MUM Europe 2020
petro25
nv2 More than 40 km
Tue Apr 05, 2011 11:56 am
On distance more than 40 km disgustingly work the nv2
Sharply level of a signal falls and level of noise raises. Inclusion interface deenergizing helps
on the bridge rx -70 to -84 noise -115 to -97
on the station bridge All in norm
You interchange the position of base and client options
The picture changes too
Problems on bridge
10:20:04 wireless,info 00:0C:42:62:E3:9A@wlan1: disconnected, control frame timeou
t
10:20:06 wireless,info 00:0C:42:62:E3:9A@wlan1: connected
10:20:09 wireless,info 00:0C:42:62:E3:9A@wlan1: disconnected, control frame timeou
t
10:20:10 wireless,info 00:0C:42:62:E3:9A@wlan1: connected
10:20:14 wireless,info 00:0C:42:62:E3:9A@wlan1: disconnected, control frame timeou
t
10:20:15 wireless,info 00:0C:42:62:E3:9A@wlan1: connected
nstreme Works without ruptures but a bit more slowly
nv2 42км r52Hn
tdma 4 ms
radius 50 км
_______________________________________________________________________
56 km nv2 rb411 r52hn
11:16:49 wireless,info 00:0C:42:64:52:7B@wlan1: connected
11:51:54 wireless,info 00:0C:42:64:52:7B@wlan1: reconnecting
11:51:55 wireless,info 00:0C:42:64:52:7B@wlan1: connected
12:13:14 wireless,info 00:0C:42:64:52:7B@wlan1: reconnecting
12:13:14 wireless,info 00:0C:42:64:52:7B@wlan1: connected
12:24:30 wireless,info 00:0C:42:64:52:7B@wlan1: reconnecting
12:24:30 wireless,info 00:0C:42:64:52:7B@wlan1: connected
12:35:27 wireless,info 00:0C:42:64:52:7B@wlan1: reconnecting
12:35:28 wireless,info 00:0C:42:64:52:7B@wlan1: connected
12:37:08 wireless,info 00:0C:42:64:52:7B@wlan1: reconnecting
12:37:08 wireless,info 00:0C:42:64:52:7B@wlan1: connected
12:37:48 wireless,info 00:0C:42:64:52:7B@wlan1: reconnecting
12:37:48 wireless,info 00:0C:42:64:52:7B@wlan1: connected
12:40:38 wireless,info 00:0C:42:64:52:7B@wlan1: reconnecting
12:40:38 wireless,info 00:0C:42:64:52:7B@wlan1: connected
tdma 3ms
radius 60
I can help with testing nv2 on distances from 40 to 60 km
Egate
Long time Member
Long time Member
Re: nv2 More than 40 km
Sat Apr 16, 2011 10:04 am
Also found that on my 43km link signal was very poor until upgrading to V5 do get disconnect, no beacon received now, though. However with NV2 pings higher with high spikes every so often, with 802.11 pings not higher than 3m/s.
Happy days. :-)
petro25
Sat Apr 16, 2011 1:28 pm
You can show options and schedules?
n21roadie
Sat Apr 16, 2011 4:44 pm
What antenna's are being used?
N21roadie,
Network 100% MT for Now?
Egate
Long time Member
Long time Member
Sun Apr 17, 2011 11:28 pm
32 db grid dish.
Happy days. :-)
n21roadie
Tue Apr 19, 2011 3:52 pm
32 db grid dish.
My understanding is
A grid is = http://www.interprojekt.com.pl/gold-wir ... rrency=USD
A Dish is = http://www.interprojekt.com.pl/gold-wir ... p-721.html
A mesh dish is = http://www.rfhamdesign.com/products/par ... index.html
But not sure what a grid dish is?
N21roadie,
petro25
Tue Apr 19, 2011 4:02 pm
About I use
http://sibdata.ru/catalog/cid/104/372.html
http://sibdata.ru/catalog/cid/139/560.html
http://www.spektr-tv.ru/supral1.2pol.php
radio r52Hn
RX\TX -67\-67 180\180 43 km
RX\TX -72\72 90\90 78 km
RX\TX -55\-55 300\300 31 km
n21roadie
Tue Apr 19, 2011 4:42 pm
About I use
radio r52Hn
OK (sorry don't read Russian? ) but my guess from those links, you using a solid 1.2m offset dish, designed for (Диапазон частот, Ггц: 10,95-12,75 GHz) a Антенны стандарта MIMO onto this dish and using cable (8D-FB PVC - коаксиальный кабель 50 Ом,)
N21roadie,
uldis
Tue Apr 19, 2011 5:28 pm
About I use
radio r52Hn
you have 3 links total and those are the data-rates on each link?
What nv2-cell-radius you tried on each of those links and what udp speed and ping times you saw?
petro25
Tue Apr 19, 2011 6:23 pm
(supral 1.2 + SXT5Hd F5100) 43 km cell radius 43 TDMA Perriod 5 ping 5 - 10 ms
(2400) 31km cell radius 30 TDMA Period 2 ping 4 - 8 ms
(2400) 43km cell radius 30 TDMA Period 2 ping 5- 10 ms
100 Mb nstreme ping 1 ms
nv2 Works astably Ticket#2011040366000031
petro25
Tue Apr 19, 2011 6:45 pm
About I use
radio r52Hn
Users browsing this forum: barracuda, Bing [Bot], glueck05, sid5632, Sob, Zacharias and 131 guests
