MUM Europe 2020
jmedinagu
ROS v6.0rc6 on CCR1016-12G crash each 1,30 hours [solved]
Mon Jan 07, 2013 6:46 pm
Hi, I have received today a CCR1016-12G
The first has been updated to v6.0rc6
The router is only connected to one ethernet to use winbox.
Each 1 hour and 30 minutes CCR1016-12G:
- two quick beeps sounds
- and a small sound of air fan 3 seconds
appears in the log:
Jan/07/2013 11:18:29 – system error critical – router was rebooted without proper shutdown
Jan/07/2013 12:49:34 – system error critical – router was rebooted without proper shutdown
Jan/07/2013 14:21:00 – system error critical – router was rebooted without proper shutdown
Jan/07/2013 15:52:05 – system error critical – router was rebooted without proper shutdown
Jan/07/2013 17:16:41 – system error critical – router was rebooted without proper shutdown
Any idea what could be happening?
normis
Re: ROS v6.0rc6 on CCR1016-12G crash each 1,30 hours
Tue Jan 08, 2013 9:54 am
please upgrade to this test release, and see if it helps. if not, this build will have more detailed info in your supout.rif file:
http://www.mikrotik.com/download/share/ ... 6.0rc7.npk
jmedinagu
Tue Jan 08, 2013 4:48 pm
Trying now v6.0rc7, tomorrow see if problems continue.....
I feedback here the results for another people with same problem.
Thanks your fast response.
jmedinagu
Wed Jan 09, 2013 10:41 am
With v6.0rc7 problem solved, router no reboots now each 1,30 hours.
Thanks.
jmedinagu
Wed Jan 09, 2013 3:48 pm
Finally, problem persist with rc7. I installed rc7 yesterday and no problems all night, but this morning:
Jan/09/2013 11:07:23 - system error critical - router was rebooted without proper shutdown
Jan/09/2013 12:20:37 - system error critical - router was rebooted without proper shutdown
Jan/09/2013 13:33:15 - system error critical - router was rebooted without proper shutdown
Jan/09/2013 14:45:40 - system error critical - router was rebooted without proper shutdown
The router is not in use, only 1 eth connect to see winbox.
normis
Thu Jan 10, 2013 9:30 am
when this happens, make supout.rif file and send to us. Also I recommend everyone to connect a serial cable, and check serial console output. You can even keep it connected if your serial console program has big scrollback, you will see any past problems and will be able to copy/paste them for us
jmedinagu
Thu Jan 10, 2013 11:21 am
I try your recommendation tomorrow and feedback here. thx.
jmedinagu
Wed Jan 16, 2013 10:40 am
At the moment with last rc7 only 1 reboot in 4 days, continue monitoring.....
mik0s
Fri Jan 25, 2013 7:34 pm
The same problem. Device CCR1036-12G-4S with 6.0rc7 few days worked intermittently congested. Not immediately noticed. But today reloaded every 5 minutes. Look - was included wathcdog without IP addresses. Disabling - a device hanging. Turned back on. What to do? Very urgent need to solve the problem. (((((
jan/25/2013 17:13:52 system,error,critical router was rebooted without proper shutdown
jan/25/2013 17:23:49 system,error,critical router was rebooted without proper shutdown
jan/25/2013 17:45:15 system,error,critical router was rebooted without proper shutdown
jan/25/2013 18:44:06 system,error,critical router was rebooted without proper shutdown
jan/25/2013 18:50:44 system,error,critical router was rebooted without proper shutdown
jan/25/2013 18:56:18 system,error,critical router was rebooted without proper shutdown
jan/25/2013 19:03:20 system,error,critical router was rebooted without proper shutdown
jan/25/2013 19:09:17 system,error,critical router was rebooted without proper shutdown
alexjhart
Fri Feb 08, 2013 10:03 am
I am also seeing a lot of random reboots in 24 hour periods. The main concern is on v6.0rc7 with CCR1036. I have sent two supouts to support and haven't had a single reply yet. Fast path isn't being used. I don't know if that has anything to do with it. I will have to try the serial console to collect some additional output.
Alex Hart
The Brothers WISP
normis
Fri Feb 08, 2013 10:22 am
Please try the new RC9 release, we have fixed many reboot problems in this release. We will have it on webpage later today, but you can try it now:
http://www.mikrotik.com/download/share/ ... 6.0rc9.npk
alexjhart
Fri Feb 08, 2013 12:44 pm
Thanks normis. I will give that a try.
Alex Hart
The Brothers WISP
alexjhart
Sun Feb 10, 2013 7:14 pm
So far I have gone 1d 09:51:40 with rc9. This is the longest it has lasted without an unexpected reboot. Granted, it tends to reboot every few hours when I have traffic passing through, even when it didn't it didn't make it 24 hours without the watchdog (I assume) rebooting. I might try giving it some load again later if it continues to be stable.
Alex Hart
The Brothers WISP
alexjhart
Sun Feb 10, 2013 7:17 pm
I forgot to mention, my RB951-2n was rebooting every day or so as well and putting rc9 on it has helped. That router has lasted 2d 06:33:15 so far.
Alex Hart
The Brothers WISP
alexjhart
Sat Feb 23, 2013 6:33 am
I haven't had any issues with reboots while on rc9 (13 days uptime on tile and 14 on 951-2n so far). Many thanks! :)
Alex Hart
The Brothers WISP
Users browsing this forum: No registered users and 88 guests
