38:B4:23,28:d2:44:d0:e0:3e,192.168.0.111)
2. I do not receive the network route specified in the profile of the l2tp client. This topic was previously discussed in your forum: viewtopic.php?t=56079
This feature is implemented in SoftEther
Thus, both possibilities requested by me are technically feasible.
meckanix
Wed Mar 15, 2017 4:29 pm
Can we add a VRF setting to the DHCP relay so that the relay can be used within a VRF?
neticted
Fri Mar 17, 2017 1:18 pm
I use wireless roaming feature and I have set Signal range in Access list to kick clients with low signals.
It works fine for most of the time but sometimes some clients got kicked frequently even with good signal.
After some time of monitoring this issue I concluded that problem is that it happens that client momentarily is received with low signal, and Mikrotik kicks it at once.
If I set lowest allowed signal to very low, client does not get kicked. But, that ruins whole idea of roaming as then clients stay connected to node even with very low signal.
My proposal is to introduce option to set hysteresis (delay) to kicking clients if signal is out of specified level range. Goal is to kick client if it really has low signal for some time not just because it is measured low for a moment.
lavv17
Wed Mar 29, 2017 3:41 pm
Hello!
RouterOS "ip route print where dst-address in x.x.x.x/z" is fast. But for a reason the same for ipv6 is slow (when the number of routes is large).
Please, make ipv6 route lookups fast as well.
savage
Wed Mar 29, 2017 3:44 pm
Hello!
And IPv6 filter on dst-address doesn't work at all in Winbox
Wyz4k
Thu Mar 30, 2017 4:09 am
Bridge-like filtering (L2) for Mesh.
lavv17
Tue Apr 04, 2017 12:34 pm
It would be nice if routing updates were more atomic. Currently converging BGP full view can lead to temporary routing loops. They last for a minute or two.
My setup consists of 3 CCR1036 routers facing different providers; iBGP between each pair of them. When a router boots up, a temporary loop can be created for a pair of minutes.
Also I'd like to repeat my plea of a graceful reboot option: viewtopic.php?f=1&t=45934&p=556840&hili ... ul#p556840
Nee
Tue Apr 11, 2017 5:03 pm
1. dstnat for output chain - i.e. to route Mikrotik's DNS requests to different DNS servers / interfaces
2. hardware ipsec acceleration for processors, which support it (i.e. RB3011) - maximum ipsec performance is the must for many modern configs, imho
Wyz4k
Thu Apr 13, 2017 8:11 am
Please add a button to clear the log. It's practically impossible to try and debug routers over crappy connections when just attempting to load the log causes the connection to break. If I could periodically clear the log it would reduce the traffic enough for the connection to remain viable.
I've tried the methods listed on the forum and they no longer work.
OnixJonix
Re: Feature requests - CAPS Logs explained
Thu Apr 13, 2017 10:32 am
Please come up with CAPS logs explanation!!!!
Stuck with capsman problems - see problems in log files, but not sure what it mean an what direction look for!!
for example:
caps,error removing stale connection [E4:XX:8C:D4:11:99/18/b823,Run,[E4:XX:8C:D4:11:99]] because of ident conflict with [E4:XX:8C:D4:11:99/18/e84d,Join,[E4:XX:8C:D4:11:99]]
andriys
Thu Apr 13, 2017 11:39 am
You might be using the same certificate on multiple CAPs. Take this as an educated guess, not a definitive answer.
OnixJonix
Thu Apr 13, 2017 1:08 pm
No certificates at all!! Maybe thats the problem??
andriys
Thu Apr 13, 2017 1:33 pm
Another guess- CAPs with duplicated MAC addresses. Do you happen to use backup/restore to clone configuration of CAP devices?
felipelinkmais
Thu Apr 13, 2017 9:31 pm
Will be nice if mikrotik create a new OLT package.. to turn any mikrotik device with sfp slot in one GPON/EPON OLT.
OnixJonix
Tue Apr 18, 2017 8:25 am
Have ~50Caps - in Capsman Radio list shows all, and in the list no dublicated macs!!! This was my first gues, but seems there everything is ok!!
Wyz4k
Tue Apr 18, 2017 10:34 am
Please make it possible to change the comment associated with a connection without it restarting said connection.
Wyz4k
Wed Apr 19, 2017 6:39 am
Could we get the LAC (local area code) also being displayed in in the info box for 3G/4G modems? This information is required to locate the sim. Currently the cellid is being displayed and it's possible to determine MCC and MNC. See http://cellidfinder.com/
scus
Wed Apr 19, 2017 3:54 pm
In case that public key authentication is used (and passwords are disabled) the SSH server should drop the connection immediately if no public key is provided by the client (instead of asking for a password and denying access even if a valid password is provided). There should also be a configuration option to allow password authentication in addition to public key authentication.
I have thousands of failed login attempts (from different IPs), all trying to login as admin, user, test, etc. using passwords...
juliokato
Wed Apr 19, 2017 5:06 pm
[Active Users (Admins)]
Is there any way to cut the connection of a remote admin.
Amazing how this feature does not exist!
jarda
Wed Apr 19, 2017 9:21 pm
Do you want to be cut off by a hacker?
juliokato
Thu Apr 20, 2017 3:25 pm
Look this:
How do I delete previous sessions stuck in an easy way?
macsrwe
Re: Feature requests (DNS names input instead of IP address)
Fri Apr 21, 2017 9:29 pm
Please add feature that will allow me to add DNS name instead of exact IP address. I need this to connect 2 or more MKT routers (PPTP connection) if they are connected to internet thru ADSL and theirs IP addresses are dynamic. I hope that you understand what I am saying and that we can expect this feature in new ROS.
bye,
i think that this should be global. anywhere you specify a dns name it should be resolved.
Yes, but not immediately - it should be stored as a DNS name and resolved in real time. For example, it's pointless to resolve /tool email server once and store it as a numeric address, which is why ROS will store it as a name. However, /system watchdog resolves the same server once and then stores it as a number, which is wrong. Also, you don't want things to fail because they can't be resolved immediately when you are configuring a router on a workbench and it has no connection to your network.
macsrwe
Fri Apr 21, 2017 9:34 pm
This would be good for both /int wireless access and /int wireless connection; also the "add to access list" and "add to connection list" operations, where you already know that the resulting entry will not be incompatible with the connection that already exists, because it is being generated from that connection.
macsrwe
Fri Apr 21, 2017 9:38 pm
JF.
JF.
Many of the newer, lower-cost devices have no beepers. :-( I have come to rely on the beepers for so much diagnosis (esp. SXT setup) and I really miss them. I would pay the extra buck.
horhay
Fri Apr 21, 2017 11:44 pm
Help us old keyboarders out and add ALT tags to menu and buttons.
This way we can use ALT C for a Close button or ALT O for OK.
skuykend
Sat Apr 22, 2017 3:59 am
During an Export of /Interface/Ethernet/Switch/Ports it would be nice to have it use a [ find default-name=xxxxx ] like the /interface ethernet export instead just the set#.
Andrew08
Sat Apr 22, 2017 10:32 am
Ip dns port support
So for example we can use 208.67.220.220:443
biatche
Sat Apr 22, 2017 4:39 pm
Requesting for neater and more readable exports
currently:
export compact
/something1
some config
/something2
some config
suggestion:
export compact
/something1
some config
/something2
somet config
spacing them out improves readability a lot.
Zero3K
Sun Apr 23, 2017 1:33 am
It would be nice if there was an option to display a box containing the Ethernet and DHCP Clients (with the Mac, IP, and how long it has been online) connected to it in the Quick Set page.
tawhwat
Sun Apr 23, 2017 5:29 pm
I believe this request can be implemented very fast but it helps the ROS management with Multiple WAN a lot! :wink:
The "/ping" and "/system ssh" allow user to specify the "src-address" parameter so that the command can initiate the network connection on specific WAN easily.
BUT "/tool fetch" doesn't include "src-address" parameter.
The problem is one ISP blocks all incoming ping request, thus I cannot use ping as a remote monitoring facility, I need to find alternatives to archive this goal.
I write script to carry out the monitoring job, but as I know, "/system ssh" cannot be executed under script environment, which means I cannot use "/system ssh" to do this job.
The only way to choose is to use "/tool fetch" facility to monitor the remote ROS, BUT it lacks "src-address" parameter, to supplement this deficiency, before using the "/tool fetch", I need to specify a temporary custom route to fix the outgoing path for remote target.
The whole situation can be simplified tremendously by only adds the "src-address" parameter to "/tool fetch"
juliokato
Sun Apr 23, 2017 7:26 pm
+1
biatche
Mon Apr 24, 2017 8:02 pm
please, MSTP & PVRSTP next version...
sparker
Tue Apr 25, 2017 9:49 am
+1
Really need, please!
biatche
Wed Apr 26, 2017 5:55 am
request: a default set if IPv6 firewall rules with IPv6 enabled be default
Wyz4k
Wed Apr 26, 2017 6:46 am
Please add the ability to do a where query in [] with any valid-variable.
fail example:
:local identity "testRouter"
:local interface [/ip neighbor find where identity=$identity]
fail reason:
result differs from :local interface [/ip neighbor find where identity="testRouter"]
contains several interface which don't have the specified identity.
pass example:
:local macAddress "00:11:22:33:44:55"
:local interface [/ip neighbor find where mac-address=$macAddress]
pass reason:
gives exact same result as :local interface [/ip neighbor find where mac-address="00:11:22:33:44:55"]
contains only interfaces that have that MAC address
Chupaka
Thu Apr 27, 2017 2:08 am
setup some VPN tunnel between the routers :)
then you may ping inside the VPN, or just use VPN Interface state to detect remote failure
Chupaka
Thu Apr 27, 2017 2:15 am
fail example:
fail reason:
that's because the variable name "identity" is the same as parameter name "identity". the following code works correctly:
:local id "testRouter"
:local interface [/ip neighbor find where identity=$id]
by the way, use the following is also correct:
:local interface [/ip neighbor find where $identity=$id]
:local interface [/ip neighbor find $identity=$id]
Wyz4k
Thu Apr 27, 2017 5:39 am
Thank you, I will try it out!
doneware
Trainer
Trainer
dhcp clientid in dns req
Thu Apr 27, 2017 9:37 pm
this one can be quite neat if someone is into parental control
https://datatracker.ietf.org/doc/draft- ... -clientid/
the code is there in dnsmasq since 2.76
Wyz4k
Fri Apr 28, 2017 3:58 am
Can we get standard 802.11s support? https://wiki.mikrotik.com/wiki/Manual:I ... e/HWMPplus indicates that the HWMP+ protocol is based on 802.11s draft but is not compatible with it.
kalaposl
Trainer
Trainer
Fri Apr 28, 2017 1:00 pm
I would love if I could run a script as a firewall action.
doneware
Trainer
Trainer
Sat Apr 29, 2017 12:25 am
this would degrade the packet forwarding performance in an unpredictable but disastrous way.
but you can log the match with custom tags, parse logs with scheduler, and fire actions as needed.
macsrwe
Sat Apr 29, 2017 2:27 am
I've been waiting over five years for /system upgrade upgrade-package-source to allow specification of its password parameter on the command line instead of demanding it interactively. This one deficiency makes Flashfig entirely useless to us and makes initializing every one of our MikroTik CPEs a multi-step manual process. I've been told this is done for "security," but every other password, encryption key, secret, etc. can be set from the CLI except this one (which is a relatively minor "security" function at best), so I'm not buying that argument. How hard can this be, guys?
nordex
Sat Apr 29, 2017 8:14 pm
Add temperature/voltage graph.
I know it is possible to add it on dude/snmp monitoring, but sometimes it's complicated, and it should not be big problem for you to add it to the existing graphing routines.
Wyz4k
Mon May 01, 2017 4:10 am
You mean like inspecting every packet with a level 7 filter does? Sometimes it's nice having the ability to do something and then allowing the engineer to make sure that it does not get triggered excessively. Rather than not allowing the engineer to have the ability to do something he might have a need to do.
