ahtoh
6to4 tunnel does not work with 192.88.99.1
Fri Jan 25, 2013 5:07 pm
router: RB750
RouterOS version: 6.0rc7
6to4 tunnel setup:
http://wiki.mikrotik.com/wiki/Setting_u ... l_via_6to4
with only difference in the route (one from manual does not work):
ipv6 route add dst-address=::/0 gateway=ipng-tunnel
ping ipv6.google.com - works
ping ipv6.yandex.ru - does not work, as well as for many other sites
What I guess is that 6to4 tunnel does not accept incoming packets that has source address different from one set up in the tunnel ( 192.88.99.1 in my case)
I found this by enabling logging with firewall on WAN interface with Proto-41 filter - reply packets from ipv6.yandex.ru showed up.
Please fix this in the next release
ahtoh
Re: 6to4 tunnel does not work with 192.88.99.1
Wed Jan 30, 2013 10:44 am
any update?
ahtoh
Fri Feb 08, 2013 1:01 pm
6RC9 installed - the issue is still there
can I have at least a confirmation or any comment on this?
can anyone confirm that I'm in the right forum for this issue?
how can I get any support from mikrotik? is it official forum or what?
tomaskir
Trainer
Trainer
Fri Feb 08, 2013 2:41 pm
This is just a user forum. You can email official Mikrotik support at support@mikrotik.com
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
hizel
Wed Jun 19, 2013 11:53 am
Hello! The problem is resolved? I repeated in 6.1 version.
abaddon
Sun Nov 10, 2013 2:02 am
I had the same problem with 6to4.nro.net
I found workaround: create second 6to4 interface with empty remote-address (tested on RouterOS 6.6).
For example:
/interface 6to4 local-address=192.0.2.34 mtu=1280 name=ipng-tunnel-in
Users browsing this forum: Baidu [Spider], Bing [Bot] and 20 guests