On that note, it would be really great to have an average cpu value being displayed in the resources tab. At the moment I have to run a script periodically and try to calculate this on my own.
biatche
Mon May 01, 2017 6:07 am
request switch vlan support on RB750Gr3
doneware
Trainer
Trainer
Wed May 03, 2017 10:57 am
there are certain "optimised" actions (like add-src/dst-to-address-list) which could have their "script" counterparts, but that doesn't mean they're the same. packet forwarding is not a thing where one want to mess with interpreted code. and running a script (executing a series of routeros commands) is actually running an interpreted code.
where i do see the quite a bit of flexibility, but it is a fundamental change how the PF code is organised. say we're just fine with a serialised code execution on a single core if it comes down to handle a flow, but that doesn't mean that cpu cycles are there to be wasted on unoptimised execution. also for me is not clear whether the script should be run in a non-blocking or blocking manner. all in all, since its just a set of interpretable code, it would be quite unpredictable whether it is to be executed parallelised or not. the result would be varying delay that could potentially affect (read: ruin) TCP throughput.
i suggested logging and parsing as a workaround, albeit it is far from perfect. but at least you'll get your messages on fw rule match in a deterministic manner, and then its up to you how those elements will be parsed and interpreted by a script or an external entity (like stuff running on syslog server) - so the desired actions could be fired.
i think this fulfils your requirements of "hands shall not be bound", but also provides enough safeguarding for the "not so creative/unexperienced" users, whose forwarding performance would be seriously degraded by running code based on firewall rule matches. and for the RouterOS developers its always a give-and-take situation, where to go, what to risk: provide a very versatile toolset where you can do anything, which can (and most probably will) result a thousands of trouble-tickets and sad faces when used inappropriately, or leave it to be solved by the excessive creativity of the few ones who actually do require it. they need to think in the dimensions of megapackets per seconds for a while, and "tinkering" does not fit into the scope no more. and there is a whole world outside of RouterOS, a lots of tools that may be used to contribute to its original functionality, we just need to think outside the box.
on the example you quoted: inspecting packets as level7 filters do. my opinion on this is a bit mixed. L7 filters offer a pretty versatile approach for packet matching, but it is not intended to be used "with every single packet". there are quite well defined guidelines - presented on regular basis on MUMs by Mikrotik folks - how L7 filters are supposed to be used, or even more harsh: shall be used. and they should not be applied to every packet. because what you get is exactly the situation i described above.
https://mum.mikrotik.com/presentations/ ... 948376.pdf (slides 5 - 9)
https://mum.mikrotik.com/presentations/IT14/touw.pdf (slide 13 and on)
Wyz4k
Wed May 03, 2017 4:54 pm
I don't see why it's not possible to do the same with a run script on hit rule with some guidelines as you mention exists for the L7 rules. Unfortunately not everybody reads MUM slides.
Yes, the method that you describe of using a firewall rule and logging is an option, but potentially something that can become really messy really quickly.
You do make a good point about whether it should run in the background or block the forwarding of the packet and I would personally argue there that it should be in the background and not delay the forwarding of the packet. Doing it in the background will significantly reduce any knock-on effects on packet throughput providing that it does not get run on each packet and there are cpu cycles to spare.
doneware
Trainer
Trainer
Wed May 03, 2017 5:52 pm
seems we have to leave it to Mikrotik guys do decide which way to go :-)
Wyz4k
Thu May 04, 2017 7:46 am
Indupitably :)
Wyz4k
Wed May 10, 2017 8:11 am
Please add the ability to ping / ssh / telnet / other from the ip dhcp-server screen in winbox. This is already offered from the wireless registration page.
Any chance we could get the ability to form simple socket connections / ssh from the router in a script? Currently it's really one sided in that it's possible to connect to the router, but not possible for the router to automatically connect to other things.
makstex
Thu May 11, 2017 7:25 am
Please add compression for the OpenVPN client.
Wyz4k
Thu May 11, 2017 9:16 am
Could we get a proper AT command + reply interface?
Sending down AT commands in the info string and then having them randomly overwrite some output as a response is far from ideal.
On that same topic, it would be great if the /interface ppp-client info section can be rewritten to go away and read all the data and then come back with the data instead of having to be polled repeatedly hoping to get all the data after x polls.
felipelinkmais
Thu May 11, 2017 4:34 pm
I don't know if it was already sugested.. but mikrotik Traffic Flow could include BGP AS Numbers.
It is important to know what is going on with your network, and with the AS included a lot of things can be done.
Thanks!!
teddyhsu
Fri May 12, 2017 2:25 pm
I hope I can create a counter only supout file, that only take process information and count connections and users.
When my routerboard have more then 100K connections and 2000 users, making supout file will take more 2 hours and bigger then 1GB.
The heavy loading reboot is very hard to debug.
Wyz4k
Sat May 13, 2017 3:38 pm
I would like to request the required changes in order to allow 3G/LTE signal strength to be monitored on a continual basis without interrupting the signal - see https://forum.sierrawireless.com/viewto ... 108#p41108
nz_monkey
Mon May 15, 2017 12:20 pm
Thanks!!
:D this is one of the most highly requested features. It has been promised for the next major release of RouterOS. No ETA...
macsrwe
Tue May 16, 2017 10:11 pm
/ip firewall address-list has a creation-time field that is read only, although it appears in the add box. It would be quite handy if that were writeable at add time, such that the entry would take effect at whatever date and time is entered. This would allow us to schedule changes in account behavior at a future date without having to be sure to log in on that date to make it happen.
SiB
Wed May 17, 2017 10:14 am
Now I must create the same few rules in FILTER ICON again and again in many place of WinBox (I use AutoIt to do it like workaround)
PLEASE ADD the SAVE option for filtering rules.
I will be creating prifile filters like, dhcp with dynamic only, Arp static only, Contrack show network1, conntrack show net2 - You gotta idea. Open filters and select own save before filters rules - perfect.
CsXen
Wed May 17, 2017 11:19 am
Hi.
I know, that Mikrotik dropped the mipsle platform support... I know... but..
Please, backport two fantastic changes to mipsle, specifically to RB532.
1. WPS client mode.
2. EAP-PEAP-MSCHAPv2
Please, make a "routeros-mipsle-6.32.5" package with these features to make our old routers happier. :)
Thanks and best regards: CsXen
Vooray
Tue May 23, 2017 10:39 am
Please, add /31 mask on p2p support (rfc3021).
freemannnn
Forum Veteran
Forum Veteran
Mon May 29, 2017 3:12 pm
it would be nice in capsman interfaces tab a column with how many devices are connected per cap.
Murmaider
Mon May 29, 2017 8:46 pm
Thanks!!
+1 for this, it makes the current traffic flow implementation 99% complete. It's that 1% we all need to make it useful to anyone using BGP.
5nik
Thu Jun 01, 2017 12:58 pm
Please add support for DHCPInform for PPP link. It is usefull for Windows VPN clients (push additional info such as domain name, classless routes etc.). Now I must redirect DHCPInform request from PPP to external DHCP server.
Pilson
Fri Jun 02, 2017 9:40 pm
Please add support for setup l2tp client source portselection - set port by maunal, or set random port. Something like /interface l2tp-client set l2tp-out1 src-port=port_number, or src-port=random. It would be a very useful feature, especially if multiple l2tp clients + ipsec establishes connections from local network via one NAT address.
Thanks.
aacable
Sat Jun 10, 2017 8:35 am
'Unmetered Content' / to bypass local servers from radius accounting.
maznu
Sun Jun 11, 2017 1:45 am
You know how everyone's always saying "we want UDP support in OpenVPN" and "we want LZO"? And MikroTik say that their OVPN implementation is really nasty code that's hard to work on?
How about instead we look to the future: WireGuard https://www.wireguard.io
Clients for every major OS, modern cryptography, and the performance looks pretty amazing:
craterman
Sun Jun 11, 2017 11:07 am
Please add:
- Incremental SPF
- IP FRR (RFC5714) and microloops (RFC5715)
- LFA (RFC5286) & Remote LFA (RFC7490)
And it would be really great if you add:
- RSVP FRR (RFC4090)
- MRT (RFC7812)
Sob
Sun Jun 11, 2017 7:13 pm
About the WireGuard idea, are you a time traveller writing to us from future? :) I almost got excited, but at present time, things don't look so bright yet:
WireGuard is not yet complete. You should not rely on this code. It has not undergone proper degrees of security auditing and the protocol is still subject to change. We're working toward a stable 1.0 release, but that time has not yet come. There are experimental snapshots tagged with "0.0.YYYYMMDD", but these should not be considered real releases and they may contain security vulnerabilities (which would not be eligible for CVEs, since this is pre-release snapshot software). If you are packaging WireGuard, you must keep up to date with the snapshots.
So I think I'll stick with wanting better OpenVPN for a while, at least until this happens:
After version 1 is finalized, an RFC will be written and standardized.
maznu
Sun Jun 11, 2017 7:23 pm
Spoiler alert: Trump gets impeached!
…but I'm not going to reveal which one is released first: WireGuard v1.0 and RouterOS v7.0 :)
drivebydex
Wed Jun 14, 2017 11:53 pm
Please add in capsman registration table "active host name" and "active address"! THX
ajack46
Thu Jun 22, 2017 3:51 pm
Providing Compression for the OpenVPN client, would be something i would wish for.
biatche
Sat Jul 01, 2017 10:45 am
1. add /ip route check-gateway-ping-interval
2. ability to customize fasttrack rules a little bit. more dual wan friendly. right now i cannot figure out a way to have fasttrack with both ipsec and multi wan, although it does appear possible if its just one extra feature.
th0massin0
Sat Jul 01, 2017 4:34 pm
1. +1!
2. If your dual wan setup depends on mangle be aware of: https://wiki.mikrotik.com/wiki/Manual:IP/Fasttrack
Queues (except Queue Trees parented to interfaces), firewall filter and mangle rules will not be applied for FastTracked traffic.
biatche
Sat Jul 01, 2017 9:59 pm
1. +1!
i made some workarounds to make fasttrack+ipsec+dualwan all work together..but i really wish they'd come up with something better
biatche
Sat Jul 01, 2017 10:01 pm
/tool fetch keep-result (yes | no; Default: yes) If yes, creates an input file.
rename this to save-tofile or something.... from what i am seeing, keep-result appears to save the output to disk. or is it input? i've no idea anymore.
MT could possibly hire an englishman to straighten the terms out.
th0massin0
Mon Jul 03, 2017 1:22 am
Could you please describe how did you worked out port forwarding in dual wan environment with fasttrack?
platitude
Tue Jul 04, 2017 11:59 pm
DNSCrypt feature request topic has been started in 2012! Your customers waiting it about 5 years and still no support from you. Looks like you are not interested in customer's data privacy at all. Now open your eyes, read the message and satisfy us.
biatche
Sun Jul 09, 2017 2:42 am
add tool: tcp/udp open port tester.
pe1chl
Sun Jul 09, 2017 12:34 pm
Feature request: move all configuration related to one physical interface to another.
E.g. you have a router with two hardware switches or with ports inside/outside switch.
You have configured e.g. ether8 which is on switch2 with all kinds of options (address, dhcp server, firewall config, etc)
and you decide it would be better to move all this to ether4 which is on switch1, e.g. because you want to free up a port
that is on switch2, to do hardware switching to the other ports on that switch. It would be convenient when this could
be done with a single command, just like an interface can be renamed with a single command and it is reflected everywhere
in the config. After issuing that command and plugging the cable from port 8 to port 4, all functionality would remain the same.
For practical purposes (what would happen to the config that was on port 4), maybe the easiest implementation would
be in the form of "swap interface configurations" What was on ether4 will be on ether8 and vice-versa.
msatter
Sun Jul 09, 2017 2:21 pm
When adding an adress in large adress-list is a PITA when an address already exits. The the script is stopped an you can work with on-error to seek sequential through the list use set to update it timeout on the dynamic address. This takes ages when you have to seek each time.
On the moment you get collision it would be a pleasure to be able to directly use set on that entry to set the expire time in the on-error.
cental63
Sun Jul 09, 2017 6:22 pm
I find that Userman is a really good choice to build a hotspot service for a company, but i think, as installer, that there is something missing, few things like embedded sms verification (and not the script), and the one that i found more interesting, make the userman database readable (just think about a company with a newsletter). All could be added to make userman like a serious radius server (chr would allows more performance for anought clients). more competitive !
Thats all :o
Regards from an Italian user
schadom
Sun Jul 09, 2017 7:56 pm
Please add the 'Comments' column and the 'Add/Edit Comment Button' which is currently missing in WinBox 3.11 under
Routing =>BGP => Networks
Routing => BGP => Aggregates
Interestingly it is available in Routing => OSPF => Networks, but missing in all of the other tabs
While I personally prefer the CLI for configuration, WinBox is nice to get a quick overview.
Wyz4k
Thu Aug 10, 2017 1:39 pm
Please add SMB support to the fetch tool or the ability to limit FTP accounts to specific folders to the FTP server. The SMB server is considerably more advanced than the FTP server on Mikrotik and makes it easier to limit clients to a specific folder.
pe1chl
Fri Aug 11, 2017 12:16 pm
/queue tree elements can now only match on "packet marks", when multiple packet marks are specified they are OR'ed.
Please add the capability to also match on the "packet priority" field, and make it an AND match with the packet marks.
(so if a queue tree element is specified with both packet marks and a priority, it will only be used when one of the specified packet
marks is present AND the priority field of the packet is as specified)
Alternatively, introduce the option of doing an AND match on packet marks. It is already possible (although cumbersome)
to add packet marks based on the packet priority field.
dgrenetz
Wed Sep 13, 2017 2:31 am
We are deploying Mikrotik virtual appliances to centralize and replace several disparate VPN solutions. We need a way to hand out our domain suffix to VPN clients so they won't have to use Netbios broadcast to resolve names. Currently, without domain suffix setting, accessing hosts by hostname takes about 5 seconds longer than it does on our existing legacy VPN solutions. I Googled the issue and see people complaining about this all the way back to 2010. However I do not see it anywhere in this Feature Request thread. Longstanding issue - please help!!
David
diasem
Tue Sep 19, 2017 1:22 am
Normis add /31 address for PTP links.
Chupaka
Tue Sep 19, 2017 10:23 am
/ip address add interface=ether1 address=192.0.2.2/32 network=192.0.2.3
vytuz
Tue Sep 19, 2017 3:09 pm
Do You maybe have in plans to make more detailed user group list? Different user access to i.e. wireless, firewall filter, nat rules, ip addresses, dhcp and etc. I imagine it may be hard to add databases and additional cunfiguration to every configuration field. Maybe any possibility to add at least additional wireless user option. Clients sometimes wants to change wifi name, password, but we do not want to allow to change other options with given password.
nelfou
Fri Sep 22, 2017 1:07 pm
Being able to customize the hAP WPS button behavior, like having it trigger a script.
(our use case would be to easily turn the Wi-Fi on/off)
Vooray
Sat Sep 23, 2017 8:42 pm
Hey, Mikrotik team!
Please extend "netwatch" funtionality a little bit. It is a nice feature, but so undeveloped.
It will be nice to have an option to set amount of ping to send before change status to down and at its frequency.
Chupaka
Mon Sep 25, 2017 11:01 am
... and routing table/vrf :)
OnixJonix
Tue Sep 26, 2017 12:37 pm
Make Address List from DHCP lease table!!
For example - select multiple LEASE entries and put them in address list (then you can use for firewall)!! Something like in wirelless - you can add entries from registration table to access list!!
Thansk!
jarda
Tue Sep 26, 2017 1:53 pm
Lease script doesn't work for you in this case?
Chupaka
Tue Sep 26, 2017 3:59 pm
Looks like he needs it in WinBox (one-time context menu like 'Make static' or something)
By the way, if your leases are static, you can just set 'Address List' for them
bajodel
Long time Member
Long time Member
Wed Sep 27, 2017 12:41 am
Hey, Mikrotik team!
..and the possibility to set source address (e.g. remote ipsec hosts)
TomjNorthIdaho
Wed Sep 27, 2017 1:46 am
Hey, Mikrotik team!
Netwatch can trigger a script.
Example - my netwatch:
/tool netwatch
add comment="Watch Dog" down-script="log info \"Netwatch missed a ping to 192.0.2.254 - starting 5 minute timeout script\" ; /system script run NetWatchBoot-192.0.2.254" host=192.0.2.254 timeout=1s500ms
Example - My script called by netwatch:
/system script
add name=NetWatchBoot-192.0.2.254 owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":local addresstoping 192.0.2.254;
:local interface "wlan1";
:local continue true;
:local counter 0;
:local maxcounter 28;
:local sleepseconds 10;
:local goodpings 0;
:log error "-----> Tom's Netwatch-Script-Warning - Netwatch could not ping $addresstoping - Will begin further testing in $sleepseconds seconds - and will continue for $maxcounter times $sleepseconds seconds";
:while ($continue) do={
:set counter ($counter + 1);
:delay $sleepseconds;
:if ([/ping $addresstoping interval=1 count=1] =0) do={
:log info "----->ping to $addresstoping failed on attempt $counter of $maxcounter -- Will try again in $sleepseconds seconds";
} else {
:log warning "-----> ping success on to $addresstoping attempt $counter of $maxcounter <----- No Further testing needed --- Program will exit -----";
:set continue false;
:set goodpings ($goodpings +1);
/interface wireless monitor $interface once without-paging do={
:local status $"status";
:local band $"band";
:local freq $"frequency";
:local wprotocol $"wireless-protocol";
:local noise $"noise-floor";
:local signal $"signal-strength";
:local snr $"signal-to-noise";
:local thruput $"p-throughput";
:log info "-----> Status: $status --- Band: $band --- Frequency: $frequency --- WProtocol: $wprotocol --- NoiseFloor: $noise";
:log info "-----> Optional Info if Available ---> SignalStrength: $signal --- SNR: $signal --- PThroughput: $throughput";
:local txr $"tx-rate";
:local rxr $"rx-rate";
:local sstr $"signal-strength";
:local signoise $"signal-to-noise";
:local curdistance $"current-distance";
:local txccq $"tx-ccq";
:local rxccq $"rx-ccq";
:log info "-----> TxRate: $txr --- RxRate: $rxr --- SignalStreng: $sstr --- SignalToNoise: $signoise --- CurrentDistance: $curdistance --- TxCcq: $txccq --- RxCcq: $rxccq";
:if ($counter=$maxcounter) do={:set continue false;}
:if ($"goodpings" = 0 ) do={
:log info "-----> Rebooting in 15 seconds";
:delay 5;
/file print file=ScriptRebootReason
/file set ScriptRebootReason.txt contents="Rebooted by Toms script on $[/system clock get date] at $[/system clock get time]"
:log error "-----> Rebooting in 10 seconds";
:delay 5;
:log error "-----> Rebooting in 5 seconds";
:delay 5;
:log error "-----> Rebooting now";
:delay 1;
/system reboot
/system reboot
/system reboot
/system reboot
With the above - a netwatch ping failure will trigger my script "NetWatchBoot-192.0.2.254"
The script will retry the ping for (:local maxcounter 28) 28 times
While pausing (:local sleepseconds 10;) 10 seconds between pings
If the script gets a ping response, the script aborts - and make a log.
If the script loops through the count-down and does not get a ping, the script will reboot the Mikrotik - and make a file named ScriptRebootReason just prior to the reboot.
I am sure this netwatch & script procedure could be modified to do many things you may want when netwatch triggers.
In my case, I have this netwatch & script on all of my Mikrotik client devices and all of my internal core network Mikrotik devices. The IP address 192.0.2.254 is an RFC IP address and is OK to use for in-house (non-external-Internet-Routed). If I want to reboot every Mikrotik everywhere on my network, all I need to do is disable the 192.0.2.254 device a few minutes. Presto - everything everywhere will auto-reboot. This is good for keeping Mikrotiks on-line when the network might have a problem.
North Idaho Tom Jones
ZeroByte
Wed Sep 27, 2017 1:57 am
Selectable auth mechanisms for RADIUS-based AAA on system login.
currently it varies based on the access vector, and Winbox requires chap which requires reversible cryto / plaintext password store.
Or add LDAP auth client, but I'm sure simply allowing MS-CHAPv2 / PAP as auth mechanisms for existing RADIUS would be a much easier solution.
nz_monkey
Wed Sep 27, 2017 10:31 am
+1
anv
Openvpn server route push
Mon Oct 16, 2017 3:23 pm
Routeros openvpn server needs a way to push routes to the clients.
CsXen
Sat Oct 21, 2017 6:51 pm
Hi.
It will be nice to have an option to make color-able any log entry.
For example, I wanna paint wifi log to green, ppp log to purple, interface log to cyan... or to other color, so I can find then faster with an eyeblick. :)
(I think, ANSI colors would be enough, but more color, more fun.)
An please, put a "find" option to log.
Best regards: Xen
WreckLoose
Tue Oct 24, 2017 11:25 pm
Yes, I think that a great feature would be greater support for Intel network interfaces. Most notably the I218 stuff. I would love top be able to run RouterOS in the Intel NUC.
TomjNorthIdaho
Wed Oct 25, 2017 6:48 pm
Hi.
Best regards: Xen
It might be nice to have an option for color in the logs.
There is a work-around that I use which gives me three colors in my logs.
In your script that writes to the logs (or at the CLI prompt) you can use this:
log error "This is a log error --- RED"
log info "This is a log info --- BLACK"
log warning "This is a log warning --- Blue"
With the above 3 lines, you will see this in your logs:
gorec2005
Fri Nov 03, 2017 6:43 am
Add please shadowsocks server & client ?
safiullahtariq
Sun Nov 26, 2017 2:30 pm
Can you please add a feature in which Hotspot doesn't account the local traffic, or to a specific subnet?
kometchtech
Fri Dec 01, 2017 4:15 pm
Despite being asked before in the past.
It seems that implementation of Wireguard is planned for the future Kernel.
https://www.phoronix.com/scan.php?page= ... d-Features
I would like you to consider implementing this function which has high encryption strength and excellent performance.
It seems that correspondence to several distributions is progressing as well.
Florian
Tue Dec 19, 2017 2:23 pm
I know it's not ready yet, but +1 on Wireguard.
pe1chl
Tue Dec 19, 2017 2:36 pm
When you read "it is planned in a future Linux kernel" you know it is not going to happen in RouterOS 6.x and probably not in 7.x either (because a kernel version probably has been decided on).
So, you can put it on the wishlist for RouterOS 8.x
Florian
Tue Dec 19, 2017 2:39 pm
I guess so, but, It's to show the devs my (or "ours") interest in this, if they can find a way to implement it, some people would be very happy.
lavv17
Mon Dec 25, 2017 2:59 pm
I'd like to have a setting to change ppp aaa order: radius first, then local. The default is now local first.
ege
Tue Dec 26, 2017 6:52 pm
SSL Bump feature for webproxy like Squid-in-the-middle.
eccles
Re: Feature requests - OpenVPN Options
Thu Dec 28, 2017 2:10 am
We really need two options which are normally provided with OpenVPN on most Routers:
a) LZO Compression - I suspect that this might be an issue if the CPU doesn't natively support it
b) UDP - We can achieve faster transmission (with less bandwidth) by using UDP instead of TCP. UDP is an OpenVPN option provided on all other routers that I have worked with. Our protocol incorporates all of the required checking to ensure reliable delivery so the additional overhead of TCP isn't required or justified.
The reason is that we are using the wapLTE device at remote sites with 4-G transmission of datalogging records to a central site. Bandwidth is expensive (we pay by the MB/GB). We have done what we can by reducing transmissions to one per day, etc. but with the increasing number of remote sites the cost of traffic is becoming a real issue. It seems that the local ISPs are wanting to capitalise on IoT device traffic, but in any case cellular data transfer is very expensive here.
Eric
pamribeirox
IPv6 Default Router Preferences (RFC4191)
Thu Dec 28, 2017 1:37 pm
It should be very simple to add support for selecting the bits of the IPv6 RA that announce if the router have "High", "Medium" or "Low" preference for being selected as a default router for the terminals in the segment. (RFC4191 2.1 Preference values)
I know VRRP could be used for that, but I think this clean and native solution is better for IPv6 first hop redundancy.
As an example, Cisco does it with the command "ipv6 nd router-preference [High|Low|Medium]" at interface level.
regards.
pe1chl
Re: IPv6 Default Router Preferences (RFC4191)
Thu Dec 28, 2017 1:50 pm
I hope 2018 will be the year that MikroTik finally continue working on IPv6 support.
pamribeirox
IPv6 replacing the link-local address
Thu Dec 28, 2017 2:06 pm
To ease the management of IPv6 networks is useful as a first step to base them on the existing IPv4 network structure.
One of the things that could be done is using some elements embedded in the IPv6 link-local address so the Windows "ipconfig /all" (and alike from other OSs) provide an simple way to verify the terminal are correctly connected/configured.
RouterOS should allow us to change the IPv6 link-local address from the default one (based on EUI-64 logic) to a manual defined address in the block reserved for link-locals in the RFC4291 (fe80::/10)
Then, as an example, the interface with IPv4 address 192.0.2.1 could also have an IPv6 LL fe90::192:0:2:1
regards.
pe1chl
Mon Jan 01, 2018 1:23 pm
Feature request: enable WMM (QoS based on DSCP) for WiFi interfaces (preferably by default) without having to use mangle rules to set priority based on DSCP.
The disadvantage of mangle rules is that they only work when all "fast" options are disabled and when the "use IP firewall" is enabled on the bridge.
Competing products have WMM enabled by default without having to configure anything. In MikroTik it requires settings like:
/interface bridge settings
set allow-fast-path=no use-ip-firewall=yes
/ip settings
/ip firewall mangle
add action=set-priority chain=postrouting new-priority=from-dscp-high-3-bits passthrough=yes
and deleting the "fast track" rules.
As some of these have quite global effect on performance, it would be preferable to have some way of just doing WMM with a simple checkmark in the Wireless settings.
(there is one, but it does not do the prioritization)
moose999
Feature request - Granular User Levels
Tue Jan 16, 2018 12:49 pm
I am aware I can control access to services (web, winbox, api, etc.) and rights (read, write, sensitive, etc.) but it would be very useful to be able to control access to features (/ip firewall nat for example) as well.
Does anyone know if this is possible?
Thanks,
Justin.
upower3
Thu Jan 18, 2018 8:59 am
Vote for https://www.wireguard.com/ , nice VPN which appears to be supported in systemd 237 (read: on every modern Linux - https://github.com/systemd/systemd/pull/4191 ). Universal VPN technology so to say, just a shame not to be able to connect to.
ViennaAustria
rinetd
Thu Mar 01, 2018 9:23 am
I'd like to re-request the function of rinetd.
https://boutell.com/rinetd/
http://brewformulas.org/Rinetd
We have several applications, where local devices cannot change their default gateway (DSL or LTE modems for example), which do not point to the mikrotik router. So port forwarding does not allow uns to access these devices from remote (telnet, SSH, webinterface, SNMP, ...). A local linux box running rinetd gives us access to this device. But a local linux box adds €/$ 200,- to the budget.
If a rinetd-like function would be added to RouterOS it would be GREAT!
Thanks!
Thomas
upower3
Re: rinetd
Thu Mar 01, 2018 9:28 am
I might me a bit wrong but why don't you just use NAT?
pe1chl
Re: rinetd
Thu Mar 01, 2018 12:16 pm
Never heard of that before, but I did similar things in the past using "netcat" ("nc")
You can do the same thing on a MikroTik using a src-nat and a dst-nat rule!
HOW???
A local linux box can be a Raspberry Pi which would be more like $50.
wtm
Sun Mar 04, 2018 2:06 am
Would like to see a Radius tester available for the "Tools section". Something along the lines of Radtest, so you can see that the external radius server is actually getting something from the Mikrotik router, and if not what the problem may be to fix it. Currently there is not enough information available in the Logging to help you on that.
Quasar
Fri Mar 09, 2018 2:45 pm
Another +1 for me. Please implement this, as WireGuard is steadily moving towards mainline kernel inclusion.
Virtual private networks with WireGuard
gerakon
Wed Mar 21, 2018 3:46 pm
In Winbox I think the Dashboard menu could go away and just have all of it's items enabled by default. Unless there's some reason people don't want to see this information or there is some amount of overhead on the router.
If it can't go away, it would be great if it would at least remember my settings between routers so that I don't have to re-enable them to compare times more easily between routers that are having IPSEC negotiation problems or when the CPU is maxed.
pe1chl
Wed Mar 21, 2018 5:01 pm
This is just a special case of the generic feature request to have some way of sharing settings in winbox between a large number of routers.
Some other requests have been seen to e.g. allow "set current winbox settings as default for new connections" and/or to simply allow
the sharing of the same settings between all routers in a Group.
mrz
Wed Mar 21, 2018 5:07 pm
This is already possible.
Connect to one router. Set columns you want to see, open windows etc.
Select session/save as
Next time before connecting to new router pick saved session.
pe1chl
Wed Mar 21, 2018 5:35 pm
- there should be some way to "save as default"
- there should be some way to interconnect the settings of a Group, so when you add some column to one window in one router out of that group, it is then also shown in all other routers from that group that you already had added (maybe some way to allow an entire group to share a single session file)
- and of course: the widget to select colums should be improved. add a dialog that can be opened that shows all possible columns with a checkmark field, allow the user to select/unselect multiple columns, and click OK to finish. this instead of the cumbersome column list that has to be accessed via 2 levels of menues and often does not fit on the screen so has to be scrolled as well.
hackclub
Wed Mar 21, 2018 8:51 pm
urgent request to (for) mikrotik
viewtopic.php?f=1&t=132062
gerakon
Thu Mar 22, 2018 12:26 am
But then I have to do that on each of the hundreds of routers in my Winbox managed sessions list.... Right? I guess my point is that I see no reason at all why someone would not want to see the dashboard information in the upper right. Is there a reason? It's just extra stuff (menu options) that doesn't need to be there. Turn them on all the time for every session and just get rid of the Dashboard menu.
Unless there's some reason that I'm not seeing?
TomjNorthIdaho
Please increase Simple-Queue limits - they max at 4,294 Meg
Thu Mar 22, 2018 12:28 am
Please increase Simple-Queue limits - they max at 4,294 Meg (aka 4.294 Gig)
ROS Simple-Queue - please increase the possible maximum limits and thresholds.
Currently on v6.41.3 and v6.41.2 (don't know about older versions) ,
The maximum possible value for "Max Limit" and "Burst Limit" and "Burst Threshold" is "4294M"
The Simple queue will not accept any higher numbers.
This presents a problem. I have multiple 10-Gig networks and on some networks I must use bandwidth limiters which are much faster than the built-in restricted values.
An example of need: 10-Gig physical Internet connection - Purchased Internet speed need to be maintained by my network equipment. Problem - the Mikrotik ROS will not accept any values greater than 4294M in any of the Winbox Simple-Queue fields
mkx
Re: Please increase Simple-Queue limits - they max at 4,294 Meg
Thu Mar 22, 2018 11:25 am
Seems like setting is set in 32-bit integer with unit of bits per second. This might pose an architectural problem and we can only hope it can be solved easily.
Perhaps by giving us possibility to set unit ... e.g. bits/second (default, current setting) or kbps (gives 1000-times higher limits) or Mbps. After all, with Gbps speeds it is not really sensible to set limits with bps resolution. Or is it?
pe1chl
Thu Mar 22, 2018 11:43 am
That is correct, the underlying Linux mechanisms being used have limitations and it was likely designed with the rationale "when you have that much bandwidth
it is not really required to shape it". It also would incur a lot of CPU overhead to do that.
WirelessRudy
Thu Mar 22, 2018 12:02 pm
This is what I have been asking for several times over the years. It's good someone else now asks again.
Somewhere some Mikrotik guy decided what the default settings are when on a virgin router a virgin winbox is openend. I would like to be able to just change that 'virgin' setting myself.
By default winbox shows a lot of info I have never interest in. But many other field I need everytime again are not there by default.... Especial when you work with many PC's it would be easy to have one winbox.exe that is everywhere the same to MY like.
TomjNorthIdaho
Thu Mar 22, 2018 5:09 pm
Well, I would suppose that if somebody (like me) needs a simple-queue setting in any of the fields greater than 4294-Meg, then they are likely running something with a big-beefy-CPU , such as a CHR on a fast Xeon processor or possibly a high-end or current or future Mikrotik hardware product.
I am pretty sure my CHR-x86-64Bit and my ROS-x86-32-Bit systems have plenty of CPU horse-power. All of my virtual ROS systems can btest to 127.0.0.1 in the 19+Gig ranges. (btest uses only 1-core. Now if you use 8+ cores (hyper-threading disabled for maximum CPU throughput) then I would assume possible system-wide-throughput might be 8x greater.
(My next hyper-visor system I am planning to build soon will allow me to configure 44 Xeon CPU cores to a hosted system - such as a CHR.)
Also , just about all new carrier-grade network equipment has one or more 10-Gig interfaces. Thus another reason for a simple-queue fix/update is needed.
Also - remember the Mikrotik post about "What would you like to see in a future Mikrotik ...something... with a 40-Gig throughput..." Thus another reason for a simple-queue fix/update.
Everything in my server room and my Internet feed uses 10-Gig interfaces. And I need an ability to use simple-queues up to 10-Gig.
artemk
Sat Mar 24, 2018 8:07 pm
+1
It works for SSH but it would be really good to make Winbox to be able to authenticate via radius.
ahmedramze
Sun Mar 25, 2018 4:34 pm
Hello
to disable DNS attacking
please add listen address on better from use ip firewall filters
/ip dns allow-remote-requist=yes
/ip dns listen-src-address=192.168.88.0/24,x.xx,y.y.y
Regards
ivicask
Sun Mar 25, 2018 4:39 pm
Hello
Regards
Cant you already do that via firewall, dont understand what more you need, if you want to block DNS requests form outside net, or alow only DNS requests from that ip range simple make firewall rule with tcp/udp 53 ports..
Sob
Sun Mar 25, 2018 8:52 pm
... if you want to block DNS requests form outside net, or alow only DNS requests from that ip range simple make firewall rule with tcp/udp 53 ports..
All other services have something like that. Api, ftp, ssh, telnet, winbox and www have "available from" option in IP->Services, smb allows to choose interface. If it makes sense for them, surely it would make sense for dns too.
sarada
Sun Apr 01, 2018 11:03 pm
Can you add a feature in User manager which support WPA EAP and add 6to4 tunnel to vlan or bridge, please?
Railander
Thu Apr 05, 2018 7:50 pm
Feature Request:
With the use of interface-lists, set customized permissions to which interfaces a user (and preferably also snmp community) can see or make changes to.
Some of our clients like to have read access to our routers, but sometimes it's a router supplying more than one client and giving even read access would mean they could see every other customer in it.
Currently we work around this using Traffic Flow, but it's not real time and generates a lot of traffic and CPU overhead.
doneware
Trainer
Trainer
Sat Apr 07, 2018 9:32 pm
this might be two things however. while the interface statistics could be worked out with "/tool graphing" even with resource visibility separation - currently using src ip address as differentiator - the "editing" part is tough. so if you can separate your customers based on ip address, you can define which interface/queue/resource the user may be viewing on the router's web gui.
but i don't really think this is a good idea, as routers are to forward packets and to run web servers. if you want real granular read/write control for defined routeros resources (interface, addresses, queues) you will be better off with an external web server using API integration.
pepek
Tue Apr 10, 2018 1:14 am
I've tried to search this topic, but I haven't found it (hope there are not any duplicates):
NTP Client - Possibility to use server name, not just IP address
exFAT (FAT64) or NTFS support - yes, MT is not NAS (it's slow), but it would be great to use file system capable of handling >4GB file complatible with Windows (you have HDD with big files and you want to share some files - you cannot connect it to MT, you have to reformat it to FAT32, copy everything except for big files back...)
Wireless - move Country and Distance setting to Simple Mode - you can set every other important "basic" setting in simple mode, but you have to switch to Advanced Mode for these two settings.
Quick Set - It's working with WPA1 password. It doesn't recognise, when you manually set WPA2-PSK AES only password. It requires also setting WPA1 password (even if WPA1 is not allowed), otherwise Quick Set shows WiFi password red and empty (WPA2 only is used)
zappulec
Tue Apr 10, 2018 6:15 pm
Secured DNS
- DNS over HTTPS
- DNS over TLS
pe1chl
Wed Apr 11, 2018 10:34 am
You will have to learn and understand that you should use QuickSet only ONCE and not look at it later!
It provides an overview of some basic config but it is not showing correct values after you made manual changes (not only this!) and should you later change some
things via QuickSet you will seriously mess up the configuration!
So please don't worry about things like this and don't use QuickSet.
In fact a more appropriate feature request would be: make QuickSet disappear once it has been used and manual changes have been made afterwards.
That would protect a lot of beginners from serious trouble.
miencek
Wed Apr 11, 2018 11:55 am
RAM Disk for temporaty files ex. configuration to/from other devices, scripts
pudjo
Request : alternative DNS Port for IP DNS Setting
Tue Apr 17, 2018 1:04 am
I've been waiting for along time MikroTik can provide alternative port for IP DNS Setting, other than 53 (default)
normally user input value ip address such as 8.8.8.8 and 8.8.4.4 for IP DNS Setting
alternative port, for example, can be set as easy as 8.8.8.8:553 and 8.8.4.4:533
The purpose is to get DNS service from non default port DNS Server.
Any response is greately appreciated,
Thank You
Miracle
Re: Request : alternative DNS Port for IP DNS Setting
Tue Apr 17, 2018 5:48 am
Thank You
Do you know dst-nat ?
Chupaka
Tue Apr 17, 2018 5:53 pm
Is there any DNS server on port other than 53?..
TomjNorthIdaho
Tue Apr 17, 2018 7:52 pm
There are some non port 53 DNS configurations/uses.
Example: DNS over TLS is often port 853 -and- I kinda remember something about 135 End-Point-Mapper being used also for DNS
Also - security through obscurity can help prevent some attacks - such as running ssh on non-standard ports , DNS could possibly be remapped to use a non-standard port other than 53 to achieve a security through obscurity.
However , the standard well-known DNS port is 53. I would think if there is a security concern , that a FW configuration would be easier and more compatible method to control DNS access and better prevent attacks against DNS servers.
pe1chl
Tue Apr 17, 2018 8:06 pm
The intended use case is probably where the ISP blocks or redirects access to port 53 outside (only allowing acces to their own resolvers)
but does not have advanced DPI in place. Then just using a different port may circumvent their efforts. E.g. OpenDNS listens on port 5353,
and one could sents the requests there. I don't know if Google DNS and CloudFlare DNS have similar alternate ports.
Of course this works only until the ISP admins know it and block or redirect that port as well. Not worth it to make a change in the router
for that, just use dst-nat.
Sob
Tue Apr 17, 2018 9:48 pm
Not worth it to make a change in the router for that, just use dst-nat.
Current RouterOS stores IP address of resolver and uses hardcoded port 53. Changing it to store IP address and port doesn't sound like anything big. But I guess dstnat would be enough. It's just that as it is now, you can do it only for clients, not for router itself. If router requires resolver on alternative port for own use, or if you want alternative port and also router as resolver for clients (because of caching, or because you want to override some records), you can't do it. It would require support for dstnat in output chain.
pe1chl
Tue Apr 17, 2018 11:10 pm
It may be possible to use a loopback interface and set the DNS server address to the address of this interface, then dstnat that traffic.
(I did not try, but I *do* use dstnat for traffic incoming to a router and that works)
msatter
Tue Apr 17, 2018 11:42 pm
Or you use an local DNS server on a RaspberryPI like DNSmasq, PiHole, etc.and you are able to control it all yourself.
TomjNorthIdaho
Wed Apr 18, 2018 1:17 am
As stupid as it might sound -almost a lol-
What happens if you add ":XY" to the IP address of the DNS server , where XY is the port #
Say you wanted you mikrotik to use port 5320
then use IP address format of the DNS server of:
a.b.c.d:5320
I remember this working on an old DSL router 15 years ago.
Sob
Wed Apr 18, 2018 2:03 am
@pe1chl: No, dstnat happens in prerouting, so traffic coming to router (no matter if it will end up in forward or input) can be matched by dstnat rule. Traffic from router doesn't come through prerouting in RouterOS.
@msatter: External device would work fine, but sometimes it may not be desired or even possible to add it.
@TomjNorthIdaho: Nope, to quote WinBox: "Error in - non zero ip address or non zero ipv6 address expected!"
But something can be done. I posted possible solution in the other thread, because it belongs there more. But I don't like it.
pe1chl
Wed Apr 18, 2018 10:38 am
Ok apparently it needs a real loop, I was thinking about adding a loopback interface (an empty bridge with an IP address) and sending the DNS queries there.
But maybe the address is considered local and it does not work then.
Chupakabra303
Wed Apr 18, 2018 1:39 pm
file get contents
Increase threshold 4096 byte, while reading the file or make the file reading by pieces. 4K is too little!
pe1chl
Wed Apr 18, 2018 2:34 pm
file get contents
It is not a limitation of those routines, but of the maximal length of a variable content.
What is needed is an open/readline/close feature so files can be read line-by-line into a variable.
(for completeness also a read(n) to read a fixed number of bytes instead of a single line)
juliokato
Wed Apr 18, 2018 3:44 pm
I have a solution to decrease costs with DNS filters like OpenDNS or SafeDNS, using a DNS resolver intermediate on UDP port 5353. All my 100 MK with different valid IPs points to this resolver.
This also helps in the security of this resolver.
I can give you more details if anyone has an interest.
Chupaka
Wed Apr 18, 2018 4:25 pm
So how do you point your Windows/Linux/MacOS machine to some non-53 DNS port?..
juliokato
Wed Apr 18, 2018 8:32 pm
I was using firewall nat:
add action=dst-nat chain=dstnat disabled=no dst-port=53 log=yes protocol=udp to-addresses=aa.bb.cc.dd to-ports=5353
this forces anyone to use my resolver, even if some user tries to use another different dns server.
This has other implications of redundance and security that is not part of this topic.
fernandolcx
Thu Apr 19, 2018 6:06 pm
Feature Request:
Actually it's possible to get a total number of active PPPoE sessions via SNMP using this OID:
1.3.6.1.4.1.9.9.150.1.1.1.0
But if we could get this number in a per interface (or PPPoE Server name) basis, should help to detect and troubleshoot issues when using
Mikrotik routers as BRAS/BNG/PPPoE Server.
If a large number of active sessions from a specific interface or servicename drops suddenly, any monitoring application can trigger an alarm for that interface/servicename.
To workaround we can use this:
/interface pppoe-server print count-only where service=service5
BUT it should be a nice feature to add to SNMP
samsung172
Fri Apr 20, 2018 12:20 am
Feature Request:
You can have this info from the radius server. (if used)
raymondr15
Fri Apr 20, 2018 1:34 am
Please add the ability to enable or disable successful login attempts for specific users, for example an API user, accounting software logging in and out updating information on the router.
lordcoke
Fri Apr 20, 2018 4:03 pm
Feature request for /tool sniffer. Please make it possible to submit a filter-port range to the sniffer to allow sniffing like this:
/tool sniffer set filter-ip-protocol=udp filter-port=32000-32255
pudjo
Mon Apr 23, 2018 3:16 pm
i have run several DNS servers using many port other than 53, the purpose is for internet filtering, users can select filtering level by choosing dns port, check out https://www.thenetpurifier.com/filtering.php
pudjo
Mon Apr 23, 2018 6:43 pm
vote +1 for dstnat in output chain
pudjo
Mon Apr 23, 2018 6:45 pm
Thank You
dst-nat not working in output chain, AFAIK
lugovoyma
Mon Apr 23, 2018 8:20 pm
openvpn UDP
pe1chl
Wed Apr 25, 2018 5:07 pm
Now that ip firewall address-list (and ipv6 firewall address-list) support DNS lookups, add a way to get subnet entries from DNS.
Unfortunately there is no standard DNS record type for subnets. There is the experimental APL record type (RFC3123) which would be exactly what is needed, but it isn't supported in DNS servers.
Therefore, I suggest to use TXT records.
Do a query for TXT records for the specified name (after or in parallel to the A and AAAA records already queried) and for each TXT record coming back, check if it conforms to valid subnet notation like 11.22.33.0/24 or 11:22:33:44::/64 and if valid, add it as an address list item.
Sob
Wed Apr 25, 2018 8:12 pm
If you have your own authoritative servers, some already have native support for APL (at least BIND and Knot DNS). And any sensible server allows to add unknown record types using generic syntax. If you have hosted DNS and you depend on some admin interface, it's another story and I guess support there will be very bad. That was the authoritative part. Resolvers should be transparent for unknown types since forever.
So it may sound perhaps a little too optimistic, but I'd say it's almost there. And a gentle push (like MikroTik adding support in RouterOS) might help to move things forward. Some people could start using it right away and others would have motivation to nag their DNS providers to add support.
erebusodora
Wed Apr 25, 2018 8:20 pm
It would be very nice to have a feature to hide rows. Column Hide and Show Footer Works is a great job on the look. Screenshot feature must be implementet too.
pe1chl
Wed Apr 25, 2018 8:28 pm
I googled for it and I cannot find any DNS server that has documented APL support, including Bind. We use bind 9.
However, if it is supported it would be fine to use APL. Probably with TXT there are less obstacles.
Sob
Wed Apr 25, 2018 10:31 pm
It doesn't seem to be advertised much, but it looks like BIND has it since 2002.
Advantage of using TXT would be instant availability everywhere. Probably even better reliability, at least in short term, because some broken resolvers will surely show up somewhere. But it's reinventing the wheel. Purists might also argue that we don't need yet another thing in TXT, there's enough of them already.
hurymak
Thu Apr 26, 2018 1:54 pm
Encrypt nand filesystem, so when some thieve unsolder it, cant read my config.
cis2131
Thu Apr 26, 2018 11:11 pm
Run a script when a port is closed by loop protect.
PtDragon
Fri Apr 27, 2018 12:08 am
Small feature request:
Please make Syn Cookies tunable!
I explain a bit: right now we can only turn on or off.
I wish we could have cookie timeout tunable in our hands (so if no cookie reply for example in 5 or 10 or 30 sec just drop connection).
That will make defense way easier :)
Chupaka
Tue May 01, 2018 3:26 pm
So, you'll need to enter encryption password each time router reboots? :)
5nik
Mon May 07, 2018 12:29 pm
Please, implement bandstearing for wifi, especially in CAPsMAN.
Please, add support 802.1x for wire interfaces.
pedromrocha
Mon May 07, 2018 2:48 pm
Please implement TACACS autentication.
We can't get your equipments certified in a ISP without that feature.
netwpl
Wed May 09, 2018 8:37 am
1+
psannz
Wed May 09, 2018 9:15 am
Yes! +1, pretty please?
TomjNorthIdaho
Simple Queues - Please increase limits - they max at 4,294 Meg
Wed May 09, 2018 9:29 pm
BUMP - I originally posted this: Wed Mar 21, 2018 3:28 pm
Currently on v6.41.3 and v6.41.2 (don't know about older versions and I have read nothing in newer versions) ,
The current maximum possible value for "Max Limit" and "Burst Limit" and "Burst Threshold" is "4294M"
This presents a huge problem. I have multiple 10-Gig networks and on some networks I must use bandwidth limiters which are much faster than the built-in restricted values.
An example of need: 10-Gig physical Internet connection (using CHR) - Purchased Internet speed need to be maintained by my network equipment. Problem - the Mikrotik ROS will not accept any values greater than 4294M in any of the Winbox Simple-Queue fields
Chupaka
Thu May 10, 2018 11:39 am
Tom, did you write to support@mikrotik.com ? Because this looks not like feature request but like important fix :)
pe1chl
Thu May 10, 2018 6:45 pm
No this is just established standard functionality hitting limitations as technology proceeds.
The queue mechanism uses 32-bit values (variables) and so the values are limited to 2^32
In fact practical limits are lower because "buckets of data" have to be calculated to be transmitted on each timer tick
and when the datarate gets so high the buckets become very large and those bursts could hit other limits or not play
along with others as nicely as you would like.
So it is not as easy to fix as you might think.
TomjNorthIdaho
Fri May 11, 2018 6:48 pm
I suspect the simple-queue maximum value settings are going to be a bigger and bigger problem in the near future. - because of the new Mikrotik 40-Gig interfaces and newer/faster CPUs.
I can't help but wonder how much of the 64-Bit CHR software actually uses 64-bit instrustions.
Many 64-bit CPU instructions use fewer CPU clock cycles compared to a 32-bit set of instructions doing the same software function.
If Mikrotik is gonna compete in the router throughput world with the other guys in the faster than 3-Gig enviornment, they need to do everything possible to gain every speed/function/feature advantage possible.
I think I will write to Mikrotik support.
anav
Tue May 15, 2018 1:09 am
EXTRA TAB CHANGE!!
The mere fact of viewing any of the parameters ACTIVATES the parameter and this is WRONG.
All entries should be blank and if you want to offer default settings, GREY THEM OUT.
Suggest putting an apply button or something.
This is not consistent with the rest of the filter rules.
Right now I call it the DANGER DANGER TAB. ;-)
Chupaka
Tue May 15, 2018 11:13 am
Huh... Any more details? What do you mean saying 'Activates'?.. Why can't you 'deactivate' it back? :)
anav
Tue May 15, 2018 2:14 pm
Sorry chupka, I am just a beginner. I didnt know I was changing router settings just by looking at the paramaters in the ExtraTab.
In my limited experience when I clicked on the little arrow tabs, I thought I was simply viewing the default parameters in those selections.
I did NOT REALIZE that I was activating those parameters.
This is not consistent with how we apply items elsewhere in winbox.
Thus suggesting that the default entries be grayed out and one has an implement button when one wants to turn grey into white.
Or it is like every other
Or add a warning at the bottom of the EXTRA TAB. Stating, opening these items ACTIVATES them.
If you do not want them activated CLOSE after viewing.
Chupaka
Tue May 15, 2018 3:54 pm
The same with TCP Flags and ICMP Option in Advanced tab.
Also, DO NOT OPEN Bridge -> Filters, there are 4 tabs and ALL OF THEM are like EXTRA! xD
anav
Tue May 15, 2018 4:25 pm
As I stated, I am new to mikrotik.
To have to rely on intuition vice standard methods is a ridiculous way of setting up programming the router.
Every other selection I make on the router is checking a box, typing in a selection, pulling a selection from a pull-down menu.
I am not saying its wrong, just that from my perspective its bad design and terrible for the non-expert.
Would it hurt that much to have a fixed text at the bottom of the EXTRA TAB.....
"CAUTION: Opening up the parameters via the arrow icons, activates the parameters. If the entries are not modified, the default settings are accepted"
OR
"NOTE: Up facing arrow icons indicates an ACTIVE parameter"
If I could add an image here, and not from an URL, I would post one to give you an idea. :-(
EDIT,,,,,,,,, posted in elsewhere for viewing here.............. the llama cannot be stopped.
Well that was less than useful....... argggg Lets try that again....
https://www.dslreports.com/speak/slides ... RhcnQ9MTgw
Bergante
Tue May 15, 2018 5:23 pm
I've posted a message on the forwarding protocols area, linked from here:
viewtopic.php?f=14&t=134423
BFD support for static routes would be extremely useful. Basicly, a static route would have an attribute to use BFD to check gateway availability. It's much better than check-gateway because it's a standard and it will help both a Mikrotik router and a router from a different manufacturer to detect a link down event.
I think it's simple to implement, even!
TomjNorthIdaho
Re: Feature requests - ability to select :port on a telnet
Wed May 16, 2018 2:00 am
A new added feature I would like to see (when using Winbox to a client Mikrotik) , would be the ability to Tools-->Telnet-->Select (*) telnet and also select a port # to telnet to (and the same for SSH).
Example: Lets say a client Mikrotik has a natted LAN IP address of 192.168.1.1/24 and there is a web server on IP address 192.168.1.20 (possibly not running a non-standard port).
Normally, you can do a telnet to IP-Address:Port# , and when it connects, you can simply type in "GET /" to verify the web server is running. However, if you can't telnet to an alternate port, then it becomes much harder to test out port - which might require a TCP/IP port forward on the outside WAN interface to the inside - then originate you telnet to alternate port from another machine.
Lets say you have a web server locally connected to the same network as your work station - try this: Telnet ip-address:80
At connection , you might not see anything - however type in this: GET /
And you will get some web server information so that you know it is actually running.
Sob
Wed May 16, 2018 2:17 am
I agree that selecting port in Tools->Telnet should be possible, but until it happens, you can do it from Terminal, it already works there:
/system telnet address=192.168.1.20 port=80
GuillermoHA
Tue May 22, 2018 6:30 pm
-Will be great in /ip hotspot active see directly what "user profile" are using without using address-list
WirelessRudy
Tue May 22, 2018 8:22 pm
Those units that have multiple PoE out ports under 'Health' menu the option to read the amps - watts of the input. Thus we can see what the total consumption is for attached devices AND this unit itself.
For many battery/solar operated units it's quit handy to see what the 'real' average power consumption is for a given actual setup.
(It would be even nicer if under 'graphs' a graph could be displayed for the last 24 hours of voltage amp/Watts consumption. Sometimes it is o so handy to know when batteries where charged (= high voltage) and when not (low voltage). The total power consumption also gives us a power budget over a 24 hour period. Power consumption depends on radio usage and that depends on actual data throughput. With a graph we can see if our actual power budget (batteries! Solar panels) are actually up to their task.
5nik
Fri May 25, 2018 12:03 am
It is possible add something like Web Aplication Proxy / redirector for HTTPS (SSL/TLS) trafic? Mikrotik will be able DNAT or redirect HTTPS(generaly SSL/TLS connections with SNI) for specific URL to another IP. It will be usable for hiding more HTTPS servers with diferent URL behind one public IP, or for very simple HTTPS (SSL/TLS) load balancing.
Wyz4k
Fri May 25, 2018 3:48 am
The woobm is awesome, but it lacks the ability to paste. Please add a "paste" button.
bdallen
Mon May 28, 2018 3:43 am
no, the list does not influence our priorities, just gives us ideas about what people want to see.
Sorry Normis, and no disrespect to you, but what does influence this list? People screaming for proper vrf seperation, IPSec VTI Support, DHCP Option 82 Snooping in ROS, Proper BNG Features, IPv6 Needs alot of fixing, BFD (YMMV), BGPv4 MIB and many others.
But yet Kid Control turns up on a CCR??
Confused :S
anav
Mon May 28, 2018 5:01 am
Apparently IPSET uses the hdd memory in my HEX for address tables.
I am very low on HDD due to lists being used.
This is despite the fact that Ihave a 16 gig sd card and 16 gig usb stick in the unit.
FEATURE REQUEST: REMOVE IPSET limitation of internal HDD and be able to apply lists to usb or sdc.
As to the question above rather amusing but a good example of something that doesnt make sense.
Typically easy and no usage of capacity wins - or Kid Control is a billioinaire and wants his feature (or significant segment of market) etc......
pe1chl
Mon May 28, 2018 10:37 am
ipset uses in-memory storage to be able to lookup an address quickly. the CPU can just walk along the list (using hashes and/or tree), without reading from SD card first.
when it would be on disk, it would take far too much time to do the lookup to do it in the routing path.
so it does not make sense to request ipset (ip firewall address-list) to be put on disk instead of in memory.
when your ipset uses too much memory, you should back down on the use you make of it and/or buy a router with more memory.
I don't think it makes any sense to have a list that is to be checked in the routing path to be offline on disk. That would only be useful in the proxy service.
anav
Mon May 28, 2018 2:08 pm
Thanks pe1chi, that makes sense.
Oh well I have two hexes, perhaps I could connect them with a vulcan mind meld and have more memory available.
Which model do you suggest for a home owner, who is only trying to keep the dogs away from the home network.
pe1chl
Mon May 28, 2018 2:55 pm
The hEX r3 has 256 MB of RAM which is normally enough for quite large lists.
You should not try to make a dynamic address list to which items are added e.g. upon unexpected incoming traffic, as this makes the list grow very large.
It is better to focus on firewall settings to keep all that traffic out. That should be easy to do on the typical NAT routing config used at home.
Just don't allow remote management (i.e. do not allow any input from internet except for established/related).
When you really have to have remote management, configure some form of VPN service on the router and allow management only from authenticated VPN users.
anav
Mon May 28, 2018 3:36 pm
I understand, I have fixed lists, based on firehol type information, and I do have some spammer,synflooder,scan lists but they are weighted or need x connections so they are rarely entered.
That said I have 3K left in hdd memory. Will see what I can do to reduce fixed lists..........
wfuzatto
Wed May 30, 2018 7:01 am
What about a fixed VHT data rate for AC device? It would be a nice feature!
doneware
Trainer
Trainer
better ping feedback in scripting
Wed May 30, 2018 10:03 am
can we have at least the summary of the sent/received ping probes returned as values? all we have right now in the number of successful responses received.
[me@router] > put [ping 8.8.8.8 count=3]
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 8.8.8.8                                    56  57 9ms
    1 8.8.8.8                                    56  57 10ms
    2 8.8.8.8                                    56  57 8ms
    sent=3 received=3 packet-loss=0% min-rtt=8ms avg-rtt=9ms max-rtt=10ms
3
Wyz4k
Wed May 30, 2018 10:12 am
In the scripts and schedules editor in winbox can we please add the ability to select all - ie ctrl a? At the moment in order to select a big script you have to manually drag from start to finish.
Sob
Wed May 30, 2018 4:14 pm
@Wyz4k: There's also Select All in right-click menu.
adziahel
Thu May 31, 2018 1:31 am
DNS-over-HTTPS or DNS-over-TLS, in that order of preference
Wyz4k
Fri Jun 01, 2018 3:18 am
There is indeed. Thanks Sob, you are a legend!
anav
Wed Jun 06, 2018 4:34 pm
Hi Chupakha I just wanted to say thanks for your patience, I am just a tad slow and finally get what you are saying.
Yes, without even knowing it I was using the up and down arrow functionality everywhere and thus should have realized what I was in effect doing on the extra page.
I still would like a note at the bottom of the page (text is cheap right?) for new users "Opening a field activates shown parameters, if Apply or OK is selected."
eroberts9
Fri Jun 08, 2018 5:15 am
I'm sure this is an extreme long shot for a feature but having multiple radios broadcasting same SSID and channel appearing as one AP to a client.
Not WDS AP/Slave where the bridge is wireless as it currently can work but having all radios connected Ethernet.
Chupaka
Fri Jun 08, 2018 1:11 pm
So what's the actual 'feature'? You just use same SSID and same security settings - and it works like this. Even if you mix MikroTik, TP-Link, Cisco APs, etc. :)
pe1chl
Fri Jun 08, 2018 1:54 pm
That is one way of doing it, but it does not really work well. Clients have to "hop" between access points and this often only happens when the signal has
become too weak to maintain the connection, so before that the client already experience bad performance.
There are other competitors (Aruba networks, Ruckus, Zyxel and maybe others) who offer true seamless roaming where all your access points have the
same MAC address and the client connects with a "virtual" access point (a controller or a function in a master AP) and remains connected to that, only
the radio layer solves the location issue (all access points try to receive the client, the one who receives it strongest is used to send data to the client).
Indeed it is a nice feature, of course it has drawbacks but it performs best when clients are wandering around in a building or park.
TomjNorthIdaho
Fri Jun 08, 2018 6:00 pm
When using multiple WiFi systems with the same SSID and wireless security settings, you should NOT have the APs perform NAT , but instead those APs should bridge the wireless wlan to an Ethernet network. Then have central core router perform NAT & DHCP on the inside LAN that the AP wireless clients are bridged to.
This will then permit client seamless roaming from AP to AP. When a client roams in your network of APs, the client maintains the same IP address.
If your APs are all doing NAT, then when a client roams to a different AP, you can experience all kinds of problems and end up with of two of the same IP address on the same network.
Chupaka
Fri Jun 08, 2018 6:27 pm
Yeah, but pe1chl tells about old wifi clients who cannot switch to another AP without timeout/diassoc on current AP. Anyway, by wifi standards it's up to the client how to select APs and when to switch...
TomjNorthIdaho
Fri Jun 08, 2018 6:45 pm
One of the problems with RFCs and standards is that often 90% of manufacturer network devices only follow RFCs and standards by only 90%.
When you think about it - it's amazing that the Internet even works with all of the different connected brands of devices
pe1chl
Fri Jun 08, 2018 10:51 pm
There are standards for fast handover but they weaken the security. Also there are standards to provide roaming information so the clients know what other AP's to look
for, still there is trouble all the time. Those seamless roaming networks do not have those problems because the controller decides how it operates and it has complete
knowledge of the topology. However, MikroTIk does not have products in that segment (and neither does Cisco, for that matter).
eroberts9
Fri Jun 08, 2018 11:50 pm
There is only one association, a client does not reassociate if they move from one AP to another. There is not a loss of service when a client moves to a closer AP.
Somewhat like WDS works now via WDS AP -> WDS Slave except backhaul isnt wireless, its via ethernet.
lesnikov
Sat Jun 09, 2018 4:22 pm
Hey,
Probably posted before but here goes again. We need 802.1x integration on routerOS for wired ports.
Been looking for this feature for years now...
anav
Mon Jun 11, 2018 3:24 pm
Due to SIP issues, a friend pointed out this thread.
viewtopic.php?t=129048
So requesting that mikrotik address the issues discovered .
Best to let the experts read and absorb just provided the following quotes....
The issue is stated as...... " A limitation of the UDP + NAT schema" in the mikrotik engine.
or stated another way......
"the conclusion is that the connection tracking engine's architecture on RouterOS is the root cause of this"
"The issue here is that Mikrotik's acceleration tactic of skipping the nat table for packets found in the connections list is the fault"
DanielJB
Tuneable wireless keep-alive interval
Mon Jun 11, 2018 5:21 pm
By default, RouterOS pings all idle wireless clients every 60s. With many associated clients over a larger area (therefore low bitrates) with 1-2 active at any given time, network efficiency is reduced and client battery life is reduced.
Disabling keepalive-frames causes issues wherein clients are listed in the registration table, but the wireless interface goes down.
Please make "/interface wireless set keepalive-frames" an adjustable delay, so we can set eg 300s rather than enabled at 60s or disabled.
Thanks!
Daniel
DummyPLUG
Fri Jun 15, 2018 10:10 am
Please add port redirect in IPv6 firewall, will much easier to force all http/https redirect to proxy and redirect all free/public DNS server access back to local dns server.
p.s. newer linux kernel and ip6tables already support this, hope routeros will have this feature as well.
craterman
Sun Jun 17, 2018 12:34 pm
OSPF and BGP Graceful Shutdown
TomjNorthIdaho
New type of APs - BaseStation - long range - PhassedArray
Wed Jun 20, 2018 9:34 pm
I would like Mikrotik to consider a new type of BaseStation AP
- Something that is possibly modular (where antennas can be mounted to other antennas to form an array of small spot-beam sectors.
- Something that falls under FCC point-to-point higher power rules
- Something that functions simular to a beam-steering phassed-array (where the system acts list a point-to-multi-point system).
Vivato (now out of business) did have two models of phassed-array outdoor BaseStation APs (rated at 2,000 wireless clients per Vivato BaseStation). I still have 16 of them. When Vivato went out of business , I switched over to Mikrotik - because firmware updates for the Vivato were old & dated. Note - I had both Google and the DOD performed testing on my Vivatos phased array BaseStations 10 years ago. They told me they were BLOWN-AWAY because of the long distance (10 miles) they could acheive with a stock notebook computer. Each set of 4 Vivatos (360 degree coverage) were 10 miles apart and they were able to roam from Vivatos to other Vivatos 10 miles away when both Google and the DOD performed their almost month long testing. Each Vivato had around 100 slot-beam antennas. The Vivatos were able to receive & transmit from/to multiple wireless clients at the same time. Their technology used beam-steering with MAC switching on the slot-beam antennas. Depending on where a wireless client was, a client might have a dozen antennas per Vivato they were connected to. Also, the Vivato BaseStations would slightly delay the tx of some antennas to form a directional beam (similar to how a radar system works in a fighter jet - no moving parts - beam steering).
Another company just announced a BaseStation (Ubnt) which is claimed to support the following; 5 Gbps real Aggregate wireless throughput , MU-MIMO , 1,500 wireless clients , 10-Gig Ethernet interface (some serious stuff here !!!)
If the Ubnt BaseStation performs even close to what my Vivatos were doing , then this is a real serious contendor for high-density high-volume high-throughput system.
The current issue today with trying to achieve this with current Mikrotik hardware is that it would require a 120 foot tower physically saturated with almost 100 narrow-beam high-gain overlapping Point-to-Point APs and dish antennas to do the same thing.
I would like to see a Mikrotik system that can achieve the same thing.
WirelessRudy
Re: New type of APs - BaseStation - long range - PhassedArray
Thu Jun 21, 2018 12:41 pm
Sounds interesting. But is part of the evolution in wireless also not that now the spectrum is saturated where 10 years ago is was hardly used? I mean, my first Mikrotik 2,4Ghz 802.11b outdoor AP on a 8dBi omnidirectional had no problem to communicate with my laptop at some 300-400 meters away. And that communication was the sending of an e-mail.
Now I am glad my new dual chain 802.11a/b/g/n/c laptop still has a connection to a 18deBi dual chain 90º sector with Netmetal 30dBm radio some 50 meters away. And I am not interested in sending an e-mail, it needs to be a 4K streaming full duplex Skype video conversation (I am a bit exaggerating).....
10 years ago in a 2,4Ghz scan I'd performed all I saw was my own AP..... Now a scan reveals some 100+ radios..... Ok, we have 5Ghz now, but that is sort of similar. My 5Ghz AP's easy pickup 20 other AP's.... and there must be several hundreds of CPE's communicating with them.
I must mention though we have one 'alien brand' AP working on a village that is also full of 5Ghz AP's and users, but they work with their own protocol on the 5Ghz band. They work with 4 antenas on one AP and then each of these 60º sectors are overlapping to get some 200º reach. The AP works on 10Mhz wide channels but each antena has its own frequency slightly different from the others. Now the OS switches connected CPE's to that sector with a good enough signal to supply the top PHY rate achievable that carries the least traffic. The result is that each of the connected clients have no issue to reach the OS limited top download of just over 30Mbps and sustain that for prolonged times. Basically each sector can sustain a full 30+Mb download to a single client thus the AP can do 4 at once.... in a 10Mhz channel! Low latency, sustained speed...... Try that with a Mikrotik 20 or even 40Mhz normal Wifi solution....
Over the same village we have 2 more AP's, both Netmetal and working 5Ghz NV2 or plain 802.11ac but 30Mbp is only possible if that client is the only one using the AP and only peak speeds. This is with -45dB signals all duo chain 20Mhz wide channels.....
So yeah, there are better ways of doing wireless.....
TomjNorthIdaho
Thu Jun 21, 2018 6:48 pm
WirelessRudy
un-releated to this forum topic ...
Back in 2002, I did a site-survey in all areas we now service (20+ towns/citys). I found zero APs.
Earlier this year , I did a site-survey using 1,000 customer Mikrotiks I manage (I used a Linux script). I found several thousand different APs.
datajerk
Fri Jun 29, 2018 4:02 am
If you are only interested in the switch/router the woobm is connected to via USB, then use telnet instead. You're telnet client C&P will work just fine.
Wyz4k
Fri Jun 29, 2018 4:46 am
This is the feature requests channel. I am requesting a very basic feature that will take all of 30 seconds for somebody to add.
New request:
[admin@MikroTik] > { :put [:resolve www.example.com]; :put "lala";}
failure: dns name does not exist
Please add a way to read the error ("failure: dns name does not exist" in the error above) when using the on-error catch below.
:do {
} on-error={ :put "resolver failed"};
raymondr15
Mon Jul 09, 2018 9:39 pm
Please add support for USB booting on RouterBoards so we can have the ability to install RouterOS onto a USB drive.
Maybe in NetInstall also make it possible which device RouterOS should be installed to if there is more than one. ie: nand, USB...
Reason 1: In case something happens to the nand chip on the RouterBoard.
Reason 2: For testing purposes to test RouterOS releases without making changes to the nand config/software.
Reason 3: In case someone is doing heavy changes all the time that will put undue strain on the nand.
Wyz4k
Tue Jul 10, 2018 6:33 am
Hi everyone,
Please add a way to authenticate with the Mikrotik router using a certificate similar to how you can authenticate with an ssh server using a private/public key pair.
Also then please add a way to disable username / password logins.
Chupaka
Tue Jul 10, 2018 12:34 pm
Hi everyone,
This is already available for SSH. You just upload your public cert to the router - and now you can connect only with this cert, unless you set
/ip ssh set always-allow-password-login=yes
Wyz4k
Tue Jul 10, 2018 1:03 pm
Hi everyone,
Not for winbox though.
genesispro
Tue Jul 10, 2018 1:19 pm
I would also like to be possible to set winbox to a state where changes are pending and the moment all changes done to be able to say commit.
If for example we have the wan port in a bridge with a dhcp-client on the bridge and the we want to remove it from the bridge remotely and add the dhcp-client to the ether1 for example we can't.
To avoid loosing remote access you would need to modify the dhcp-client to the ether1 but you can't because it is a child!
So one needs to remove it from the bridge port and then modify the dhcp-client which would of course has to be done locally... or with a script!
Chupaka
Tue Jul 10, 2018 1:27 pm
Yeah. Also not for WebBox, not for Telnet, not for API...
Anyway, your initial message was not about WinBox. If you need WinBox - use SSH with port forwarding for WinBox :)
Chupaka
Tue Jul 10, 2018 1:31 pm
Not a script, but in a Terminal:
  /interface bridge port remove [find interface=ether1]
  /ip dhcp-client add disabled=no interface=ether1
or
/interface bridge port remove [find interface=ether1]; /ip dhcp-client add disabled=no interface=ether1
genesispro
Tue Jul 10, 2018 1:50 pm
Well I use winbox and/or API so with neither I could do it remotely since I would loose at the first step the remote connection
or
Chupaka
Tue Jul 10, 2018 2:18 pm
Just press Terminal on the left of WinBox. If you use "{ }" - commands inside of brackets will be executed when you press Enter after the bracket. Like this:
[admin@s.internal] > {
{... :put "here"
{... :put "we"
{... :put "go!"
here
we
go!
nicutdk
Mon Jul 16, 2018 1:27 pm
I want to make a suggestion for IP cloud
So...
Will be nice to have feature to associate IPcloud from routerOS with Mikrotik Account to manage all mikrotik router.
For Example I have many clients and I make my own structure to manage. If I forgot to add is to hard to put again.
Regards,
pe1chl
Mon Jul 16, 2018 2:18 pm
A WiFi TDMA mode that is compatible with UBNT airMAX.
We usually have a mix of MikroTik/UBNT access points and clients in our network so we can only use bare 802.11 even when TDMA would perform much better.
Alternative: an IEEE standard for this mode that is implemented by both companies.
pe1chl
Tue Jul 17, 2018 10:36 am
Netinstall for Linux, or documentation of the netinstall process so it can be programmed for Linux by someone else.
diode
Tue Jul 17, 2018 12:24 pm
Having an integrated 5 GHz Backup in LHG 60.
Now I need to mount 2 dishes plus a HEX POE for power ...
WirelessRudy
Tue Jul 17, 2018 2:29 pm
Now you'd wish manufacturers to give one of their main tools to keep clients with them away...
tdma is 'proprietary' protocol. Meaning every radio manufacturer can deviate from the IEEE standard to improve (or at least try to...) the standard on their own. Hence they do and each and every manufacturer has its own ideology and arguments to do it the way they do.
And why should Mikrotik allow Ubiquity to use their standard, or vice versa. And others?
Many wisp made a choice some years ago to go for one brand. Now they are 'married' to that brand if they use tdma. Imagine tdma could be freely used in-between brands. Mikrotik probably would have been bankrupt by then since many WISPs would over time then have move to other platforms.
And to show how complicate it is anyway. The eCambium 'elevate' product line was supposed to be working with 3rd party devices. So far after 2 years of promises it still only worked for Ubnt devices and I believe one model of Mikrotik.
So if you really want to stick to a 'multi brand' network you have to stick to plain 802.11 and to be honest, if you use 'ac' with good antennas and properly configure (RTS/CTS!) that protocol might work in several circumstances better then tdma what I already proved in some posts and just the last week still see is the case. Even after the latest ROS v.6.42.6 I have some P2MP network running in 802.11 instead of NV2 because it give much more capacity for the single client and in total over the AP...
pe1chl
Tue Jul 17, 2018 2:47 pm
We are operating an amateur radio network and we do not control the manufacturer of equipment chosen by the users.
And in fact, the product gamma of the two main manufacturers has been varying over time to give preference to one or the other.
e.g. before the LHG there was no cheap MikroTik user device with some gain, the SXT was too small for many users.
UBNT has the AirGRID devices which, although single-polarization, work over longer distances.
Now with the LHG this has changed, but we still have:
- sites with UBNT AP and a mix of AirGRID and LHG/SXT clients
- sites with MikroTik AP and a mix of AirGRID and LHG/SXT clients
Pracitce shows that the UBNT AP works better in the presence of interference (less problems with spurious RADAR detection)
but the LHG is the better choice for user equipment because it uses both polarisations.
It would be nice if both of them could operate under the same managed access protocol. I have no idea of the internals
of the different protocols now in use. The term TDMA is a bit worrying, hopefully (and likely) it does not mean there is a fixed
timeslot allocation for clients. A good protocol would use some form of round-robin polling of the clients with polling priority
dropping when traffic is low. Something more like DAMA.
I think when neither MikroTIk nor UBNT come up with some openness, the IEEE should publish a standard. Then both
manufacturers can do nothing but implement that standard (possibly alongside their own offering) or they would lose all
their marketshare to a manufacturer that does.
Cha0s
Tue Jul 17, 2018 4:32 pm
+1
Also it would be nice if a MikroTik installation itself can be a netinstall server for another RouterBoard.
pe1chl
Tue Jul 17, 2018 5:44 pm
And install of a clean new RouterOS in an inactive partition on a router with 2 or more partitions.
Router running from Active partition part0, download new npk files and do "install into part1",
optionally copy config from part0 to part1, set part1 to Active and reboot: new clean install without doing netinstall.
andreiroos
Wed Jul 18, 2018 4:26 pm
I saw that it is mentioned to have the ability to set limits in queues from child queues to be expressed in a percentage value of the parent, This have been mentioned about in 2012 (Saw it on tab 5). Would also like it to be implemented especially for the fact that our internet connections get throttled (shaped) at times and this would make life much easier to adjust only the parent queue to implement speed changes.
TomjNorthIdaho
Wed Jul 18, 2018 11:40 pm
Winbox proxy ???
It might be nice to be able to connect to another Mikrotik using the 1st mikrotik as a proxy to be able to connect up to a 2nd Mikrotik.
Where , an admin might not be able to directly connecte to the 2nd mikrotik, but if the 1st mikrotik can mac/IP connect to the 2nd then allow a winbox proxy connection through the 1st mikrotik to a 2nd mikrotik.
ditonet
Forum Veteran
Forum Veteran
Thu Jul 19, 2018 1:04 am
@TomjNorthIdaho
RoMON
https://wiki.mikrotik.com/wiki/Manual:RoMON
Regards,
pe1chl
Thu Jul 19, 2018 11:43 am
@TomjNorthIdaho
RoMON
RoMON works only over L2 transparent links. A proxy could be operating at IP level. A nice feature would be to add an IP-level layer to RoMON so you can
extend the RoMON network like this:
PC <---------IP link--------------->Router1<----------L2 link ----------->Router2
and then access Router2 "via RoMON" from the PC. This can now be done only at commandline-level, not winbox.
mikruser
Long time Member
Long time Member
Thu Jul 19, 2018 12:04 pm
craterman
Thu Jul 19, 2018 2:31 pm
Please make the opportunity to make rules for the firewall with timerange starting today and ending at some time tomorrow. For example from 20:00:00 to 06:00:00
mrz
Thu Jul 19, 2018 2:37 pm
[admin@rOS] /ip firewall> filter add time=
Time ::= [!]Start-End,Day
Start -- 0s..1d (time interval)
End -- 0s..1d (time interval)
Day ::= sun|mon|tue|wed|thu|fri|sat[,Day*]
WirelessRudy
Fri Jul 20, 2018 1:08 am
When testing P2MP networks for best throughput and latency you need to run a test from several CPE's (in a 'all MT' network) and then switch between the different protocols and setting to see what gives best result.
Each time though the connection with AP is lost due a config change, the CPE needs to be opened up again in its winbox session. And each time all settings for the bandwidth test are gone... each time you need to fill these again..
Can bandwidth test not be made to at least remember its settings? It has to be stopped when the CPE drops the connection over the interface the test runs, but it would be o so helpful if the settings for the test just come back after the winbox session is opened again. Just click on 'run' and the test can run again..
Would make it a great time saver in troubleshooting and fine tuning P2MP networks...
metricmoose
Sat Jul 28, 2018 5:25 am
I would like some way of hiding profiles in usermanager from the customer-facing parts, like in the signup and user pages. This would allow us to generate vouchers that will be priced differently or have different limitations than what's available on the self-signup, without making those packages available to self-signup customers.
wpeople
Sat Jul 28, 2018 4:21 pm
Winbox proxy ???
If you can connect to 1st mikrotik via TCP (ssh), than using putty, you can configure additional port forwards on the fly.
(using linux, port forward should be added at connection - windows based putty allows on the fly)
Like: ssh into box1, open putty configuration (connection/ssh/tunnels) add new tunnel: 8291 -> 192.168.1.2:8291
that means connection to localhost:8291, putty will grab those packets, push to ssh server (remote mikrotik) what forwards them to 192.168.1.2:8291 on remote site.
and vice versa
taduikis
Sat Jul 28, 2018 5:53 pm
I use The Dude for this. Leave the Btest windows open and configure as you want..
Wyz4k
Wed Aug 01, 2018 9:04 am
Please implement a proper auto channel selection that looks at the usage and noise floor of each frequency in the scanlist before choosing a channel.
And not one that just counts how many devices it sees per frequency (as per now): viewtopic.php?f=7&t=122063&p=677377#p600476
TomjNorthIdaho
Wed Aug 01, 2018 6:05 pm
+1
When a WISP has multiple APs with the same SSID (nv2 APs), often a client will not select the best AP but rather the 1st AP it finds.
I would like to see some client optional settings that will allow an administrator to define some parameters when scanning for an AP to connect to. Such options might include:
- Scan time prior to making a connection to an AP
- AP selection by one of the following:
-- Strongest AP signal strength
-- Best Signal To Noise ratio
-- Best estimated CCQ
-- Fastest connect receive rate
The current client scan to find an AP is not adiquate and very often does NOT select the best possible AP when there are many candidate APs to connect to.
Example … As a LAB test … If you use SuperChannel with a scan list of 5000-6000 and you have 30 APs. The clients will probably NOT select the best AP to connect to. And also some APs might never get a connection and some APs will get almost all of the client connections. There needs to be a better system for client to AP load distribution so that multiple APs balanced with near equal clients per AP.
Or one possible solution --- I suspect the current client scan for AP mechanism scans starting at the lowest frequency in the scan list then walks up through higher frequencies. I suspect a better client scan system might be to randomize the scan list search order to find an AP. Then multiple APs might have near equal client connection counts.
North Idaho Tom Jones
DmitryAVET
Wed Aug 08, 2018 11:07 am
Graphing is very cool tool, but... it killing Flash when using "Store on Disk" option (Interface/Queue/Resources).
7 days = 100K+ writes to flash...
Please, add posibility to store data on external storage, like USB Flash or microSD card.
Wyz4k
Wed Aug 08, 2018 11:13 am
Please add all items that are in wireless -> registration table to CAPSMAN -> registration table. I regularly use the last-ip column for example which is not available in CAPSMAN.
mlow
Thu Aug 09, 2018 3:10 pm
I'm throwing this on the list a second time.
Support for RFC6939, i.e, the client link-layer address option, enabling a DHCPv6 relay to pass a client's link-layer address (MAC address) as an option (number 79) to a DHCPv6 server, whereupon the server can use that information for static lease reservation, etc.
The need for such is currently described on the DHCPv6 wikipedia page, here: https://en.wikipedia.org/wiki/DHCPv6#RF ... ess_Option
dimonana
Thu Aug 09, 2018 3:23 pm
I'd like to ask to complete IPSEC/IKEv2 implementation.
Motivation is : lots of VPN providers - NordVPN and others - are moving to that, leaving L2TP/IPsec disappearing.
Lombart
Mon Aug 13, 2018 6:34 am
add dual-wan mode at quickset
it realy help for us
thank you
liwest_alx
Mon Aug 13, 2018 1:30 pm
CRS112-8P-4S:
SNMP Oid's for PSU1 + PSU2 Voltage or at least a status.
Currently only Temperature under system health supported.
Jotne
Mon Aug 13, 2018 1:33 pm
CRS112-8P-4S:
So you see it under /system healt print ?
If so you can us Script/Syslog/Splunk to graph it.
See here on how I monitor Temperature.
viewtopic.php?t=137338
magnavox
Mon Aug 13, 2018 9:23 pm
Hi Mikrotik Staff,
any chance for implement MLPPP server ?
Read: viewtopic.php?f=1&t=66192&p=679772#p679772
eroberts9
Tue Aug 14, 2018 4:15 am
DFS certification for the US .
paulct
Tue Aug 14, 2018 10:53 am
Until there is version 7, or whatever it is called. Can we get a BGP peer priority?
e.g say if you need to upgrade ROS, swap out a CCR, or reboot - each BGP is assigned a priority and receives/sends routes according to that policy in order?
e.g:
Peer 1 - default route (priority 1)
IX route server - priority 2
IX2 route server - priority 3
Private peer 1 - Priority 4
Private peer 2 - Priority 5
In that way, essential peer routes are loaded into the routing table first according to what you decide. This would help when provider A peers on a route server and you privately peer with them - rather load the routes from the route server first and so on. We know ROS is not great loading thousands of routes - but at least with this method there is some control.
Maybe even a timer or such?
Basically a stop gap solution until we have higher clocked CPU's / better software.
LucZWFM
Tue Aug 14, 2018 1:06 pm
Making the headers of the tables sticky, so when one scrolls down one still sees the header...
What I mean with header:
Make the gray part sticky please. It's much more comfortable that it will not dissapear when scrolling down...
Thanks!
TomjNorthIdaho
Re: Feature requests - SNMP OID Ethernet link speed
Tue Aug 14, 2018 5:59 pm
It would be great to have SNMP OIDs for Ethernet link speeds. (if they are there , I have not spotted them yet).
These could be very useful to detect when an Ethernet link changes link speed. Such as when what is/was supposed to be a 1-Gig link changes to a 100 meg link.
Omniflux
Tue Aug 14, 2018 8:22 pm
$ snmpwalk -v2c -c public 192.168.88.1 |grep ifSpeed
IF-MIB::ifSpeed.1 = Gauge32: 0
IF-MIB::ifSpeed.2 = Gauge32: 1000000000
IF-MIB::ifSpeed.3 = Gauge32: 1000000000
IF-MIB::ifSpeed.4 = Gauge32: 0
IF-MIB::ifSpeed.5 = Gauge32: 100000000
IF-MIB::ifSpeed.6 = Gauge32: 1000000000
IF-MIB::ifSpeed.7 = Gauge32: 0
IF-MIB::ifSpeed.8 = Gauge32: 0
IF-MIB::ifSpeed.9 = Gauge32: 1000000000
IF-MIB::ifSpeed.10 = Gauge32: 1000000000
IF-MIB::ifSpeed.12 = Gauge32: 100000000
IF-MIB::ifSpeed.14 = Gauge32: 1000000000
IF-MIB::ifSpeed.15 = Gauge32: 0
IF-MIB::ifSpeed.17 = Gauge32: 0
IF-MIB::ifSpeed.18 = Gauge32: 100000000
IF-MIB::ifSpeed.21 = Gauge32: 10000000
IF-MIB::ifSpeed.22 = Gauge32: 0
IF-MIB::ifSpeed.24 = Gauge32: 0
IF-MIB::ifSpeed.25 = Gauge32: 1000000000
StubArea51
Trainer
Trainer
Tue Aug 14, 2018 10:53 pm
+1 !!!!!!
pe1chl
Tue Aug 14, 2018 11:06 pm
As was written above, this feature is already available. And has been for as long as I use RouterOS. So "that could be" and "+1" is completely meaningless.
Jotne
Wed Aug 15, 2018 8:25 am
It works fine on my hEX RB750Gr3
snmpwalk -v2c -c public 192.168.0.1  .1.3.6.1.2.1.2.2.1.5
IF-MIB::ifSpeed.1 = Gauge32: 1000000000
IF-MIB::ifSpeed.3 = Gauge32: 0
IF-MIB::ifSpeed.4 = Gauge32: 1000000000
IF-MIB::ifSpeed.5 = Gauge32: 1000000000
IF-MIB::ifSpeed.8 = Gauge32: 1000000000
snmpwalk -v2c -c public 192.168.0.1 .1.3.6.1.2.1.2.2.1.2
IF-MIB::ifDescr.1 = STRING: ether1-Wan
IF-MIB::ifDescr.2 = STRING: bridge_vlan1
IF-MIB::ifDescr.3 = STRING: ether3
IF-MIB::ifDescr.4 = STRING: ether4-Win_Server
IF-MIB::ifDescr.5 = STRING: ether5-Linux_server
IF-MIB::ifDescr.6 = STRING: pptp-in1
IF-MIB::ifDescr.8 = STRING: ether2-Cisco-Switch
IF-MIB::ifDescr.9 = STRING: bridge-vlan20
IF-MIB::ifDescr.10 = STRING: eth2-vlan20
And on hAP lite 941-2
snmpwalk -v2c -c public 192.168.0.80 .1.3.6.1.2.1.2.2.1.2
IF-MIB::ifDescr.1 = STRING: wlan1
IF-MIB::ifDescr.2 = STRING: ether1
IF-MIB::ifDescr.3 = STRING: ether2
IF-MIB::ifDescr.4 = STRING: ether3
IF-MIB::ifDescr.5 = STRING: ether4
IF-MIB::ifDescr.6 = STRING: bridge
snmpwalk -v2c -c public 192.168.0.80 .1.3.6.1.2.1.2.2.1.5
IF-MIB::ifSpeed.1 = Gauge32: 50000000
TomjNorthIdaho
Wed Aug 15, 2018 7:26 pm
It would be nice if there was a "print oid" output result that contained the OID for ethernet link speed.
mikruser
Long time Member
Long time Member
Sat Aug 25, 2018 3:09 pm
Feature request: AES hardware acceleration for OpenVPN
tigro11
Tue Aug 28, 2018 12:11 am
hi guys, it seems to me that it is still not possible to change the date format in dd/mm/yyyy. It would be very useful as I also work with userman reports.
Does anyone have a solution?
thank you
Valerio
doneware
Trainer
Trainer
Wed Aug 29, 2018 1:00 am
rfc 6286 - AS-wide Unique BGP Identifier for BGP-4 support for routerOS BGP.
it relaxes some strict definitions: routerid can be now an arbitrary 32 bit unsigned integer, while the older definition restricts it to "valid unicast address".
this breaks BGP compatibility with mikrotik devices right now if not taken in consideration.
in general you only need to remove the check that was required in rfc4271.
this needs to be worked out with IPv6-only devices where you don't have no IPv4 address to be used as bgp identifer.
TomjNorthIdaho
Wed Aug 29, 2018 1:05 am
A somewhat simple feature I would like to see in ROS.
The ability to restore a backup and have the option to "Do Not Re-Write MAC Addresses"
it would be great to be able to restore a Mikrotik and have the option to NOT re-write every ethernet & wlan & bridge MAC address
TomjNorthIdaho
Feature Request CLI site-survey include Radio-Name
Wed Aug 29, 2018 10:17 pm
I would like to see the CLI site-survey include "Radio-Name" in the results.
When using winbox, you can see "Radio-Name" in the site-survey results - however when using the CLI such as my example below:
/interface wireless> scan wlan1 duration=90 save-file=SiteSurvey.txt
the CLI site-survey does not include "Radio-Name" in the results.
FYI - I am using NV2
FYI - in all of my Mikrotik APs, I use radio names similar to this: Radio-Name 172-16-10-89-Mica-N/AC-2x2
FYI - I can't simply use SSID , because I have hundreds of Mikrotiks APs using the same SSID.
Without the radio-name in the survey results, it makes it difficult to quickly identify which APs are actually being seen and I have to refer back to MAC addresses and frequency to determine which AP is actually being seen.
DummyPLUG
Mon Sep 03, 2018 5:40 pm
resend syslog email if fail to send, currently any syslog email will be discard if fail to send which raise a problem if wan or mail server down.
Simono
Mon Sep 03, 2018 5:56 pm
Support for ups APC Back-CS via USB cable.
tigro11
Mon Sep 03, 2018 8:35 pm
thank you
Valerio
news?
thobias
Mon Sep 03, 2018 9:22 pm
1. IP firewall address lists could include one another (or firewall rules could match multiple lists at once, e.g. "src-address-list=list1,list2").
Please this to be able to use several lists on a single rule without having to copy them together manually or by scripting.
http://prntscr.com/kq653h
Also do the same on src/dst-address and in/out-interface so we don't have to create a list if just needing a rule with two or three addresses as it makes config more neat.
helipos
Wed Sep 05, 2018 12:14 pm
I would like to see something like triggers when an interface state changes, so router can run a script (like ip-up/ip-down on "real" Linuxes).
+1
pe1chl
Wed Sep 05, 2018 2:10 pm
The underlying Linux mechanism does have a "list of lists" feature so it would be easy to add a "list12" that has "list1" and "list2" as members and then specify that as src-address-list.
There is no support to have several lists or several addresses in a single firewall item. You can only do that by having several separate items and indeed that is what happens when you try that in Linux.
(you insert a simple rule with different addresses and when you look later you have several rules in your table)
Moky
Wed Sep 05, 2018 3:29 pm
I would like to suggest two things:
  1. Webproxy HTTPS support (any of two listed options or both):
    • Possibility to address HTTPS domains with SNI parameter like "tls-host" option in MikroTik filter (e.g. ability to create rules in webproxy with "tls-host").
    • MitM HTTPS decryption support with imported certificate which is trusted on client machines.
  2. NTP client option to show more information about NTP server (like "stratum" etc. - Cisco has a nice info about any configured remote NTP server).
Kind regards,
Moky
thobias
Wed Sep 05, 2018 4:12 pm
But what is preventing Mikrotik from making it possible to create hidden lists from several IPs specified in a single rule or having a rule match if IP exists in list A or list B?
Users browsing this forum: karlisi and 110 guests
